Implementing Unknown/Interfacial Dirichlet BC
Hi all,
I’m trying to solve a problem where the Dirichlet boundary condition in one domain depends on what is calculated in the other domain. In this sense, the dirichlet boundary condition not known a priori. This problem is slightly more complex than the Poisson periodic boundary condition demo.
As a MWE, consider calculating the pressure drop through two sequential columns packed with porous materials. The pressure drop is estimated using a Darcy-type equation as -dp_i/dx = k_i for bed i on a domain [0, 1].
The boundary conditions are p_0(x=0)=2, and p_1(x=1)=2*p_0(x=1). The friction coefficients are k_0 = 1 = -k_1.
Somewhat related issue is reported here: Mesh movement calculation for FSI - boundary conditions
But I don’t see how to apply that to this issue.
Any help would be appreciated
I’ve solved this problem by essentially adding the “interfacial BC” as an additional equation
