Inconsistent results with component-wise Dirichlet BC on tetrahedral mesh when using multiple processors
I am trying to apply component-wise Dirichlet boundary conditions on points. I combine The equations of linear elasticity and Component-wise Dirichlet BC.
In the code below, when I use cell_type=mesh.CellType.hexahedron, the results are the same whether I run on one processor or multiple processors.
However, when I change to cell_type=mesh.CellType.tetrahedron, I get different results depending on the number of processors.
Could anyone help me understand why using component-wise Dirichlet conditions with cell_type=mesh.CellType.tetrahedron leads to inconsistent results when running with different numbers of processors?
Thansk
from dolfinx import mesh, fem, io, default_scalar_type
L = 1
W = 0.2
mu = 1
rho = 1
delta = W / L
gamma = 0.4 * delta**2
beta = 1.25
lambda_ = beta
g = gamma
domain = mesh.create_box(
    MPI.COMM_WORLD,
    [np.array([0, 0, 0]), np.array([L, W, W])],
    [20, 5, 5],
    # cell_type=mesh.CellType.hexahedron,
V = fem.functionspace(domain, ("Lagrange", 1, (domain.geometry.dim,)))
point_1_coords = np.array([0, 0, 0])
point_2_coords = np.array([0, W, 0])
point_3_coords = np.array([L, 0, 0])
def point_1(x):
    return np.linalg.norm(x.T - point_1_coords, axis=1) <= 1e-6
def point_2(x):
    return np.linalg.norm(x.T - point_2_coords, axis=1) <= 1e-6
def point_3(x):
    return np.linalg.norm(x.T - point_3_coords, axis=1) <= 1e-6
boundary_vertex_1 = mesh.locate_entities_boundary(domain, 0, point_1)
boundary_vertex_2 = mesh.locate_entities_boundary(domain, 0, point_2)
boundary_vertex_3 = mesh.locate_entities_boundary(domain, 0, point_3)
# print(f"boundary_vertex_1: {boundary_vertex_1} on process {MPI.COMM_WORLD.rank}")
# print(f"boundary_vertex_2: {boundary_vertex_2} on process {MPI.COMM_WORLD.rank}")
# print(f"boundary_vertex_3: {boundary_vertex_3} on process {MPI.COMM_WORLD.rank}")
# Component wise constraints (for tetrahedron results depend on number of processors)
constraint_dofs_x = []
constraint_dofs_x.extend(fem.locate_dofs_topological(V.sub(0), 0, boundary_vertex_1))
constraint_dofs_y = []
constraint_dofs_y.extend(fem.locate_dofs_topological(V.sub(1), 0, boundary_vertex_1))
constraint_dofs_y.extend(fem.locate_dofs_topological(V.sub(1), 0, boundary_vertex_2))
constraint_dofs_z = []
constraint_dofs_z.extend(fem.locate_dofs_topological(V.sub(2), 0, boundary_vertex_1))
constraint_dofs_z.extend(fem.locate_dofs_topological(V.sub(2), 0, boundary_vertex_2))
constraint_dofs_z.extend(fem.locate_dofs_topological(V.sub(2), 0, boundary_vertex_3))
# print(f"constraint_dofs_x: {constraint_dofs_x} on process {MPI.COMM_WORLD.rank}")
# print(f"constraint_dofs_y: {constraint_dofs_y} on process {MPI.COMM_WORLD.rank}")
# print(f"constraint_dofs_z: {constraint_dofs_z} on process {MPI.COMM_WORLD.rank}")
bcx = fem.dirichletbc(
    default_scalar_type(0), np.array(constraint_dofs_x, dtype=np.int32), V.sub(0)
bcy = fem.dirichletbc(
    default_scalar_type(0), np.array(constraint_dofs_y, dtype=np.int32), V.sub(1)
bcz = fem.dirichletbc(
    default_scalar_type(0), np.array(constraint_dofs_z, dtype=np.int32), V.sub(2)
bc = [bcx, bcy, bcz]
# # Constraints in all directions (works fine)
# u_D = np.array([0, 0, 0], dtype=default_scalar_type)
# bc1 = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, 0, boundary_vertex_1), V)
# bc2 = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, 0, boundary_vertex_2), V)
# bc3 = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, 0, boundary_vertex_3), V)
# bc = [bc1, bc2, bc3]
    return ufl.sym(
        ufl.grad(u)
    )  # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
u = ufl.TrialFunction(V)
f = fem.Constant(domain, default_scalar_type((0, 0, -rho * g)))
problem = LinearProblem(
    a, L, bcs=bc, petsc_options={"ksp_type": "preonly", "pc_type": "lu"}
uh = problem.solve()
local_max = np.max(np.abs(uh.x.array))
print("local_max on rank", MPI.COMM_WORLD.rank, "= ", local_max)
global_max = MPI.COMM_WORLD.allreduce(local_max, op=MPI.MAX)
if MPI.COMM_WORLD.rank == 0:
    print("global_max = ", global_max)
# with io.XDMFFile(domain.comm, "test_test_1.xdmf", "w") as xdmf:
#     xdmf.write_mesh(domain)
#     uh.name = "Deformation"
#     xdmf.write_function(uh)
Could it be that your problem is simply ill posed? Prescribing Dirichlet conditions on points on the boundary is not a mathematically permitted operation, which may or may not manifest in the discrete statement. Indeed this could differ per element type, mesh refinement, linear solver, etc. For example, on my system your cell_type=mesh.CellType.hexahedron case with 1 process gives inf results.
Interesting.
I get the following results:
with cell_type=mesh.CellType.hexahedron:
  • mpirun -n 1 → global_max = 0.07377740766356042
  • mpirun -n 2 → global_max = 0.07377740766354705
  • mpirun -n 4 → global_max = 0.07377740766355016
with cell_type=mesh.CellType.tetrahedron:
  • mpirun -n 1 → global_max = inf
  • mpirun -n 2 → global_max = 0.0959180830783075
  • mpirun -n 4 → global_max = 0.0537226913890615
Therefore, I was wondering what happens when I use cell_type=mesh.CellType.tetrahedron and why the results differ depending on the number of processors.
The first thing you should do is to change the PETSc options to:
options =  {"ksp_type": "preonly", "pc_type": "lu",
            "ksp_error_if_not_converged": True,
            "ksp_monitor": None,
which will throw
petsc4py.PETSc.Error: error code 71
[0] KSPSolve() at /usr/local/petsc/src/ksp/ksp/interface/itfunc.c:1089
[0] KSPSolve_Private() at /usr/local/petsc/src/ksp/ksp/interface/itfunc.c:838
[0] KSPSetUp() at /usr/local/petsc/src/ksp/ksp/interface/itfunc.c:427
[0] PCSetUp() at /usr/local/petsc/src/ksp/pc/interface/precon.c:1086
[0] PCSetUp_LU() at /usr/local/petsc/src/ksp/pc/impls/factor/lu/lu.c:121
[0] MatLUFactorNumeric() at /usr/local/petsc/src/mat/interface/matrix.c:3312
[0] MatLUFactorNumeric_SeqAIJ_Inode() at /usr/local/petsc/src/mat/impls/aij/seq/inode.c:1635
[0] MatPivotCheck() at /usr/local/petsc/include/petsc/private/matimpl.h:874
[0] MatPivotCheck_none() at /usr/local/petsc/include/petsc/private/matimpl.h:859
[0] Zero pivot in LU factorization: https://petsc.org/release/faq/#zeropivot
[0] Zero pivot row 2266 value 9.37531e-15 tolerance 2.22045e-14
on the tetrahedral grid.
Thus, one might wonder why this happens in serial and not in parallel, and that can be highlighted by running
            "ksp_error_if_not_converged": False,
and call
problem.solver.view()
after (trying) to solve the system.
In serial it yields:
PC Object: (dolfinx_linearproblem_131380451237840) 1 MPI process
  type: lu
    out-of-place factorization
    tolerance for zero pivot 2.22045e-14
    matrix ordering: nd
    factor fill ratio given 5., needed 6.87672
      Factored matrix follows:
        Mat Object: (dolfinx_linearproblem_131380451237840) 1 MPI process
          type: seqaij
          rows=2268, cols=2268, bs=3
          package used to perform factorization: petsc
          total: nonzeros=567288, allocated nonzeros=567288
            using I-node routines: found 752 nodes, limit used is 5
  linear system matrix = precond matrix:
while in parallel:
PC Object: (dolfinx_linearproblem_125992758287040) 2 MPI processes
  type: lu
    matrix ordering: external
    factor fill ratio given 0., needed 0.
        Mat Object: (dolfinx_linearproblem_125992758287040) 2 MPI processes
          type: mumps
          package used to perform factorization: mumps
          total: nonzeros=587574, allocated nonzeros=587574
            MUMPS run parameters:
              Use -dolfinx_linearproblem_125992758287040ksp_view ::ascii_info_detail to display information for all processes
              RINFOG(1) (global estimated flops for the elimination after analysis): 8.9479e+07
              RINFOG(2) (global estimated flops for the assembly after factorization): 450522.
              RINFOG(3) (global estimated flops for the elimination after factorization): 8.9479e+07
              (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
              INFOG(3) (estimated real workspace for factors on all processors after analysis): 587574
              INFOG(4) (estimated integer workspace for factors on all processors after analysis): 15796
              INFOG(5) (estimated maximum front size in the complete tree): 261
              INFOG(6) (number of nodes in the complete tree): 68
              INFOG(7) (ordering option effectively used after analysis): 2
              INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): -1
              INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 587574
              INFOG(10) (total integer space store the matrix factors after factorization): 15796
              INFOG(11) (order of largest frontal matrix after factorization): 261
              INFOG(12) (number of off-diagonal pivots): 0
              INFOG(13) (number of delayed pivots after factorization): 0
              INFOG(14) (number of memory compress after factorization): 0
              INFOG(15) (number of steps of iterative refinement after solution): 0
              INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 10
              INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 20
              INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 10
              INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 20
              INFOG(20) (estimated number of entries in the factors): 587574
              INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 10
              INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 19
              INFOG(23) (after analysis: value of ICNTL(6) effectively used): 0
              INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
              INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
              INFOG(28) (after factorization: number of null pivots encountered): 0
              INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 587574
              INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 9, 17
              INFOG(32) (after analysis: type of analysis done): 1
              INFOG(33) (value used for ICNTL(8)): 7
              INFOG(34) (exponent of the determinant if determinant is requested): 0
              INFOG(35) (after factorization: number of entries taking into account BLR factor compression - sum over all processors): 587574
              INFOG(36) (after analysis: estimated size of all MUMPS internal data for running BLR in-core - value on the most memory consuming processor): 0
              INFOG(37) (after analysis: estimated size of all MUMPS internal data for running BLR in-core - sum over all processors): 0
              INFOG(38) (after analysis: estimated size of all MUMPS internal data for running BLR out-of-core - value on the most memory consuming processor): 0
              INFOG(39) (after analysis: estimated size of all MUMPS internal data for running BLR out-of-core - sum over all processors): 0
which means that PETSc picks different factorization backends in serial and parallel.
The serial one (is the petsc default solver) does not deal well with null spaces, while the parallel one, mumps deals with null spaces.
However, as you have a null space for your operator (probably rigid body motions, you should remove them with for instance:
which will give you consistent results irregardless of the number of processes.
Full modified code:
L = 1
W = 0.2
mu = 1
rho = 1
delta = W / L
beta = 1.25
lambda_ = beta
g = gamma
    MPI.COMM_WORLD,
    [20, 5, 5],
    #cell_type=mesh.CellType.hexahedron,
def point_1(x):
def point_2(x):
def point_3(x):
    return ufl.sym(
        ufl.grad(u)
def sigma(u):
def build_nullspace(V: dolfinx.fem.FunctionSpace):
    """Build PETSc nullspace for 3D elasticity"""
    dtype = dolfinx.default_scalar_type
    # Create vectors that will span the nullspace
    bs = V.dofmap.index_map_bs
    length0 = V.dofmap.index_map.size_local
    basis = [dolfinx.la.vector(V.dofmap.index_map, bs=bs, dtype=dtype) for i in range(6)]
    b = [b.array for b in basis]
    # Get dof indices for each subspace (x, y and z dofs)
    dofs = [V.sub(i).dofmap.list.flatten() for i in range(3)]
    # Set the three translational rigid body modes
    for i in range(3):
        b[i][dofs[i]] = 1.0
    # Set the three rotational rigid body modes
    dofs_block = V.dofmap.list.flatten()
    x0, x1, x2 = x[dofs_block, 0], x[dofs_block, 1], x[dofs_block, 2]
    b[3][dofs[0]] = -x1
    b[3][dofs[1]] = x0
    b[4][dofs[0]] = x2
    b[4][dofs[2]] = -x0
    b[5][dofs[2]] = x1
    b[5][dofs[1]] = -x2
    dolfinx.la.orthonormalize(basis)
    basis_petsc = [
        PETSc.Vec().createWithArray(x[: bs * length0], bsize=3, comm=V.mesh.comm) for x in b
    return PETSc.NullSpace().create(vectors=basis_petsc)
nsp = build_nullspace(V)
            "pc_factor_mat_solver_type": "mumps",}
uh = fem.Function(V, name="uh")
    a, L,u=uh, bcs=bc, petsc_options=options
problem.A.setNullSpace(nsp)
problem.solve()
You can also visualize the nullspace of your operator, as done in
Hi Jorgen,
Thanks a lot for showing the thought chain for pinpointing the issue and for providing a complete nullspace implementation.
I noticed that switching to the iterative solver
  petsc_options={
      "ksp_type": "cg",
      "pc_type": "gamg",
also solves the “instability” problem, yielding:
  • mpirun -n 1 → global_max = 0.05372279263348693
  • mpirun -n 2 → global_max = 0.05372260524282449
  • mpirun -n 4 → global_max = 0.05372268668671327
Since I see the same package used to perform factorization: petsc with cell_type=mesh.CellType.hexahedron and the run is successful, I can guess that the solver is simply more stable with hex elements.
PC Object: (dolfinx_solve_281472922395824) 1 MPI process
  type: lu
    matrix ordering: nd
    factor fill ratio given 5., needed 4.62462
        Mat Object: (dolfinx_solve_281472922395824) 1 MPI process
          type: seqaij
          total: nonzeros=649962, allocated nonzeros=649962
            using I-node routines: found 732 nodes, limit used is 5
If you use multigrid you should provide the aforementioned nullspace as setnearnullspace:
