ISLocalToGlobalMappingApply Error
I am using the mixed-dimensional branch and I’m building up on the problem I had earlier.
My the code appears to work well when I use MeshView to create a mesh that is on the edge of the source mesh. But as soon as I try to move away from it sharing 3 edges, which I need to do for my code, then it seems fail.
I have attached my code and the output error. Any help would be greatly appreciated.
from typing import List, Tuple
set_log_level(LogLevel.TRACE)
# Width of total domain
width = 1.0
# Height of total domain
height = 1.0
# Total resolution
resolution = 20
f = Constant(10)
a_top = 1
b_top = 1
def newton_solver_parameters():
    return{"nonlinear_solver": "newton",
           "newton_solver": {"linear_solver": "gmres"}}
def plott(x, title):
    plt.figure()
    im = plot(x)
    ax = plt.gca()
    cbar = ax.figure.colorbar(im, ax=ax)
    cbar.ax.set_ylabel("", rotation=-90, va="bottom")
    plt.title(title)
# Define SubDomain equations
class BottomSubDomain(SubDomain):
        return between(x[1], (0, 0.5))
class MiddleSubDomain(SubDomain):
        return between(x[1], (0.25, 0.75))
# Define Boundary equations
class ThreeQuartersBoundary(SubDomain):
        return near(x[1], 0.75)
class MiddleBoundary(SubDomain):
        return near(x[1], 0.5)
class TopBoundary(SubDomain):
        return near(x[1], 1.0)
def run_problem_with(mesh_full: Mesh, mesh_mid: Mesh, domains: MeshFunction,
                     boundaries_full: MeshFunction, boundaries_sub: MeshFunction):
    plott(domains, 'domains')
    # Create the function spaces
    W_a = FunctionSpace(mesh_full, "Lagrange", 1)
    W_b = FunctionSpace(mesh_mid, "Lagrange", 1)
    W = MixedFunctionSpace(W_a, W_b)
    # Define boundary conditions
    bcs = [DirichletBC(W.sub_space(0), a_top, boundaries_full, 1),
           DirichletBC(W.sub_space(1), b_top, boundaries_sub, 1),
    u = Function(W)
    ua, ub = u.sub(0), u.sub(1)
    va, vb = TestFunctions(W)
    ua_0 = 1.0
    ub_0 = 1.0
    ua.vector()[:] = ua_0
    ub.vector()[:] = ub_0
    dxa = Measure("dx", domain=mesh_full, subdomain_data=domains)
    dxb = Measure("dx", domain=mesh_mid)
    F_a = inner(nabla_grad(ua), nabla_grad(va)) * dxa
    F_b = inner(nabla_grad(ub), nabla_grad(vb)) * dxb - f * vb * dxb
    # This one works for both
    # F_a_couple = - f * va * dxa
    # This one does not work when the b domain is in the middle
    F_a_couple = - f * va * dxa(0) - ub * va * dxa(1)
    F = F_a + F_b + F_a_couple
    solve(F == 0, u, bcs, solver_parameters=newton_solver_parameters())
    plott(ua, "ua")
    plott(ub, "ub")
def create_subdomain(mesh_full: Mesh, sub_domain: SubDomain, top_boundary: SubDomain) -> Tuple[Mesh, MeshFunction, MeshFunction]:
    # Define domains
    domains = MeshFunction("size_t", mesh_full, 2)
    domains.set_all(0)
    # Mark area for sub domain
    sub_domain.mark(domains, 1)
    # Create mesh for the sub domain
    mesh_sub = MeshView.create(domains, 1)
    # Create boundary function for sub domain
    boundaries_sub = MeshFunction("size_t", mesh_sub, 1)
    boundaries_sub.set_all(0)
    top_boundary.mark(boundaries_sub, 1)
    return mesh_sub, boundaries_sub, domains
# Define full mesh
mesh_full = RectangleMesh(Point(0, 0),
                          Point(width, height),
                          resolution,
                          resolution)
# Define boundaries on full mesh
boundaries_full = MeshFunction("size_t", mesh_full, 1)
boundaries_full.set_all(0)
top_boundary = TopBoundary()
top_boundary.mark(boundaries_full, 1)
# Run the problem with the coupled domain in the middle of the full mesh
mesh_bot, boundaries_bot, domains_bot = create_subdomain(mesh_full, BottomSubDomain(), MiddleBoundary())
run_problem_with(mesh_full, mesh_bot, domains_bot, boundaries_full, boundaries_bot)
mesh_mid, boundaries_mid, domains_mid = create_subdomain(mesh_full, MiddleSubDomain(), ThreeQuartersBoundary())
run_problem_with(mesh_full, mesh_mid, domains_mid, boundaries_full, boundaries_mid)
Based on the error message it doesn’t seem to like the local index, though I have no idea why.
Error Message
PetscDolfinErrorHandler: line ‘723’, function ‘ISLocalToGlobalMappingApply’, file ‘/build/petsc-Y5jkE2/petsc-3.10.5+dfsg1/src/vec/is/utils/isltog.c’,
: error code ‘63’ (Argument out of range), message follows:
Local index 48437696 too large 230 (max) at 0
PetscDolfinErrorHandler: line ‘2151’, function ‘MatSetValuesLocal’, file ‘/build/petsc-Y5jkE2/petsc-3.10.5+dfsg1/src/mat/interface/matrix.c’,
PETSc error in ‘/home/alex/fenics-md/dolfin/dolfin/la/PETScMatrix.cpp’, ‘MatSetValuesLocal’
PETSc error code ‘63’ (Argument out of range), message follows:
Elapsed wall, usr, sys time: 0.000238802, 0, 0 (Assemble cells)
File “/home/alex/.local/lib/python3.7/site-packages/IPython/core/interactiveshell.py”, line 3325, in run_code
exec(code_obj, self.user_global_ns, self.user_ns)
File “”, line 1, in
runfile(’/home/alex/Dropbox/Programming/Python/Multi Domain/stackTest.py’, wdir=’/home/alex/Dropbox/Programming/Python/Multi Domain’)
File “/home/alex/Pycharm/helpers/pydev/_pydev_bundle/pydev_umd.py”, line 197, in runfile
pydev_imports.execfile(filename, global_vars, local_vars) # execute the script
File “/home/alex/Pycharm/helpers/pydev/_pydev_imps/_pydev_execfile.py”, line 18, in execfile
exec(compile(contents+"\n", file, ‘exec’), glob, loc)
File “/home/alex/Dropbox/Programming/Python/Multi Domain/stackTest.py”, line 143, in
File “/home/alex/Dropbox/Programming/Python/Multi Domain/stackTest.py”, line 99, in run_problem_with
File “/home/alex/.local/lib/python3.7/site-packages/dolfin/fem/solving.py”, line 233, in solve
File “/home/alex/.local/lib/python3.7/site-packages/dolfin/fem/solving.py”, line 298, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to successfully call PETSc function ‘MatSetValuesLocal’.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside /home/alex/fenics-md/dolfin/dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** Git changeset: cca9a4d76bbd15801aaf965ac110d13d1fafa3c2
Hi Alex,
Thanks for your feedback on the mixed-dimensional branch.
I ran your MWE and was able to reproduce the error you got.
As mentioned in your comment, the problem comes from the coupling term :
The form is decomposed depending on the matrix block they belong to, and the assembler iterates overs the entities defined by the given Measure.
In the subform -ub*va*dxa(1), we iterate over the cells of the parent mesh.
Since ub is defined on a submesh, the assembler uses the mapping built by MeshView to get the appropriate cell index. But there are cells in mesh_full that are not in mesh_mid, for which it cannot find the index in the mapping (the subdomain_data argument is not used at that point).
That’s why you get an “Out of range” error.
We assume that the integration mesh embedded in the Measure is the “smallest” one.
In your example, dxa(1) is equivalent to dxb (since mesh_mid is built from the cells marked with 1), but the assembler will iterate only over the submesh cells.
Then, using
F_a_couple = - f * va * dxa(0) - ub * va * dxb
should fix your problem.
