Custom NewtonSolver using the mixed-dimensional branch and PETScNestMatrix
Hello everyone,
I’m trying to use the PETScNestMatrix to solve a double-saddle point problem. I precompute one of the blocks to a PETScMatrix. I can’t use directly the mixed-dimensional branch’s solvers because I need to add this precomputed matrix directly to the system. I started by trying to solve an incompressible elasticity problem. I did something similar to this to define a Problem where I could manipulate the assembly of the matrix and create the PETScNestMatrix.
class Problem(d.NonlinearProblem):
    def __init__(self, Ji, Fi):
        self.bilinear_forms = Ji
        self.linear_forms = Fi
        d.NonlinearProblem.__init__(self)
    def F(self, b, x):
        bs = []
        for Gi in self.linear_forms:
            bs_ = d.PETScVector()
            d.assemble(Gi, tensor = bs_)
            bs.append(bs_)
        b_ = bs
        self.A.init_vectors(b, b_)
    def J(self):
        Amat = d.PETScMatrix()
        Ai = []
        for dg in self.bilinear_forms:
            Amat = d.assemble(dg)
            Amat.apply('insert')
            Ai.append(Amat)
        Amat = d.PETScNestMatrix(Ai)
        self.A = Amat
        return Amat
It’s usual that I passed the matrix A to the function J, however, I couldn’t use the option set_nest that it’s used in the C++ code of the mixed-dimensional branch. So my first question is: Is it possible to create an empty PETScNestMatrix and then pass to it the list with the PETScMatrix from Python?
I tried to solve it anyway and I created a NewtonSolver following the C++ codes of the mixed-dimensional branch and I tested in a simple problem.
class NewtonSolver(d.NewtonSolver):
    def __init__(self, mesh):
        factory = d.PETScFactory.instance()
        comm = mesh.mpi_comm()
        d.NewtonSolver.__init__(self, comm, d.PETScLUSolver(),
                                factory)
        self.solver = self.linear_solver()
    def solve(self, problem, u):
        matP = d.PETScMatrix()
        # Extract parameters
        convergence_criterion = self.parameters['convergence_criterion']
        maxiter = self.parameters['maximum_iterations']
        relaxation_parameter = 1.
        # Reset iteration counts
        newton_iteration = 0
        krylov_iterations = 0
        # Compute J to initialize the vectors
        matA = problem.J()
        x = d.PETScVector()
        matA.init_vectors(x, u)
        b = d.PETScVector()
        problem.F(b, x)
        dx = b.copy()
        dx.zero()
        # Check convergence
        newton_converged = False
        if convergence_criterion == 'residual':
            newton_converged = self.converged(b, problem, 0)
        elif convergence_criterion == 'incremental':
            raise ValueError("The convergence criterion %s is unknown, known criteria are 'residual' or 'incremental'")
        # Start iterations
        while (not newton_converged and newton_iteration < maxiter):
            # compute Jacobian
            matA = problem.J()
            matA.convert_to_aij()
            # Setup (linear) solver (including set operators)
            self.solver_setup(matA, matP, problem, newton_iteration);
            # Perform linear solve and update total number of Krylov iterations
            if not dx.empty():
                dx.zero()
            dx0 = np.linalg.solve(matA.array(), b.get_local())
            print('numpy solver:', np.max(dx0))
            krylov_iterations += self.solver.solve(dx, b);
            print('PETSc solver:', np.max(dx.get_local()))
            # Update solution
            self.update_solution(x, dx, relaxation_parameter, problem, newton_iteration);
            newton_iteration += 1
            # Compute F
            matA = problem.J()
            problem.F(b, x);
            # Test for convergence
            newton_converged = self.converged(b, problem, newton_iteration)
        if newton_converged:
            if self.mpi_comm.rank == 0:
              d.info("Newton solver finished in %d" % newton_iteration +
                      " iterations and %d" % krylov_iterations + " linear solver iterations.")
            error_on_nonconvergence = self.parameters["error_on_nonconvergence"]
            if error_on_nonconvergence:
                if newton_iteration == maxiter:
                    raise ValueError("NewtonSolver.cpp",
                          "solve nonlinear system with NewtonSolver",
                          "Newton solver did not converge because maximum number of iterations reached")
                                  "Newton solver did not converge")
                print("Newton solver did not converge.")
        return newton_iteration, newton_converged
    def update_solution(self, x, dx, relaxation_parameter, problem, iteration):
        if relaxation_parameter == 1.0:
            x -= dx
            x.axpy(-relaxation_parameter, dx)
#%% Parameters
mu = d.Constant(1)
lmbda = d.Constant(1)
h1 = d.Constant((0, 0, 0.1))
h2 = d.Constant((0, 0, -0.1))
n = 3
mesh = d.UnitCubeMesh(n, n, n)
#%% Faces
class Top(d.SubDomain):
        return d.near(x[2], 1.)
class Bottom(d.SubDomain):
        return d.near(x[2], 0.)
top = Top()
bot = Bottom()
marker = d.MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
bot.mark(marker, 1)
top.mark(marker, 2)
#%% Spaces
V = d.VectorFunctionSpace(mesh, 'CG', 2)
P = d.FunctionSpace(mesh, 'DG', 1)
W = d.MixedFunctionSpace(V, P)
w = d.Function(W)
u, p = w.sub(0), w.sub(1)
(du, dus) = d.TrialFunctions(W)
(delta_u, delta_us) = d.TestFunctions(W)
dS = d.Measure("ds", domain = W.sub_space(0), subdomain_data = marker)
#%% Kinematics
dim = len(u)
I = d.Identity(dim)             # Identity tensor
F = I + d.grad(u)             # Deformation gradient
J  = d.det(F)
FiT = d.inv(F.T)
C = F.T*F/J**(2./3.)
I1C = d.tr(C)
# Strain energy function
Psi = mu/2.*(I1C - 3.) - p*(J-1)
Pi = Psi*d.dx + d.inner(h1, u)*dS(1) + d.inner(h2, u)*dS(2)
Gi = [d.derivative(Pi, u), d.derivative(Pi, p)]
dGi = []
for gi in Gi:
    for wi in w.split():
        dGi.append(d.derivative(gi, wi))
#%% Set solver
problem = Problem(dGi, Gi)
solver = NewtonSolver(mesh)
solver.parameters['maximum_iterations'] = 1
solver.parameters['error_on_nonconvergence'] = False
solver.solve(problem, [u.vector(), p.vector()])
When I try to solve this problem, in the first iteration (and the followings) the PETScLUSolver gave me a different value than, if for example, I solved it with numpy:
numpy solver: 29.3059696871
PETSc solver: 10856.9383564
If I use a PETScKrylovSolver results in this error:
*** Error:   Unable to successfully call PETSc function 'KSPSolve'.
*** Reason:  PETSc error code is: 73 (Object is in wrong state).
*** Where:   This error was encountered inside /tmp/dolfin/dolfin/la/PETScKrylovSolver.cpp.
*** Process: 0
*** Git changeset:  f0a90b8fffc958ed612484cd3465e59994b695f9
Any idea of why this is happening? I’m using the latest docker container of the mixed-dimensional branch.
Thank you,
Regarding your first question :
There is indeed a set_nest function in the C++ PETScMatrix class, taking as parameters a list of PETSc matrices, which will create or update the corresponding PETScNestMatrix. This C++ function doesn’t seem to be accessible from the python interface.
Regarding the NewtonSolver and PETScKrylovSolver, it is difficult to figure out what is the problem without a MWE.
Hello javijv4,
maybe you can setup your nested matrix directly using petsc4py.
I am using something like this:
M = PETSc.Mat().createNest([[M00,M01], [M10,M11]], comm=MPI.COMM_WORLD)
where all the M as well as all sub-matrices are backend_type matrices (created with e.g. as_backend_type(X).mat)
best wishes
Florian
@cdaversin, thank you for the fast answer. Here is a MEW:
import dolfin as d
d.parameters["form_compiler"]["quadrature_degree"]=4
mu = d.Constant(1)
mesh = d.UnitCubeMesh(3, 3, 3)
top, bot = Top(), Bottom()
bot.mark(marker, 1)
top.mark(marker, 2)
# Spaces
w = d.Function(W)
# Kinematics
I = d.Identity(3)             # Identity tensor
J  = d.det(F)
I1C = d.tr(F.T*F/J**(2./3.))
Psi = mu/2.*(I1C - 3.) - p*(J-1)        # Strain energy function
dGi = []
for gi in Gi:
# Assemble bilinear form
Ai = []
for dg in dGi:
    Ai.append(d.assemble(dg))
# Assemble linear form
bs = []
for g in Gi:
    bs.append(d.assemble(g))
b = d.PETScVector()
Amat.init_vectors(b, bs)
# Set solver
solver_type = 'lu'
if solver_type == 'krylov':
    solver = d.PETScKrylovSolver()
elif solver_type == 'lu':
    solver = d.PETScLUSolver()
Amat.convert_to_aij()
solver.set_operator(Amat)
# Solve
dx0 = np.linalg.solve(Amat.array(), b.get_local())
dx = b.copy()
dx.zero()
Like I said before, if I set solver_type = 'krylov', then I get the PESTc error 73. If I set solver_type = 'lu', then I get a different result depending if I solve using numpy or the PETSc solver.
@Florian_Bruckner yes, I know I can do that. However, if I want to create the matrix and the use a function to give it the submatrices it doesn’t work. For example:
import dolfin as d
def Jmatrix(A, dGi):
    Ai = []
    for dg in dGi:
        Ai.append(d.as_backend_type(Amat).mat())
    A, B, Bt, C = Ai
    Amat = PETSc.Mat().createNest([[A,B], [Bt,C]])
mu = d.Constant(1)
w = d.Function(W)
dim = len(u)
J = d.det(F)
FiT = d.inv(F.T)
I1C = d.tr(C)
Pi = Psi*d.dx
dGi = []
for gi in Gi:
A = d.PETScNestMatrix()
Jmatrix(A, dGi)
print(A.array().shape)
This will print out (0,0). It is useful to do give the values to A inside a Function because this way I only create the matrix once and then I just update its values. Anyway, this is convenient but I can definitely work around that.
My guess is that the PETSc solver and the numpy solver you are using are different, and might then give different results. I am not a PETSc expert, but I did a quick test from your MWE with a different PETSc solver configuration. For example, using superlu :
ksp = solver.ksp()
ksp.setType('preonly')
pc = ksp.getPC()
pc.setType('lu')
pc.setFactorSolverPackage('superlu')
ksp.setFromOptions()
gives :
numpy solver: 13.312943321351039
PETSc solver: 287.7411886846228
I am not sure what is behind the numpy solver, and I think your question is closely related to PETSc so it could be worth posting it to the PETSc mailing list.
