Hello everyone. I’m working on a free surface flow using the ALE method to update the surface position. I’m having some issues regarding the mesh deformation - some elements are very distorced and sometimes they become just lines. The initial domain is given from a mesh file converted from GMSH to xml. I’m following this thread to remesh the domain according to a given boundary. I haven’t tested the solution yet, as I’m struggling to install Femorph via PIP. I’m following these instructions to install Femorph via pip in a ubuntu 18.04 WSL, but I’m getting the error:
Directory '.' is not installable. File 'setup.py' not found.
Maybe this error is happening because I’m not using a virtual environment? I work on 3+ projects with fenics, so I chose to install fenics locally instead of using a venv. Just guessing. I’m trying to avoid using docker for now, but if there is no other option, I’ll follow the installation instructions for it.
Any advices?
