I am unsure whether this is a bug or I have a mistake. Consider this MWE:
from dolfinx import fem, mesh
def main():
els_side = 4
domain = mesh.create_unit_square(MPI.COMM_WORLD, els_side, els_side)
V = fem.functionspace(domain, ("Lagrange", 1),)
DG0 = fem.functionspace(domain, ("Discontinuous Lagrange", 0))
solution = fem.Function(V)
dg0_func = True
ufl_derivative = True
if dg0_func:
conductivity = fem.Function(DG0)
conductivity.x.array[:] = 1.0
conductivity = fem.Constant(domain, 1.0)
dx = ufl.dx
if ufl_derivative:
a_ufl = conductivity * ufl.dot(ufl.grad(solution), ufl.grad(v)) * dx
form = ufl.derivative(a_ufl, solution)
u = ufl.TrialFunction(V)
form = conductivity * ufl.dot(ufl.grad(u), ufl.grad(v)) * dx
j_compiled = fem.compile_form(
domain.comm, form, form_compiler_options={"scalar_type": np.float64})
coefficient_map = {}
for coeff in form.coefficients():
coefficient_map[coeff] = coeff
constant_map = {}
for const in form.constants():
constant_map[const] = const
j_instance = fem.create_form(j_compiled,
[V, V],
msh=domain,
subdomains={},
coefficient_map = coefficient_map,
constant_map = constant_map)
A = fem.assemble_matrix(j_instance)
print(A.data)
if __name__=="__main__":
main()
When using ufl.derivative together with a DG0 function in the form, the matrix assembled from compiling and creating the bilinear form in two steps is wrong. Here I expect to see a stiffness matrix but I obtain a null matrix.
In this MWE, both the flags ufl_derivative and dg0_func are set to True. If either of them is False, I obtain the expected stiffness matrix. Moreover, if both of them are True, the coefficient_map argument of create_form doesn’t even need the conductivity to run, when it normally complains about missing constants or coefficients.
