Hi there
I am really new to fenics, but i worked the tutorials through. Now I am trying to do some more stuff to get into fenics.
https://1drv.ms/u/s!AocekCrLgWbAihmCF7NaIQBNEIit?e=HEuUJC
As you can see in the attached image, I try to simulate a pulling force on a physical surface (2) of a geometry. The second geometry is fixed at its left and right physical planes (1 + 3).
The code I created works but I do not know how to define a specific Force on the surface 2. In addition I have not found any contact body model. Can someone help me to get this to bodies connected?
I found this: https://comet-fenics.readthedocs.io/en/latest/demo/contact/penalty.html but I am not sure how to implement this in my code.
I will upload the .geo code in separat code.
Thank you very much.
from ufl import nabla_div
from dolfin import Mesh, XDMFFile, File, MeshValueCollection, cpp, Measure,
DirichletBC, FunctionSpace, Constant, TrialFunction,
TestFunction, dot, grad, dx, Function, solve
msh = meshio.read("./winkel.msh")
for cell in msh.cells:
if cell.type == “triangle”:
triangle_cells = cell.data
elif cell.type == “tetra”:
tetra_cells = cell.data
for key in msh.cell_data_dict[“gmsh:physical”].keys():
if key == “triangle”:
triangle_data = msh.cell_data_dict[“gmsh:physical”][key]
elif key == “tetra”:
tetra_data = msh.cell_data_dict[“gmsh:physical”][key]
tetra_mesh = meshio.Mesh(points=msh.points, cells={“tetra”: tetra_cells})
triangle_mesh =meshio.Mesh(points=msh.points,
cells=[(“triangle”, triangle_cells)],
cell_data={“name_to_read”:[triangle_data]})
meshio.write(“mesh.xdmf”, tetra_mesh)
meshio.write(“mf.xdmf”, triangle_mesh)
Scaled variables
E = 210000000000
nu = 0.3
mu, lambda_ = Constant(E/(2*(1 + nu))), Constant(Enu/((1 + nu)(1 - 2nu)))
#mu = 80769200000
rho = 7800
load = 0 #beachte Vorzeichen
F = load #Kraft auf Objekt (eventuell muss hier force per volume gewählt werden)
gamma = -9.81 #beachte Vorzeichen*
#beta = 121154000000
#lambda_ = beta
g = gamma
Create mesh and define function space
mesh = Mesh()
with XDMFFile(“mesh.xdmf”) as infile:
infile.read(mesh)
File(“winkel_mesh.pvd”).write(mesh)
mvc = MeshValueCollection(“size_t”, mesh, 1)
with XDMFFile(“mf.xdmf”) as infile:
infile.read(mvc, “name_to_read”)
File(“winkel_facets.pvd”).write(mf)
V = VectorFunctionSpace(mesh, ‘P’, 1)
Define boundary condition
bcl = DirichletBC(V, Constant((0, 0, 0)), mf, 1)
bcr = DirichletBC(V, Constant((0, 0, 0)), mf, 3)
bcup = DirichletBC(V, Constant((0, 200, 0)), mf, 2)
###bcup is displacement? how do I get a Force to this physical surface?
bcs = [bcl, bcr, bcup]
Define strain and stress
#return sym(nabla_grad(u))
def sigma(u):
return lambda_nabla_div(u)Identity(d) + 2muepsilon(u)
Define variational problem
d = u.geometric_dimension() # space dimension
f = Constant((0, rho*g+F, 0))
T = Constant((0, 0, 0)) #traction force
#Z = Constant((0, 100, 0)) #force on physical plane
L = dot(f, v)*dx + dot(T, v)*ds #+ dot(Z, v)*ds
Compute solution
solve(a == L, u, bcs)
Plot stress
s = sigma(u) - (1./3)*tr(sigma(u))Identity(d) # deviatoric stress
von_Mises = sqrt(3./2inner(s, s))
V = FunctionSpace(mesh, ‘P’, 1)
von_Mises = project(von_Mises, V)
Compute magnitude of displacement
u_magnitude = sqrt(dot(u, u))
u_magnitude = project(u_magnitude, V)
print(‘min/max u:’,
u_magnitude.vector().get_local().min(),
u_magnitude.vector().get_local().max())
Save solution to file in VTK format
File(‘winkel/displacement_fenics.pvd’) << u
File(‘winkel/von_mises_fenics.pvd’) << von_Mises
File(‘winkel/magnitude_fenics.pvd’) << u_magnitude
