I am trying to port the NewFrac linear elasticity code to a modern version of Fenics. I get this error:
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/bcs.py", line 230, in dirichletbc
bc = bctype(_value, dofs, V)
TypeError: __init__(): incompatible function arguments. The following argument types are supported:
1. __init__(self, g: ndarray[dtype=float64, order='C', writable=False], dofs: ndarray[dtype=int32, shape=(*), order='C', writable=False], V: dolfinx.cpp.fem.FunctionSpace_float64) -> None
2. __init__(self, g: dolfinx.cpp.fem.Constant_float64, dofs: ndarray[dtype=int32, shape=(*), order='C', writable=False], V: dolfinx.cpp.fem.FunctionSpace_float64) -> None
3. __init__(self, g: dolfinx.cpp.fem.Function_float64, dofs: ndarray[dtype=int32, shape=(*), order='C', writable=False]) -> None
4. __init__(self, g: dolfinx.cpp.fem.Function_float64, dofs: collections.abc.Sequence[ndarray[dtype=int32, shape=(*), order='C', writable=False]], V: dolfinx.cpp.fem.FunctionSpace_float64) -> None
Invoked with types: dolfinx.cpp.fem.DirichletBC_float64, dolfinx.cpp.fem.Constant_float64, ndarray, dolfinx.fem.function.FunctionSpace
File "/home/a/fenics/./test.py", line 180, in <module>
bc_bottom_y = dolfinx.fem.dirichletbc(zero_scalar, dofs_bottom_y, V)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/bcs.py", line 232, in dirichletbc
bc = bctype(_value, dofs, V._cpp_object)
Invoked with types: dolfinx.cpp.fem.DirichletBC_float64, dolfinx.cpp.fem.Constant_float64, ndarray, dolfinx.cpp.fem.FunctionSpace_float64
I can’t find any documentation about this error. Here is the code I have (I cannot provide a minimal example, as I only run into the problem with this full code):
#!/usr/bin/env python3
import sys
from pathlib import Path
from dolfinx.io.gmshio import extract_geometry,extract_topology_and_markers, ufl_mesh
from dolfinx.cpp.io import perm_gmsh
from dolfinx.cpp.mesh import to_type
from dolfinx.mesh import create_mesh
import basix
from dolfinx.fem import Constant
plt.rcParams["figure.figsize"] = (40,6)
def project(v, target_func, bcs=[]):
# Ensure we have a mesh and attach to measure
V = target_func.function_space
dx = ufl.dx(V.mesh)
# Define variational problem for projection
w = ufl.TestFunction(V)
Pv = ufl.TrialFunction(V)
a = ufl.inner(Pv, w) * dx
L = ufl.inner(v, w) * dx
# Assemble linear system
A = assemble_matrix(a, bcs)
b = assemble_vector(L)
apply_lifting(b, [a], [bcs])
set_bc(b, bcs)
solver = PETSc.KSP().create(A.getComm())
solver.setOperators(A)
solver.solve(b, target_func.vector)
def generate_mesh_with_crack(Lx=1,Ly=1,Lcrack=.3,lc=.015,refinement_ratio=10,dist_min=.05,dist_max=.2):
# For further documentation see
# - gmsh tutorials, e.g. see https://gitlab.onelab.info/gmsh/gmsh/-/blob/master/tutorial/python/t10.py
# - dolfinx-gmsh interface https://github.com/FEniCS/dolfinx/blob/master/python/demo/gmsh/demo_gmsh.py
gdim = 2
proc = MPI.COMM_WORLD.rank
if proc == 0:
model = gmsh.model()
model.add("Rectangle")
model.setCurrent("Rectangle")
p1 = model.geo.addPoint(0.0, 0.0, 0, lc)
p2 = model.geo.addPoint(Lcrack, 0.0, 0, lc)
p3 = model.geo.addPoint(Lx, 0, 0, lc)
p4 = model.geo.addPoint(Lx, Ly, 0, lc)
p5 = model.geo.addPoint(0, Ly, 0, lc)
l1 = model.geo.addLine(p1, p2)
l2 = model.geo.addLine(p2, p3)
l3 = model.geo.addLine(p3, p4)
l4 = model.geo.addLine(p4, p5)
l5 = model.geo.addLine(p5, p1)
cloop1 = model.geo.addCurveLoop([l1, l2, l3, l4, l5])
surface_1 = model.geo.addPlaneSurface([cloop1])
model.mesh.field.add("Distance", 1)
model.mesh.field.setNumbers(1, "NodesList", [p2])
#model.mesh.field.setNumber(1, "NNodesByEdge", 100)
#model.mesh.field.setNumbers(1, "EdgesList", [2])
# SizeMax - /------------------
# SizeMin -o----------------/
# Point DistMin DistMax
model.mesh.field.add("Threshold", 2)
model.mesh.field.setNumber(2, "IField", 1)
model.mesh.field.setNumber(2, "LcMin", lc / refinement_ratio)
model.mesh.field.setNumber(2, "LcMax", lc)
model.mesh.field.setNumber(2, "DistMin", dist_min)
model.mesh.field.setNumber(2, "DistMax", dist_max)
model.mesh.field.setAsBackgroundMesh(2)
model.geo.synchronize()
surface_entities = [model[1] for model in model.getEntities(2)]
model.addPhysicalGroup(2, surface_entities, tag=5)
model.setPhysicalName(2, 2, "Rectangle surface")
model.mesh.generate(gdim)
# Sort mesh nodes according to their index in gmsh
geometry_data = extract_geometry(model, name="Rectangle")[:,0:2]
topology_data = extract_topology_and_markers(model, "Rectangle")
# Broadcast cell type data and geometric dimension
gmsh_cell_id = MPI.COMM_WORLD.bcast(model.mesh.getElementType("triangle", 1), root=0)
# Extract the cell type and number of nodes per cell and broadcast
# it to the other processors
gmsh_cell_type = list(topology_data.keys())[0]
properties = gmsh.model.mesh.getElementProperties(gmsh_cell_type)
name, dim, order, num_nodes, local_coords, _ = properties
cells = topology_data[gmsh_cell_type]["topology"]
cell_id, num_nodes = MPI.COMM_WORLD.bcast([gmsh_cell_type, num_nodes], root=0)
cell_id, num_nodes = MPI.COMM_WORLD.bcast([None, None], root=0)
cells, geometry_data = np.empty([0, num_nodes]), np.empty([0, gdim])
#Permute topology data from MSH-ordering to dolfinx-ordering
ufl_domain = ufl_mesh(cell_id, gdim, np.float64)
gmsh_cell_perm = perm_gmsh(to_type(str(ufl_domain.ufl_cell())), num_nodes)
cells = cells[:, gmsh_cell_perm]
# Create distributed mesh
mesh = create_mesh(MPI.COMM_WORLD, cells, geometry_data[:, :gdim], ufl_domain)
return mesh
Lx = 1.
Ly = .5
Lcrack = 0.3
lc =.2
dist_min = .1
dist_max = .3
mesh = generate_mesh_with_crack(Lcrack=Lcrack,
Lx=Lx,
Ly=Ly,
lc=lc, # characteristic length of the mesh
refinement_ratio=20, # how much to refine at the tip zone
dist_min=dist_min, # radius of tip zone
dist_max=dist_max # radius of the transition zone
# element = basix.ufl.element('Lagrange',mesh.topology.cell_name(),degree=1) # ,shape=(2,))
# element = ufl.finiteelement.FiniteElement("Lagrange", mesh.ufl_cell(), degree=1, dim=(2,))
# V = dolfinx.fem.functionspace(mesh, element, (mesh.geometry.dim,))
# 2D Lagrange vector element of degree 1
"Lagrange", # element family
mesh.topology.cell_name(), # cell type as string
1, # polynomial degree
shape=(2,) # vector of 2 components
def bottom_no_crack(x):
return np.logical_and(np.isclose(x[1], 0.0),
x[0] > Lcrack)
def right(x):
return np.isclose(x[0], Lx)
V_x = V.sub(0)
V_y = V.sub(1)
dofs_bottom = dolfinx.fem.locate_dofs_geometrical(V, bottom_no_crack)
dofs_right = dolfinx.fem.locate_dofs_geometrical(V, right)
# --- Extract DOFs for each component ---
# Vector element interleaves: [u_x0, u_y0, u_x1, u_y1, ...]
dofs_bottom_x = dofs_bottom[::2] # x-component
dofs_bottom_y = dofs_bottom[1::2] # y-component
dofs_right_x = dofs_right[::2] # x-component
dofs_right_y = dofs_right[1::2] # y-component
# --- Zero BC values ---
zero_scalar = Constant(mesh, 0.0) # scalar, not a 2D vector
bc_right_x = dolfinx.fem.dirichletbc(zero_scalar, dofs_right_x, V)
bcs = [bc_bottom_y, bc_right_x]
dx = ufl.Measure("dx",domain=mesh)
top_facets = dolfinx.mesh.locate_entities_boundary(mesh, 1, lambda x : np.isclose(x[1], Ly))
mt = dolfinx.mesh.MeshTags(mesh, 1, top_facets, 1)
ds = ufl.Measure("ds", subdomain_data=mt)
u = ufl.TrialFunction(V)
E = 1.
nu = 0.3
mu = E / (2.0 * (1.0 + nu))
lmbda = E * nu / ((1.0 + nu) * (1.0 - 2.0 * nu))
# this is for plane-stress
lmbda = 2*mu*lmbda/(lmbda+2*mu)
def eps(u):
"""Strain"""
return ufl.sym(ufl.grad(u))
def sigma(eps):
"""Stress"""
return 2.0 * mu * eps + lmbda * ufl.tr(eps) * ufl.Identity(2)
def a(u,v):
"""The bilinear form of the weak formulation"""
k = 1.e+6
return ufl.inner(sigma(eps(u)), eps(v)) * dx
def L(v):
"""The linear form of the weak formulation"""
# Volume force
b = dolfinx.fem.Constant(mesh,ufl.as_vector((0,0)))
# Surface force on the top
f = dolfinx.fem.Constant(mesh,ufl.as_vector((0,0.1)))
return ufl.dot(b, v) * dx + ufl.dot(f, v) * ds(1)
problem = dolfinx.fem.LinearProblem(a(u,v), L(v), bcs=bcs,
petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
uh.name = "displacement"
Path("output").mkdir(parents=True, exist_ok=True)
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "elastic.xdmf", "w") as file:
file.write_mesh(uh.function_space.mesh)
file.write_function(uh)
Thanks!
