Hi Fenicsers,
I pose kindly my question here, which is occurring during the mesh refinement within MPI parallel computation.
I have a pointwise level set function (lsf_project()) which is defined on the previous mesh, after mesh refinement, this function can no longer be evaluated correctly.
The minimum code is showed as follows:
else: #refinement=True
print('********************************************Refinement******************************************************')
It_refine=It_refine+1 #new mesh is defined here, avoid the bug of MPI during refinement process
Nx=Nx+4
Ny=Ny+4
Nz=Nz+4
meshname="mesh_{}".format(It_refine)
meshname=BoxMesh(comm, Point(0.0,0.0,0.0),Point(1.0,1.0,1.0),Nx,Ny,Nz)
materials= MeshFunction('size_t', meshname, 3) #3 represents the dim of topology which leads to tetrahedral mesh
dx=Measure("dx")(subdomain_data=materials,domain=meshname)
#Function space
V=FunctionSpace(meshname,'CG',deg)
#lsf function is defined pointwisely and based on the previous function space V
lsf_project=Function(V)
lsf_project.assign(project(lsf,V))
An error occurs when computing the code "lsf_project.assign(project(lsf,V)) " with info:
*** Error: Unable to evaluate function at point.
*** Reason: The point is not inside the domain. Consider calling "Function::set_allow_extrapolation(true)" on this Function to allow extrapolation.
*** Where: This error was encountered inside Function.cpp.
*** Process: 1
*** DOLFIN version: 2019.1.0
*** Git changeset: 74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
Great thanks for your further help.
