Based on the tutorial case for a linear elasticity problem: Implementation — FEniCSx tutorial
the demo is modified a little, that is, ignore the body force f, and add a x-direction force on the outside face (x[0] == 1).
The computation is done well, however, when I tried to compute the boundary force back from the displacement field for validation, the force i got is much smaller, why? What’s wrong with my code? Thanks in advance for any help!
the code is listed below:
- this part is the same as the tutorial demo, until setting L
import dolfinx as dfx
# Scaled variable
import pyvista
from dolfinx import mesh, fem, plot, io, default_scalar_type
L = 1
W = 0.2
mu = 1
rho = 1
delta = W / L
gamma = 0.4 * delta**2
beta = 1.25
lambda_ = beta
g = gamma
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
[20, 6, 6], cell_type=mesh.CellType.hexahedron)
def clamped_boundary(x):
return np.isclose(x[0], 0)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
u = ufl.TrialFunction(V)
f = fem.Constant(domain, default_scalar_type((0, 0, -rho * g)))
- this part is my custom code for solving
def traction_boundary(x):
return np.isclose(x[0], 1)
fdim = 2
boundary_facets_load = dfx.mesh.locate_entities_boundary(domain, fdim, traction_boundary)
Tface = fem.Constant(domain, default_scalar_type((-0.013, 0, 0)))
facet_marker = dfx.mesh.meshtags(domain, fdim, boundary_facets_load, 1)
ds2 = ufl.Measure("ds", domain=domain, subdomain_data=facet_marker)
L = ufl.dot(Tface, v) * ds2
uh = problem.solve()
- Then re-compute boundary force
V2 = fem.functionspace(domain, ("CG", 1, (domain.geometry.dim, domain.geometry.dim)))
sigma_expr = sigma(uh)
expr_sigma = fem.Expression(sigma_expr, V2.element.interpolation_points())
sigma_u = fem.Function(V2)
sigma_u.interpolate(expr_sigma)
n = ufl.FacetNormal(domain)
t = ufl.dot(sigma_u, n)
force_x_expr = t[0] * ds2(1)
total_force_x = fem.assemble_scalar(fem.form(force_x_expr))
total_force_x
>>> -0.0006366250943262476
However, I set the Tface as (-0.013, 0, 0), but I got the total_force_x of -0.0006366. Anything wrong with my code for computing force from uh?
