Hi everyone,
docker run -ti dolfinx/dolfinx:stable does not include dolfinx_mpc library/module.
Isn’t GitHub - jorgensd/dolfinx_mpc: Extension for dolfinx to handle multi-point constraints. merged to stable branch?
Best,
Ufuk
Hi everyone,
Best,
Ufuk
DOLFINx_mpc is a standalone library, it is not part of DOLFINx.
You can find docker images including dolfinx_mpc at: Package dolfinx_mpc · GitHub
Thanks for the answer.
I see that dolfinx-mpc is listed in
Does that mean that I can install dolfinx-mpc in docker?
docker pull dolfinx/dolfinx:stable
I tried it in the docker image but after apt upgrade
root@b650ce5a7959:~# apt install dolfinx-mpc
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package dolfinx-mpc
Best,
Ufuk
You need to call
sudo apt update
First
In the container
gives
bash: add-apt-repository: command not found
Then we tried
apt install software-properties-common
to install add-apt-repository but apt install dolfinx-mpc didn’t work again:
root@b650ce5a7959:~# apt update
Hit:1 https://ppa.launchpadcontent.net/fenics-packages/fenics/ubuntu jammy InRelease
Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:4 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
Get:5 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
Get:6 http://security.ubuntu.com/ubuntu jammy-security/main amd64 Packages [754 kB]
Get:7 http://security.ubuntu.com/ubuntu jammy-security/multiverse amd64 Packages [5557 B]
Get:8 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages [799 kB]
Fetched 1669 kB in 50s (33.4 kB/s)
23 packages can be upgraded. Run 'apt list --upgradable' to see them.
Best,
Ufuk
As seen in: Packages in “FEniCS PPA” : FEniCS PPA : “FEniCS Packages Team” team
you need to call apt-get install python3-dolfinx-mpc.
Please note that since you are using apt to install dolfinx, you could start with the ubuntu:22.04 docker container, as you will overwrite all installations of DOLFINx by using apt.
Thank you for your solution.
