Hi, I have a 2d polygon mesh in .stl format. What’s the recommended way to import the mesh in the latest fenicsx? I read a bit about dolfin-convert in old threads. Is it still the right way to do it with Fenicsx?
Regards
JT
Regards
JT
'dolfin-convert’ is long deprecated. To convert to a compatible format (xdmf) I would suggest using meshio.
If you have used the mesh in legacy dolfin, simply write it to xdmf with dolfin.XDMFFile.
Thanks dokken. I managed save into XDMFFile. I tried to following another post by import xdmf file as follows, but it seems no longer working for Fenicsx. Is there some changes in how mesh is imported?
mesh = Mesh()
infile.read(mesh)
mf = cpp.mesh.MeshFunctionSizet(mesh, mvc))
