Hi everyone, I’m new of FEnicsX, and I’ve tried to compute galvanic corrosion using FEniCSX.
To calculate that, following procedure will be conducted.
- setting initial potential to the field
- calculating current density at the boundaries according to the functions, two boundaries for galvanic corrosion
- adjusting total current density at the boundaries to zero
- setting adjusted current density to Neumann boundary conditions
- calculating PDE
Then I have two quenstions,
- In adjusting total current density, I have to obtain values of total current density at the boundary. Can I calculate integral of current density at the boundary? For example, can I calculate integral from value of “u” using function “fCDs” at the boundary “boundaryS”?
- After obtaining adjusting current density at the boundary, How do I set values to Neumann boundary condition?
Following is a program I wrote halfway.
Thank you in advance for any help.
Takahiro.
from dolfinx.mesh import create_rectangle
# parameters
lx , ly = 1e-2, 1.0e-3
nx, ny = 200, 20
pN = 100.0
F = 96500.0
R = 8.3144
T = 300.0
DO = 1.9e-9
delta = ly
Einit = -0.9
sigma = 0.2
Ecors = -0.3
Ecorz = -0.9
co = 0.25
ic = 0.35
# create mesh
mesh = create_rectangle(MPI.COMM_WORLD, [np.array([0.0, 0.0]), np.array([lx, ly])], [nx, ny])
# Functions
from dolfinx.fem import FunctionSpace, Function
from ufl import TestFunction, TrialFunction
V = FunctionSpace(mesh, ("CG", 1))
# initial value of u
from dolfinx.fem import Constant, Expression
expr = Expression(Constant(mesh, ScalarType(Einit)), V.element.interpolation_points)
u.interpolate(expr)
# boundaries
def boundaryZ(x):
return np.logical_and(np.isclose(x[1], 0), x[0] < 0.5 * lx)
def boundaryS(x):
return np.logical_and(np.isclose(x[1], 0), x[0] >= 0.5 * lx)
# functions of current density
def fCDs(x):
return ic * np.exp((x - Ecors) * 0.38 * F / (R * T))
def fCDz(x):
return ic * np.exp((x - Ecorz) * 1.2 * F / (R * T))
