Good morning everyone. I am trying to install fenics on my new laptop. It is the Pop-os system, which is based on Ubunto.
First of all, I followed the steps on the website to install fenics. I choose to use conda and I used followed command to install
Then I successfully installed by this method. However, when I try to use it through jupyter lab. There is an error called no module named ‘fenics’, I changed it to ‘fenicsx’, but it still failed.
It really confused me, and I also activate the conda fenicsx-env before this. I also checked the pip list under the fenicsx-env. It shows there is fenics
Moreover, I also considered the possibility that I need to use dolfin and dolfinx instead of fenics and fenicsx, however, the same issue occurs
Moreover, I also did a final check using python3 -c ‘import XXX’ in terminal for fenics, fenicsx, dolfin, and dolfinx. Only dolfinx went through and all other three modules failed(It is checked after I activate the fenicsx-env in conda)
Any advice and help are appreciated!
