I want to learn to model electric field around electrostatic charged bodies using Fenicsx and looking for tutorials on parallel capacitors and similar problems.
from dolfinx.fem import functionspace, Function, dirichletbc
from dolfinx import default_scalar_type, fem, mesh, io
nx, ny = 50, 50
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])],
[nx, ny], mesh.CellType.triangle)
V = fem.functionspace(domain, ("CG", 1))
f = fem.Constant(domain, default_scalar_type(0.0))
# Define boundary conditions
def boundary_top(x):
return np.isclose(x[1], 2)
def boundary_bottom(x):
return np.isclose(x[1], -2)
# Set Dirichlet boundary conditions
facet_top = mesh.locate_entities_boundary(domain, fdim, boundary_top)
# Define a function to set the inflow profile
def sin_function(x):
return np.sin(np.pi * x[1])
u_top = fem.Function(V)
u_top.interpolate(sin_function)
dofs_top = fem.locate_dofs_topological(V, fdim, facet_top)
bc_top = fem.dirichletbc(u_top, dofs_top, V)
facet_bottom = mesh.locate_entities_boundary(domain, fdim, boundary_bottom)
bc_bottom = fem.dirichletbc(PETSc.ScalarType(-1), fem.locate_dofs_topological(V, fdim, facet_bottom), V)
u = ufl.TrialFunction(V)
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
# Compute solution
A_z = fem.Function(V)
problem = LinearProblem(a, L, u=A_z, bcs=[bc_top, bc_bottom], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
# Save solution to file
with io.XDMFFile(domain.comm, "capacitor_potential.xdmf", "w") as file:
file.write_mesh(domain)
file.write_function(uh)
# Compute electric field
gdim = domain.geometry.dim
E_field = -ufl.grad(uh)
V_E = fem.functionspace(domain, ("CG", 2, (gdim, )))
E = fem.Function(V_E)
E_expr = fem.Expression(E_field, V_E.element.interpolation_points())
E.interpolate(E_expr)
# Export solution
with io.VTXWriter(domain.comm, "capacitor_field.bp", E, engine="BP4") as vtx:
vtx.write(0.0)
I have written a small code, at the top I want a sinusoidal distribution of potential. But I am getting some error. Also, how can I expand the domain to include space around the plate?
Since no tutorial was available for solving basic electrostatics problem using Fenics. I tried to try it for solving capacitor.
from dolfinx.io import gmshio
from ufl import div, grad, inner, dx, Measure
# Initialize parameters
L, H = 5, 5 # Domain size
plate_length = 1
plate_height = 0.1
V0 = 100.0 # Voltage on upper plate
model_rank = 0
mesh_comm = MPI.COMM_WORLD
gdim = 2
# Initialize gmsh
# Create background domain
background = gmsh.model.occ.addRectangle(0, 0, 0, L, H)
# Create plates
upper_plate = gmsh.model.occ.addRectangle(2, 2, 0, plate_length, plate_height)
lower_plate = gmsh.model.occ.addRectangle(2, 3, 0, plate_length, plate_height)
gmsh.model.occ.synchronize()
# Fragment all geometries together
all_surfaces = [(2, upper_plate), (2, lower_plate)]
whole_domain = gmsh.model.occ.fragment([(2, background)], all_surfaces)
# Create physical markers
upper_plate_marker, lower_plate_marker = 1, 2
background_surfaces = []
other_surfaces = []
for domain in whole_domain[0]:
com = gmsh.model.occ.getCenterOfMass(domain[0], domain[1])
# Identify upper plate
if 2 <= com[0] <= 3 and 2 <= com[1] <= 2.1:
gmsh.model.addPhysicalGroup(domain[0], [domain[1]], tag=1)
gmsh.model.setPhysicalName(domain[0], 1, "upper_plate")
other_surfaces.append(domain)
# Identify lower plate
elif 2 <= com[0] <= 3 and 3 <= com[1] <= 3.1:
gmsh.model.addPhysicalGroup(domain[0], [domain[1]], tag=2)
gmsh.model.setPhysicalName(domain[0], 2, "lower_plate")
# Background is everything else
background_surfaces.append(domain[1])
# Add marker for background
gmsh.model.addPhysicalGroup(2, background_surfaces, tag=0)
gmsh.model.setPhysicalName(2, 0, "background")
# Create refined mesh around plates
edges = gmsh.model.getBoundary(other_surfaces, oriented=False)
gmsh.model.mesh.field.setNumbers(1, "EdgesList", [e[1] for e in edges])
# Add threshold field for mesh refinement
gmsh.model.mesh.field.setNumber(2, "IField", 1)
gmsh.model.mesh.field.setNumber(2, "LcMin", plate_height/3)
gmsh.model.mesh.field.setNumber(2, "LcMax", plate_height*6)
gmsh.model.mesh.field.setNumber(2, "DistMin", plate_height*4)
gmsh.model.mesh.field.setNumber(2, "DistMax", plate_height*10)
gmsh.model.mesh.field.add("Min", 5)
gmsh.model.mesh.field.setNumbers(5, "FieldsList", [2])
gmsh.model.mesh.field.setAsBackgroundMesh(5)
# Generate mesh
gmsh.option.setNumber("Mesh.Algorithm", 8)
gmsh.model.mesh.setOrder(2)
gmsh.write("capacitor.msh")
# Read mesh
mesh_obj, cell_tags,facet_tags = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=2)
gmsh.finalize()
with XDMFFile(MPI.COMM_WORLD, "mt.xdmf", "w") as xdmf:
xdmf.write_mesh(mesh_obj)
xdmf.write_meshtags(cell_tags, mesh_obj.geometry)
I was able to create mesh. But not able to apply dirichletbc
# Create function space (using 2nd order elements for better accuracy)
V = fem.functionspace(mesh_obj, ("CG", 1))
upper_plate_dofs = fem.locate_dofs_topological(V, gdim, cell_tags.find(1))
lower_plate_dofs = fem.locate_dofs_topological(V, gdim, cell_tage.find(2))
bc_upper = fem.dirichletbc(PETSc.ScalarType(V0), upper_plate_dofs, V)
bc_lower = fem.dirichletbc(PETSc.ScalarType(-V0), lower_plate_dofs, V)
The mesh generation is quite involved, so I didn’t look through all details.
Still, your definition of boundary conditions is certainly wrong. You need to tag entities of dimension gdim - 1 to apply boundary conditions on them.
