Inserting several vectors into assembled global matrix equation
PETSc does give you the tools to precisely specify the sparsity pattern of your matrix, but it gets quite involved quite quickly (MatCreateAIJ — PETSc 3.24.0 documentation )
Maybe just setting the NNZ (number of non-zeros) already gives you the performance you need? I’ve played around with that quite a while ago (Assembly of FEniCS submatrices in large PETSc matrix: preallocation - #6 by Stein)
The PETSc matrix call M.getInfo() is quite useful for checking whether PETSc is actually doing what you intend.
For more targeted help you’d have to supply a MWE.
