Implicit/Explicit schemes in Stabilization methods
My anecdotal experience with this is that it’s fine to use the full Jacobian of the SUPG terms in Newton’s method, although many manual implementations simply treat \tau as a constant when computing the Jacobian, which involves slightly fewer floating-point operations during assembly and is easier to implement when you don’t have access to FEniCS’s derivative function. However, using the exact Jacobians of highly-nonlinear shock-capturing viscosities is likely to lead to convergence issues.
