I tried to install v0.9.0 via spack. While i have no problems installing older versions (example v0.7.2)
spack add fenics-dolfinx py-fenics-dolfinx
spack install
When i try to install v0.9.0:
spack add fenics-dolfinx@0.9.0 py-fenics-dolfinx
spack install
I get the following error:
==> Installing fenics-dolfinx-0.9.0-vx5ed6nuwjjpotmlseufe2dbm26qqscx [69/71]
==> No binary for fenics-dolfinx-0.9.0-vx5ed6nuwjjpotmlseufe2dbm26qqscx found: installing from source
==> Using cached archive: /zhome/academic/HLRS/isd/isdsg/spack/var/spack/cache/_source-cache/archive/b2/b266c74360c2590c5745d74768c04568c965b44739becca4cd6b5aa58cdbbbd1.tar.gz
==> No patches needed for fenics-dolfinx
==> fenics-dolfinx: Executing phase: 'cmake'
3 errors found in build log:
3 -- The C compiler identification is unknown
4 -- The CXX compiler identification is GNU 12.2.0
5 -- Detecting C compiler ABI info
6 -- Detecting C compiler ABI info - failed
7 -- Check for working C compiler: /zhome/academic/HLRS/isd/isdsg/spack/opt/spack/linux-skylake_avx512/compiler-wrapper-1.0-5isgcady7hsyypjtqqdf37uougwgmbns/libexec/spack/cc
8 -- Check for working C compiler: /zhome/academic/HLRS/isd/isdsg/spack/opt/spack/linux-skylake_avx512/compiler-wrapper-1.0-5isgcady7hsyypjtqqdf37uougwgmbns/libexec/spack/cc - broken
>> 9 CMake Error at /zhome/academic/HLRS/isd/isdsg/spack/opt/spack/linux-rocky8-skylake_avx512/gcc-11.2.0/cmake-3.27.9-akawbnh536ivrvygyer2xirvp5w56zzd/share/cmake-3.27/Modules/CMakeTestCCompiler.cmake:
67 (message):
10 The C compiler
11
12 "/zhome/academic/HLRS/isd/isdsg/spack/opt/spack/linux-skylake_avx512/compiler-wrapper-1.0-5isgcady7hsyypjtqqdf37uougwgmbns/libexec/spack/cc"
13
14 is not able to compile a simple test program.
spack debug report
* **Spack:** 1.0.0.dev0 (46f773762640503530f1987f3b4dd233830ef15e)
* **Python:** 3.6.8
* **Platform:** linux-rocky8-skylake_avx512
I was also not sure if spack github or slack channel are more suitable for this problem.
