The API of DOLFINx has changed since 0.6.0 release (which is the one on conda).
Here is an updated version with the current nightly build (21/09/2023):
# Copyright (C) 2023 Jørgen S. Dokken
# Local assembly in DOLFINx using numpy
# SPDX-License-Identifier: MIT
import time
import cffi
import dolfinx.fem.petsc as petsc
from ufl import div, ds, dx, grad, inner
class LocalAssembler():
def __init__(self, form):
self.form = fem.form(form)
self.update_coefficients()
self.update_constants()
cell_form_pos = self.form.ufcx_form.form_integral_offsets[0]
subdomain_ids = self.form._cpp_object.integral_ids(fem.IntegralType.cell)
assert(len(subdomain_ids) == 1)
assert(subdomain_ids[0] == -1)
is_complex = np.issubdtype(ScalarType, np.complexfloating)
nptype = "complex128" if is_complex else "float64"
self.kernel = getattr(self.form.ufcx_form.form_integrals[cell_form_pos],f"tabulate_tensor_{nptype}")
self.active_cells = self.form._cpp_object.domains(fem.IntegralType.cell,subdomain_ids[0])
assert len(self.form.function_spaces) == self.form.rank
self.local_shape = [0 for _ in range(self.form.rank)]
for i, V in enumerate(self.form.function_spaces):
self.local_shape[i] = V.dofmap.dof_layout.block_size * V.dofmap.dof_layout.num_dofs
e0 = self.form.function_spaces[0].element
if self.form.rank == 1:
e1 = self.form.function_spaces[0].element
elif self.form.rank == 2:
e1 = self.form.function_spaces[1].element
raise RuntimeError(f"Assembly for tensor of tensor of {rank=} is not supported")
needs_transformation_data = e0.needs_dof_transformations or e1.needs_dof_transformations or \
self.form._cpp_object.needs_facet_permutations
if needs_transformation_data:
raise NotImplementedError("Dof transformations not implemented")
self.ffi = cffi.FFI()
V = self.form.function_spaces[0]
self.x_dofs = V.mesh.geometry.dofmap
self.local_tensor = np.zeros(self.local_shape, dtype=ScalarType)
def update_coefficients(self):
self.coeffs = fem.assemble.pack_coefficients(self.form._cpp_object)[(fem.IntegralType.cell, -1)]
def update_constants(self):
self.consts = fem.assemble.pack_constants(self.form._cpp_object)
def update(self):
def assemble(self, i:int):
x = self.form.function_spaces[0].mesh.geometry.x
x_dofs = self.x_dofs[i]
geometry = np.zeros((len(x_dofs), 3), dtype=np.float64)
geometry[:, :] = x[x_dofs]
facet_index = np.zeros(0, dtype=np.intc)
facet_perm = np.zeros(0, dtype=np.uint8)
if self.coeffs.shape == (0, 0):
coeffs = np.zeros(0, dtype=ScalarType)
coeffs = self.coeffs[i,:]
ffi_fb = self.ffi.from_buffer
self.local_tensor.fill(0)
self.kernel(ffi_fb(self.local_tensor), ffi_fb(coeffs), ffi_fb(self.consts), ffi_fb(geometry),
ffi_fb(facet_index), ffi_fb(facet_perm))
return self.local_tensor
N = 20
msh = mesh.create_box(MPI.COMM_WORLD, [np.array([0.0, 0.0, 0.0]),
np.array([2.0, 1.0, 1.0])], [N, N, N],
mesh.CellType.tetrahedron)
Q = fem.FunctionSpace(msh, ("DG", 2))
p = ufl.TrialFunction(Q)
q = ufl.TestFunction(Q)
a = inner(p, q) *dx
lhs_assembler = LocalAssembler(a)
W = fem.VectorFunctionSpace(msh, ("Lagrange", 1))
uh = fem.Function(W)
uh.interpolate(lambda x: (x[0], 2*x[1], x[2]**2))
l = inner(div(uh), q)*dx
rhs_assembler = LocalAssembler(l)
w1 = fem.Function(Q)
bs = Q.dofmap.bs
start = time.perf_counter()
for cell in range(msh.topology.index_map(msh.topology.dim).size_local):
A = lhs_assembler.assemble(cell)
b = rhs_assembler.assemble(cell)
cell_dofs = Q.dofmap.cell_dofs(cell)
unrolled_dofs = np.zeros(len(cell_dofs)*bs, dtype=np.int32)
for i, dof in enumerate(cell_dofs):
for j in range(bs):
unrolled_dofs[i*bs+j] = dof*bs+j
w1.x.array[unrolled_dofs] = np.linalg.solve(A, b)
w1.x.scatter_forward()
end = time.perf_counter()
print(f"Local assembly {end-start:.2e}")
w2 = fem.Function(Q)
problem = petsc.LinearProblem(a, l, u=w2)
problem.solve()
w2.x.scatter_forward()
print(f"Global assembly {end-start:.2e}")
with VTXWriter(msh.comm, "w1.bp", [w1]) as vtx:
vtx.write(0)
with VTXWriter(msh.comm, "w2.bp", [w2]) as vtx:
vtx.write(0)
assert np.allclose(w1.x.array, w2.x.array)
