Induction heating
Hi, I would like to simulate the heating in a solid with two materials, the main one and small “dots” with different material properties. The small dots should be heated via induction of an electromagnetic field. Any ideas if its possible to do with Fenics considering that both electromagnetic fields and heat transfer can be modeled separately?
Thanks
FEniCS is a general tool for approximation of solutions of PDEs by the finite element method. So yes it’s possible. Everything you need is showcased in the demos.
