I did some more experimentation, if anybody is interested in a follow up:
Using the ideas from
https://fenicsproject.org/qa/5245/nedelec-interpolation/
I got to the following program to “manually” calculate the BDM-interpolant of a function on a triangle, which seems to be working very nice, as it reproduces the results I get from the NGSolve interpolation.
Anyhow, this still leaves the question what the internal interpolate() function does, and why it seems to do the wrong thing when interpolating to a BDM function space.
order = 2
editor = MeshEditor()
mesh = Mesh()
editor.open(mesh, 'triangle', 2, 2)
editor.init_vertices(4)
editor.add_vertex(0,[0,0])
editor.add_vertex(1,[1,0])
editor.add_vertex(2,[0,1])
editor.init_cells(1)
editor.add_cell(0, [0,1,2])
editor.close()
mesh.init()
def BDMi_Ned_dofs(u0, mesh, r):
V = FunctionSpace(mesh, 'BDM', r)
if r == 1:
W = FunctionSpace(mesh, 'BDM', 1)
v0 = TestFunction(W)
V0 = FiniteElement('BDM', mesh.ufl_cell(), r)
V1 = FiniteElement('N1curl', mesh.ufl_cell(), r-1)
W = FunctionSpace(mesh, MixedElement([V0,V1]))
v0, v1 = TestFunctions(W)
a = (inner(u, n) * inner(v0, n))('+') * dS + inner(u, n) * inner(v0, n) * ds
L = (inner(u0, n) * inner(v0, n))('+') * dS + inner(u0, n) * inner(v0, n) * ds
if r > 1:
a = a + inner(u, v1) * dx
L = L + inner(u0, v1) * dx
A = assemble(a)
A_reduced = assemble(inner(u,v)*dx(mesh))
b = assemble(L)
b_reduced = assemble(inner(v,Function(V))*dx(mesh))
n_facet_dofs = A.size(0) - 2*(A.size(0)-A.size(1))
n_internal_dofs = V.dim() - n_facet_dofs
cols = np.array([i for i in range(A.size(1))], dtype=np.intc)
block = np.ndarray((V.dim(),V.dim()), dtype=np.float_)
for i in range(n_facet_dofs):
block[i,:] = A.getrow(i)[1][:]
b_reduced[i] = b[i]
for i in range(n_internal_dofs):
block[n_facet_dofs+i,:] = A.getrow(n_facet_dofs+n_internal_dofs+i)[1][:]
b_reduced[n_facet_dofs+i] = b[n_facet_dofs+n_internal_dofs+i]
A_reduced.set(block, cols, cols)
A_reduced.apply('insert')
b_reduced.apply('insert')
solve(A_reduced, u.vector(), b_reduced)
return u
V = FunctionSpace(mesh, 'BDM', order)
g = Expression(('0','pow(x[0],3)'), degree = 3)
#u = interpolate(g,V)
u = BDMi_Ned_dofs(g, mesh, order)
print('Interpolation manual, Nedelec dofs:')
print('\t L2 norm u[0]', assemble(u[0]*u[0]*dx(mesh)))
print('\t L2 norm u[1]', assemble(u[1]*u[1]*dx(mesh)))
print('\t L2 norm div(u)', assemble(div(u)*div(u)*dx(mesh)))
print('\n')
u = interpolate(g, V)
print('Interpolation automatic:')
