I would like to do the following
f = dolfinx.fem.Function(V)
f.interpolate(lambda x: x[0] ** 2 + x[1] ** 2)
temp = dolfinx.fem.Function(V)
temp_expr = dolfinx.fem.Expression(ufl.dot(f, v), V.element.interpolation_points())
temp.interpolate(temp_expr)
so I can then visualize the fem.Function within the domain. Is this possible?
If I try this, I get
RuntimeError: Cannot interpolate Expression with Argument
What you are trying to do is to assemble a linear form. Simply assemble it in temp.vector
(or temp.x.petsc_vec
in newer dolfinx versions) rather than a new vector created on the fly.
Can you elaborate a bit further please.
I managed to do this
temp_expr = ufl.dot(f, v) * ufl.dx
temp_form = dolfinx.fem.form(temp_expr)
b = dolfinx.fem.petsc.assemble_vector(temp_form)
but I am not sure how to proceed next with the temp.vector
/temp.x.petsc_vec
like you mentioned
Essentialy what I would like to do is to display the RHS vector of the
inside the domain.
I can’t test it now, but something like
dolfinx.fem.petsc.assemble_vector(temp.vector, temp_form)
should do the job
