Integral Constrains in FEniCSx (whole domain/subdomain)
This is a follow up from the discussion here. It is a semi-simplification of a more complex 3D problem.
Consider the following Dirichlet BC problem with a global integral constraint.
- \partial _x^2u(x) = 0,~~x \in [0,1],~~u(0) = 0.5,~~u(1) = 1.5, ~~\int\limits_0^1 {dx} u(x)=2
This is the same as introducing a Lagrange multiplier \lambda (real constant since the constraint is global) and minimizing the “action”
J[u,\lambda ] = \int\limits_0^1 {dx} {\left( {{\partial _x}u(x)} \right)^2} - \lambda \left( {\int\limits_0^1 {dx} u(x) - 2} \right)
Minimization to \lambda gives the integral constraint and towards u gives - \partial _x^2u(x) = \lambda. Direct analytical solution gives u(x)=-6x^2+7x+0.5. Now since FEniCSx does not support real elements for \lambda in the aforementioned topic it was suggested by @conpierce8 to use @dokken’s dolfinx_mpc library to constrain all the dofs in that subspace to a single dof, and it works perfectly. I will post slightly modified minimal code since the problem is different from the original topic.
import dolfinx_mpc
comm = MPI.COMM_WORLD
### Create mesh and function spaces
domain = dolfinx.mesh.create_unit_interval(comm, 1000)
element1 = ufl.FiniteElement("Lagrange", domain.ufl_cell(), 1)
V = dolfinx.fem.FunctionSpace(domain, ufl.MixedElement([element1, element1]))
V0c, submap = V.sub(0).collapse()
V1 = V.sub(1)
### Create test and test functions
v, r = ufl.TestFunctions(V)
uh = dolfinx.fem.Function(V)
u, m = ufl.TrialFunctions(V)#
points = domain.geometry.x
# Export the mesh points and the boundary points
length=len(points)
### Mark boundaries
def right_boundary(x): return np.isclose(x[0], 1.0)
def left_boundary(x): return np.isclose(x[0], 0.0)
def domain_nodes(x): return ~np.logical_or(left_boundary(x), right_boundary(x))
node_left = dolfinx.mesh.locate_entities_boundary(domain, 0, left_boundary)
node_right = dolfinx.mesh.locate_entities_boundary(domain, 0, right_boundary)
node_middle = dolfinx.mesh.locate_entities_boundary(domain, 0, domain_nodes)
tags = {"left": 2, "right": 3, "middle": 1}
marker_left = np.full_like(node_left, tags["left"])
marker_right = np.full_like(node_right, tags["right"])
marker_middle = np.full_like(node_middle, tags["middle"])
nodes = np.concatenate((node_left, node_right, node_middle))
markers = np.concatenate((marker_left, marker_right, marker_middle))
idx = np.argsort(nodes)
ft = dolfinx.mesh.meshtags(domain, 0, nodes[idx], markers[idx])
### Create Dirichlet bcs
right_facets = dolfinx.fem.locate_dofs_geometrical((V.sub(0), V0c), right_boundary)
left_facets = dolfinx.fem.locate_dofs_geometrical((V.sub(0), V0c), left_boundary)
bc_r = dolfinx.fem.dirichletbc(ScalarType(1.5), right_facets[0], V.sub(0))
bc_l = dolfinx.fem.dirichletbc(ScalarType(0.5), left_facets[0], V.sub(0))
### MultiPointConstraint
mpc = dolfinx_mpc.MultiPointConstraint(V)
# Find the master dof (x = 0.0) and owning process
nodes = dolfinx.mesh.locate_entities_boundary(domain, 0, lambda x: np.isclose(x[0], 0.0))
master_dof = dolfinx.fem.locate_dofs_topological(V1, 0, nodes, remote=False)
master_owner = np.full_like(master_dof, comm.rank)
master_dof = np.concatenate(comm.allgather(master_dof), dtype=np.int64)
master_owner = np.concatenate(comm.allgather(master_owner), dtype=np.int32)
# Check for correct number of master dofs (should be 1)
if master_dof.size != 1:
    raise RuntimeError(f"Expected to find 1 master dof; found {master_dof.size}")
    print(f"[{comm.rank}]: master_dof = {master_dof}")
    print(f"[{comm.rank}]: master_owner = {master_owner}")
# Find the slave nodes
nodes = dolfinx.mesh.locate_entities(domain, 0, lambda x: ~np.isclose(x[0], 0.0))
slave_dof = dolfinx.fem.locate_dofs_topological(V1, 0, nodes, remote=False)
#print(f"[{comm.rank}]: slave_dof = {slave_dof}")
# Create arrays for use by mpc.add_constraint
masters = np.broadcast_to(master_dof, slave_dof.shape)
owners = np.broadcast_to(master_owner, slave_dof.shape)
coeffs = np.ones_like(masters, dtype=ScalarType)
offsets = np.arange(masters.size + 1, dtype=np.int32)
# Create constraint and finalize mpc
mpc.add_constraint(V, slave_dof, masters, coeffs, owners, offsets)
mpc.finalize()
### Create variational form and solve
C0 = dolfinx.fem.Constant(domain, ScalarType(2))
f = dolfinx.fem.Constant(domain, ScalarType(0))
# a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx - m*v*ufl.dx + u * r * ufl.dx
n = ufl.FacetNormal(domain)
ds = ufl.Measure("ds", domain, subdomain_data=ft)
a = (
    ufl.inner(ufl.grad(u), ufl.grad(v))*ufl.dx
    - ufl.inner(m, v)*ufl.dx
    + ufl.inner(u, r)*ufl.dx
    #- ufl.inner(ufl.grad(u), n * v)*ds(tags["left"])
L = ufl.inner(f, v)*ufl.dx  +  ufl.inner(C0, r)*ufl.dx
problem = dolfinx_mpc.LinearProblem(
    a, L, mpc, bcs=[bc_l,bc_r],
    petsc_options={
        "ksp_type": "preonly",
        "pc_type": "lu",
uh = problem.solve()
uh1=uh.x.array
new_array1 = [uh1[i] for i in range(len(uh1)) if i not in slave_dof]
new_array = [new_array1[i] for i in range(len(new_array1)) if i not in master_dof]
def u(x):
    return -6 * (x**2) + 7 * x + 0.5
nn=len(points)
for i in range (nn):
 print(points[i,0],new_array[i],u(points[i,0]))
I want to try to go this problem a step further by introducing a local constraint in a subdomain, \int\limits_0^{0.5} {dx} u(x)=2. If I am not terribly mistaken this means that \lambda takes a constant value in [0,0.5] and has zero contribution otherwise. The action now is J[u,\lambda ] = \int\limits_0^1 {dx} {\left( {{\partial _x}u(x)} \right)^2} - \lambda \left( {\int\limits_0^{0.5} {dx} u(x) - 2} \right) = \int\limits_0^1 {dx} \left[ {{{\left( {{\partial _x}u(x)} \right)}^2} - \lambda \left( {\theta (0.5 - x)u(x) - 2} \right)} \right] and the resulting PDE is - \partial _x^2u(x) = \lambda \theta (0.5 - x) where the step function \theta complicates the problem.
My questions and discussion topics are
  1. The above Lagrangian formalism does not seem elegant. Is there another way to formulate the problem?
  2. How could you suggest to tackle the - \partial _x^2u(x) = \lambda \theta (0.5 - x) and \int\limits_0^{0.5} {dx} u(x)=2 problem in FEniCSx?
  3. Could I maybe create a custom integral measure in FEniCSx and use code similar to the above? How can I do this while working on the dolfinx_mpc library? Or is there a way to split the calculation in two regions?
Any input is obviously highly appreciated.
PS. To solve the problem analytically you split the region in 0.5 and impose continuity in u and \partial _xu in this point and find a piecewise solution. Analytical solution: u(x) = \begin{cases} -\frac{312}{10}{x^2} + \frac{122}{5}x + {\frac{1}{2}}, ~~~ x \in [0,0.5] \\ -\frac{34}{5}x + {\frac{83}{10}},~~~~~~~~~~~~~~ x \in [0.5,1] \end{cases}
It’s not necessary to use a step function in the formulation. You can simply use an integral that is restricted to [0, 0.5]. E.g.
import dolfinx_mpc
V1 = V.sub(1)
length=len(points)
### Mark boundaries
mpc.finalize()
# Create custom integral measure for Lagrange multiplier
cells = dolfinx.mesh.locate_entities(domain, domain.topology.dim, lambda x: x[0] < 0.5 + 1e-6)
tags = np.full_like(cells, 1)
cell_tags = dolfinx.mesh.meshtags(domain, domain.topology.dim, cells, tags)
dx = ufl.Measure('dx', domain, subdomain_data=cell_tags)
f = dolfinx.fem.Constant(domain, ScalarType(1))
# a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx + m*v*ufl.dx + u * r * ufl.dx
a = (
    ufl.inner(ufl.grad(u), ufl.grad(v))*dx
    + ufl.inner(m, v)*dx(1)
    + ufl.inner(u, r)*dx(1)
L = ufl.inner(f, v)*dx  +  ufl.inner(C0, r)*dx
    petsc_options={
        "pc_type": "lu",
uh1=uh.x.array
def u(x):
nn=len(points)
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "solution.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain)
    xdmf.write_function(uh.sub(0).collapse())
Thanks, turns out it is way easier than I thought. I will post a slightly modified code that also compares the numerical solution to the analytical one.
My actual problem is an integral constraint in 3D something like \int\limits_0^h {dz} u(0,1,z) = 1 and the input you provided was way usefull.
Thanks again!
import dolfinx_mpc
V1 = V.sub(1)
length=len(points)
### Mark boundaries
mpc.finalize()
# a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx - m*v*ufl.dx(1) + u * r * ufl.dx(1)
a = (
    - ufl.inner(m, v)*dx(1)
    petsc_options={
        "pc_type": "lu",
uh1=uh.x.array
def u(x):
    if 0 <= x <= 0.5:
        return -312/10 * x**2 + 122/5 * x + 1/2
    elif 0.5 < x <= 1:
        return -34/5 * x + 83/10
        return "x out of range. Please provide x in [0, 1]"
nn=len(points)
