Issue with Facet/Cell tag
Hello everyone,
Greetings of the day.
I am using Dolfinx 0.7.1 and was trying to get calculated values on nodes represented by the facet tags.
I read the Gmsh mesh (which is a sqr as attached in .geo file) as below-
domain, cell_markers, facet_markers = gmshio.read_from_msh("try_sqr.msh", mesh_comm, gmsh_model_rank =2 , gdim=1)
Now as per my understanding, facet_markers should consider the tags and the corresponding nodal indices.
When I print the indices
facet_markers.indices
I get
array([ 0,  2,  5, 10, 18, 22, 28, 36, 44, 46, 62, 63, 64, 65, 69, 70],
      dtype=int32)
In the mesh, I have only 30 nodes. So I do not understand why it gives indices which are treater than number of nodes.
The way I plan to get the nodal values of the boundaries is-
u_surface = uh.x.array[ct.find(3)]
where uh is my calculated solution and boundary with tag 3 is where I am interested. Is this the correct way? Or there is a better way
When I do this at present, since node indices are above the actual, I get the out-of-bound error (which is obvious) since the maximum index for the solution is the number of nodes.
Looking forward to your kind support.
The .geo file-
lc = 0.25 ;
Point(1) = {0 , 0, 0, lc};
Point(2) = {1 , 0, 0, lc};
Point(3) = {1 , 1, 0, lc};
Point(4) = {0 , 1, 0, lc};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 1};
Curve Loop(1) = {1, 2, 3, 4};
Plane Surface(1) = {1};
Physical Curve("bottom") = {1};
Physical Curve("right") = {2};
Physical Curve("top") = {3};
Physical Curve("left") = {4};
Physical Surface("Copper") = {1};
You are actually meshing a 2D mesh here, so why are you sending in gdim=1?
Extremely sorry, that happened to be a typo when I was coping the stuff. Its 2 , I checked my code.
This is the actual
domain, cell_markers, facet_markers = gmshio.read_from_msh("try_sqr.msh", mesh_comm, gmsh_model_rank, gdim=2)
If your mesh is 2D, then the facets are line segments, not mesh nodes.
Ok, I understand now. That makes it clear why my boundary condition is working fine, but I am not able to get the nodal values using the same approach.
So how can I get the nodal values and coordinates for a particular facet tag? I tried using -
facet_geo = dolfinx.mesh.locate_entities(domain, domain.topology.dim -1, marker)
to get the nodal data, but I am not able to specify the marker properly. Should the marker be the tag number, like marker=3, or something like that?
Use entities_to_geometry, i.e.
    indices = dolfinx.cpp.mesh.entities_to_geometry(domain._cpp_object, mesh.topology.dim-1,
                   facet_markers.find(marker), False)
    cell_vertices = domain.geometry.x[indices]
    print(cell_vertices)
ref: https://github.com/search?q=repo%3AFEniCS%2Fdolfinx%20entities_to_geometry&type=code
and various other discourse posts (search for entities_to_geometry)
Thank you very much for your guidance.
