I’m new to fenicx. I would like to use it to simulate heat transport under laser irradiation at the surface.
I did a test with internal mesh and it seems to work. However, when I try to use gmsh to add more materials I start to get artifacts even with simple cube.
I believe it is related to the mesh topology but could not find the reason.
I will really appreciate some help.
Here are the results and the 2 codes:
Internal mesh:
from dolfinx import fem, mesh, plot
L = 100.0
H = 100.0
dL = 30
dH = 30
domain = mesh.create_box(MPI.COMM_WORLD,[[0.0,0.0,0.0], [L, L, H]], [dL, dL, dH], mesh.CellType.tetrahedron)
rpump = 25.0
q = ((H-x[2])/ H) * x[0] * (x[0]-L) * x[1] * (x[1]-L) * (2 / (np.pi * rpump * rpump) ) * ufl.exp( - 2 * ((x[0]-L/2.0)**2 + (x[1]-L/2.0)**2) / (rpump * rpump ))
omega = 1e2
c=0.4
k=20
eta = 2*np.pi*1j*c/k
u = ufl.TrialFunction(V)
a = ( ufl.inner(ufl.grad(u), ufl.grad(v)) + eta * omega * ufl.inner(u,v) ) * ufl.dx
L = (omega / k) * ufl.inner(q, v) * ufl.ds
problem = LinearProblem(a, L, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
import dolfinx.io
with dolfinx.io.XDMFFile(domain.comm, "outputreg.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
xdmf.write_function(uh)
Using gmsh
import sys
L = 100.0
H = 100.0
dL = 40
dH = 20
interfaces = [H]
lc = 8
proc = MPI.COMM_WORLD.rank
if proc == 0:
gmsh.model.add("Model")
gmsh.model.occ.addBox(0, 0, 0, L, L, H, 1)
gmsh.model.occ.synchronize()
gmsh.model.addPhysicalGroup(3, [1], 1)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin",2)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax",5)
#gmsh.option.setNumber("Mesh.RecombineAll", 1)
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 1)
gmsh.option.setNumber("Mesh.Algorithm", 8)
gmsh.option.setNumber("Mesh.Algorithm3D", 1)
#gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 2)
gmsh.model.mesh.generate(3)
gmsh.option.setNumber("Mesh.SaveAll", 0)
gmsh.model.geo.synchronize()
gmsh.write("t2.msh")
if '-nopopup' not in sys.argv:
gmsh.fltk.run()
gmsh.finalize()
from dolfinx.io.gmshio import read_from_msh
model_rank = 0
domain, cell_tags, facet_tags = read_from_msh("t2.msh", MPI.COMM_WORLD, model_rank, gdim=3)
rpump = 25.0
q = ((H-x[2])/H) * x[0] * (x[0]-L) * x[1] * (x[1]-L) * (2 / (np.pi * rpump * rpump) ) * ufl.exp( - 2 * ((x[0]-L/2.0)**2 + (x[1]-L/2.0)**2) / (rpump * rpump ))
omega = 1e2
c=0.4
k=20
rpump = 25.0
omega = 1e3
c=0.4
k=20
import dolfinx.io
with dolfinx.io.XDMFFile(domain.comm, "outputocc.xdmf", "w") as xdmf:
