I’m having trouble implementing the following step function as a factor into my variational formulation:
\Theta (\mathbf{n}\cdot \mathbf{v}) = \frac{1}{2} (1 - \tanh(\frac{\mathbf{n}\cdot \mathbf{v}}{U_0 \delta}))
Where \mathbf{n} is the outward facing normal vector and \mathbf{v} is the 2D velocity vector. U_0 and \delta are constants. \mathbf{n} is always [1 \, 0]^T since the variational formulation is only applied at one specific vertical boundary.
\Theta should be then implemented into the variational form as follows:
F = \mathbf{n}\left[\frac{1}{2} \rho |\mathbf{v}|^2 \Theta (\mathbf{n}\cdot \mathbf{v}) \right]
Since I’m multiplying this term with ds(1)
in FEniCS, I’m making sure that this is only applied at the specific boundary marked with 1
The whole boundary term is only relevant when the velocity x-component is negative, then \Theta becomes 0.5, otherwise it’s 0. \Theta is basically a conditional statement.
In my code \mathbf{v} is a function of a 2D function space: v = Function(FunctionSpace)
And therefore a list tensor. \mathbf{n} is defined as n = FacetNormal(mesh)
This minimal code snippet reproduces my error:
from ufl import tanh
class Bottom(SubDomain):
return on_boundary and near(x[1], 0.0)
class Top(SubDomain):
return on_boundary and near(x[1], 96)
class Left(SubDomain):
return on_boundary and near(x[0], 0.0)
class Right(SubDomain):
return on_boundary and near(x[0], 96)
def boundaries(x, on_boundary):
return on_boundary
# Define Function Space
mesh = UnitSquareMesh(96, 96)
P2v = VectorElement("Lagrange", mesh.ufl_cell(), 2)
ME = FunctionSpace(mesh, P2v)
# mark subdomains to boundaries
Right().mark(boundaries, 1)
Left().mark(boundaries, 2)
Top().mark(boundaries,3)
Bottom().mark(boundaries,4)
# Define boundary measure on Neumann part of boundary
ds = Measure("ds", subdomain_data=boundaries)
bcv_top = DirichletBC(ME, Constant((0,0)) , boundaries, 3)
bcv_bottom = DirichletBC(ME, Constant((0,0)) , boundaries, 4)
bcv_inflow = DirichletBC(ME, Constant((1,0)), boundaries, 2)
# put all velocity boundaries in list
bcs = [bcv_inflow, bcv_top, bcv_bottom]
dv = TrialFunction(ME)
w = TestFunction(ME)
# # Define functions
v = Function(ME)
v0 = Function(ME)
rho = Constant(924.3)
U = 0.0048
delta = 0.0025
theta = 0.5 * (1 - tanh(dot(v,n)/(U*delta)))
F = 0.5 * rho * abs(v0)**2 * theta * dot(n, w) * ds(1)
a, L = lhs(F), rhs(F)
problem = LinearVariationalProblem(a, L, v, bcs=bcs)
solver = LinearVariationalSolver(problem)
My error message is:
Form has no parts with arity 2.
Expecting scalar.
File "/Users/pauline/Desktop/minimal code.py", line 68, in <module>
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/dolfin/fem/problem.py", line 55, in __init__
L = Form(L, form_compiler_parameters=form_compiler_parameters)
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/dolfin/fem/form.py", line 43, in __init__
ufc_form = ffc_jit(form, form_compiler_parameters=form_compiler_parameters,
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/dolfin/jit/jit.py", line 47, in mpi_jit
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/dolfin/jit/jit.py", line 97, in ffc_jit
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/jitcompiler.py", line 217, in jit
module = jit_build(ufl_object, module_name, parameters)
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/jitcompiler.py", line 130, in jit_build
module, signature = dijitso.jit(jitable=ufl_object,
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/dijitso/jit.py", line 165, in jit
header, source, dependencies = generate(jitable, name, signature, params["generator"])
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/jitcompiler.py", line 65, in jit_generate
code_h, code_c, dependent_ufl_objects = compile_object(ufl_object,
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/compiler.py", line 142, in compile_form
return compile_ufl_objects(forms, "form", object_names,
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/compiler.py", line 190, in compile_ufl_objects
ir = compute_ir(analysis, prefix, parameters, jit)
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/representation.py", line 182, in compute_ir
irs = [_compute_integral_ir(fd, form_id, prefix, element_numbers, classnames, parameters, jit)
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/representation.py", line 182, in <listcomp>
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/representation.py", line 455, in _compute_integral_ir
ir = r.compute_integral_ir(itg_data,
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/uflacs/uflacsrepresentation.py", line 132, in compute_integral_ir
uflacs_ir = build_uflacs_ir(itg_data.domain.ufl_cell(),
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/uflacs/build_uflacs_ir.py", line 338, in build_uflacs_ir
V, V_deps, V_targets = build_scalar_graph(expressions)
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/uflacs/build_uflacs_ir.py", line 823, in build_scalar_graph
scalar_expressions = rebuild_with_scalar_subexpressions(G)
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/uflacs/analysis/graph_rebuild.py", line 276, in rebuild_with_scalar_subexpressions
ws = reconstruct_scalar_subexpressions(v, wops)
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ufl/corealg/multifunction.py", line 100, in __call__
return self._handlers[o._ufl_typecode_](o, *args)
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ffc/uflacs/analysis/graph_rebuild.py", line 62, in scalar_nary
error("Expecting scalar.")
File "<string>", line 1, in <lambda>
File "/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/ufl/log.py", line 172, in error
Exception: Expecting scalar.
I have the “Form has no parts of arity 2” error because the variational form isn’t complete. I don’t have this error in the complete code. But what’s important is the “expecting scalar” error message.
How can I implement this step function? Does anybody have any idea?
Kind regards,
Pauline
