Issue with restarting transient simulation with more than one field
Dear Fenicsx community,
I am facing an issue when solving coupled time dependent PDEs. I have a code that tries to save, after each successful time step, the fields using adios4dolfinx.
However, when I try to restart a simulation by reading the field saved as initial data, the values of the next iteration appear to be shuffled.
I attach this MWE. I am sorry for its length, but I have tried shorter examples that do not capture my problem (i.e. only one time step, or only one PDE). I am using fenicsx 0.9.0.
We want to solve two coupled PDEs, let say a diffusion problem for a velocity field u and the transport of a scalar field \varphi by u. I use Crank-Nicolson for both PDEs (note that I do not know if this is an appropriate method, this is just for the MWE and to keep it simple):
\int_{\Omega} \frac{u^{n+1}-u^n}{\tau}\cdot v + \int_\Omega \nabla \left (\frac{u^n + u^{n+1}}{2}\right ):\nabla v = \int_\Omega\frac{f^n + f^{n+1}}{2}\cdot v,
\int_\Omega \frac{\varphi^{n+1}-\varphi^n}{\tau}\psi+\frac12\int_\Omega (u^n\cdot\nabla \varphi^n)\psi + \frac12\int_\Omega (u^{n+1}\cdot\nabla \varphi^{n+1})\psi=0.
The code solves for 10 time steps, stops, and then try to restart for 10 other time step. Somehow, the functions are read back properly, but the first step after restart ‘shuffle’ the values. I have pictures of the fields at steps n=10 and n=11 that shows the issue.
### Import modules ###
import adios4dolfinx
import basix
from functools import partial
from dolfinx.io import gmshio
from dolfinx import fem, mesh
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
import os
import h5py
from pathlib import Path
### A few classes ###
class Solver:
    def __init__(self, domain, dt, f):
        self.domain = domain
        self.f = f
        self.Vu = fem.functionspace(domain, ('CG', 1, (2,)))
        self.u_n = fem.Function(self.Vu)
        self.uh = fem.Function(self.Vu)
        self.f_n = fem.Function(self.Vu)
        self.fh = fem.Function(self.Vu)
        self.u = ufl.TrialFunction(self.Vu)
        self.v = ufl.TestFunction(self.Vu)
        self.Vphi = fem.functionspace(domain, ('CG', 1))
        self.phi_n = fem.Function(self.Vphi)
        self.phih = fem.Function(self.Vphi)
        self.phi = ufl.TrialFunction(self.Vphi)
        self.psi = ufl.TestFunction(self.Vphi)
        self.dt_cste = fem.Constant(domain, PETSc.ScalarType(dt))
        F_u = (ufl.dot((self.u - self.u_n) / self.dt_cste, self.v) + ufl.inner(ufl.grad((self.u + self.u_n)/2), ufl.grad(self.v)) + ufl.dot((self.f_n + self.fh)/2, self.v)) * ufl.dx
        F_phi = ((self.phi - self.phi_n) / self.dt_cste + 0.5 * ufl.dot(self.u_n, ufl.grad(self.phi_n)) + 0.5 * ufl.dot(self.uh, ufl.grad(self.phi))) * self.psi * ufl.dx
        self.a_u = ufl.lhs(F_u)
        self.L_u = ufl.rhs(F_u)
        self.bilinear_form_u = fem.form(self.a_u)
        self.linear_form_u = fem.form(self.L_u)
        self.a_phi = ufl.lhs(F_phi)
        self.L_phi = ufl.rhs(F_phi)
        self.bilinear_form_phi = fem.form(self.a_phi)
        self.linear_form_phi = fem.form(self.L_phi)
        self.bc_u = None # To update using set_bc_u
        self.A_u = None # Create using assemble_u
        self.rhs_u = None # Create using create_rhs_u
        self.solver_u = None # Create using setup_solver_u
        self.bc_phi = None # To update using set_bc_phi
        self.A_phi = None # Create using assemble_phi
        self.rhs_phi = None # Create using create_rhs_phi
        self.solver_phi = None # Create using setup_solver_phi
    def set_bc_u(self, g):
        A function to create the bcs from g.
        uD = fem.Function(self.Vu)
        uD.interpolate(g)
        tdim = self.domain.topology.dim
        fdim = tdim - 1
        self.domain.topology.create_connectivity(fdim, tdim)
        boundary_facets = mesh.exterior_facet_indices(self.domain.topology)
        boundary_dofs = fem.locate_dofs_topological(self.Vu, fdim, boundary_facets)
        self.bc_u = fem.dirichletbc(uD, boundary_dofs)
        return self.bc_u
    def set_bc_phi(self):
        We choose a MWE with no inflow
        pass
    def assemble_A_u(self):
        Assemble stiffness matrix.
        if not self.bc_u:
            raise ValueError('Boundary conditions must be set using self.set_bc_u before assembling A_u')
        self.A_u = assemble_matrix(self.bilinear_form_u, bcs=[self.bc_u])
        self.A_u.assemble()
        return self.A_u
    def assemble_A_phi(self):
        self.A_phi = assemble_matrix(self.bilinear_form_phi)
        self.A_phi.assemble()
        return self.A_phi
    def create_rhs_u(self):
        Create right hand side vector
        self.rhs_u = create_vector(self.linear_form_u)
        return self.rhs_u
    def create_rhs_phi(self):
        self.rhs_phi = create_vector(self.linear_form_phi)
        return self.rhs_phi
    def update_rhs_u(self, t2, t3):
        Update the right hand side
        self.f_n.interpolate(partial(self.f, t=t2)) # Update source term
        self.fh.interpolate(partial(self.f, t=t3)) # Update source term
        with self.rhs_u.localForm() as loc_b:
            loc_b.set(0)
        assemble_vector(self.rhs_u, self.linear_form_u)
        apply_lifting(self.rhs_u, [self.bilinear_form_u], [[self.bc_u]])
        self.rhs_u.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
        set_bc(self.rhs_u, [self.bc_u])
        return self.rhs_u
    def update_rhs_phi(self):
        with self.rhs_phi.localForm() as loc_rhs_phi:
            loc_rhs_phi.set(0)
        assemble_vector(self.rhs_phi, self.linear_form_phi)
        self.rhs_phi.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
        return self.rhs_phi
    def setup_solver_u(self):
        Setup the solver for the linear problem
        self.solver_u = PETSc.KSP().create(self.domain.comm)
        self.solver_u.setOperators(self.A_u)
        self.solver_u.setType(PETSc.KSP.Type.PREONLY)
        self.solver_u.getPC().setType(PETSc.PC.Type.LU)
        return self.solver_u
    def setup_solver_phi(self):
        self.solver_phi = PETSc.KSP().create(self.domain.comm)
        self.solver_phi.setOperators(self.A_phi)
        self.solver_phi.setType(PETSc.KSP.Type.PREONLY)
        self.solver_phi.getPC().setType(PETSc.PC.Type.LU)
        return self.solver_phi
### Initialize, save and restart functions ###
def initialize(dir : str, dt : float):
    os.makedirs(dir)
    # Create the h5 file (contains the time) #
    file_h5 = dir + '/info.h5'
    with h5py.File(file_h5, 'w') as h5f:
        mock_data = np.zeros(1)
        h5f.create_dataset('t', data=mock_data, maxshape=(None,), dtype='float64') # Time stamps
    # Create the mesh from a disk #
    gmsh.model.add("disk")
    disk = gmsh.model.occ.addDisk(0.0, 0.0, 0.0, 1.0, 1.0)
    gmsh.model.occ.synchronize()
    gmsh.model.addPhysicalGroup(2, [disk], tag=1)
    gmsh.model.setPhysicalName(2, 1, "DiskSurface")
    gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 0.05)
    gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.05)
    gmsh.model.mesh.generate(2)
    mesh_data = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=2)
    gmsh.finalize()
    domain = mesh_data[0]
    # Initialize the solver #
    f = lambda x, t : (5*x[1] * np.sin(t), -5*x[0] * np.sin(t))
    solver = Solver(domain, dt, f)
    # Interpolate intial condition #
    u0 = lambda x : (-5*x[1], 5*x[0])
    phi0 = lambda x : np.exp(- ((x[0] - 0.5)**2 + (x[1] - 0)**2) / 0.2**2)
    solver.u_n.interpolate(u0)
    solver.phi_n.interpolate(phi0)
    # Assemble forms #
    g = lambda x : (0*x[0], 0*x[0])
    solver.set_bc_u(g)
    solver.assemble_A_u()
    solver.assemble_A_phi()
    solver.create_rhs_u()
    solver.create_rhs_phi()
    solver.setup_solver_u()
    solver.setup_solver_phi()
    # Useful values #
    solver.t = 0 # Time of the initial condition
    solver.n = 0 # Current time step
    return solver
def restart(dir : str, T : float):
    # Read the times #
    with h5py.File(file_h5, 'r') as f:
        times = f['t'][:]
    # Check if finished #
    if float(times[-1]) >= T or np.isclose(times[-1], T):
        print('Simulation is already finished, skipping!')
        return None
    dt = times[-1] - times[-2]
    N = len(times)
    # Read last solution #
    u = read_field(dir, 'u', N-1)
    phi = read_field(dir, 'phi', N-1)
    solver = Solver(u.function_space.mesh, dt, f)
    solver.u_n.x.array[:] = u.x.array # Set u_n to last known value of u
    solver.phi_n.x.array[:] = phi.x.array
    # Assemble forms #
    solver.set_bc_u(g)
    # Useful values #
    solver.t = times[-1]
    solver.n = N-1
    return solver
def save(dir : str, solver : Solver):
    with h5py.File(file_h5, 'a') as h5f: # open the file on which to save the data
        dataset = h5f['t']
        dataset.resize((len(dataset) + 1,))
        dataset[-1] = solver.t
    # Save fields #
    path = Path(dir)
    adios4dolfinx.write_function(path, solver.uh, time=solver.n, name='u')
    adios4dolfinx.write_function(path, solver.phih, time=solver.n, name='phi')
def read_field(dir : str, name : str, n : int):
    filename = Path(dir)
    domain = adios4dolfinx.read_mesh(filename, comm=MPI.COMM_WORLD)
    V = fem.functionspace(domain, ('CG', 1)) if name=='phi' else fem.functionspace(domain, ('CG', 1, (2,)))
    func = fem.Function(V)
    adios4dolfinx.read_function(filename, func, time=n, name=name)
    return func
### Solve the PDE ###
def solve(T : float, dt : float, dir : str):
    Solve the heat equation
    Input :
    - T : final time to reach
    - dt : time step
    - dir : directory in which to save the data
    if os.path.exists(dir):
        print('Directory already exists! Attempting a restart...')
        solver = restart(dir, T)
        if solver is None:
            return None
        solver = initialize(dir, dt)
        path = Path(dir)
        adios4dolfinx.write_mesh(path, solver.domain, engine="BP4")
        adios4dolfinx.write_function(path, solver.u_n, time=0, name="u")
        adios4dolfinx.write_function(path, solver.phi_n, time=0, name="phi")
    while solver.t < T and not np.isclose(solver.t, T):
        solver.update_rhs_u(solver.t, solver.t + dt)
        solver.solver_u.solve(solver.rhs_u, solver.uh.x.petsc_vec)
        solver.uh.x.scatter_forward()
        solver.update_rhs_phi()
        solver.solver_phi.solve(solver.rhs_phi, solver.phih.x.petsc_vec)
        solver.phih.x.scatter_forward()
        solver.t += dt
        solver.n += 1
        save(dir, solver)
        solver.u_n.x.array[:] = solver.uh.x.array
        solver.phi_n.x.array[:] = solver.phih.x.array
### Test the code ###
dir = 'MWE_restart-2-fields'
dt = 0.05
T = 0.5
solve(T, dt, dir)
T = 1
solve(T, dt, dir)
### Display solution ###
from matplotlib.tri import Triangulation as Triangulation_plt
from matplotlib.animation import FuncAnimation
cmap = 'viridis'
lw = 0.5
    times = f['t'][:]
total_time = 5000
N = len(times)
min_phih_array = np.zeros(N)
max_phih_array = np.zeros(N)
for n in range(N):
    phih = read_field(dir, 'phi', n)
    min_phih_array[n] = np.min(phih.x.array)
    max_phih_array[n] = np.max(phih.x.array)
min_phih = np.min(min_phih_array)
max_phih = np.max(max_phih_array)
fig, ax = plt.subplots(subplot_kw={"projection": "3d"})
phi0 = read_field(dir, 'phi', 0)
domain = phi0.function_space.mesh
tri_plt = Triangulation_plt(domain.geometry.x[:, 0], domain.geometry.x[:, 1], domain.topology.connectivity(domain.topology.dim, 0).array.reshape((-1, 3)))
ax.set_xlim(-1, 1)
ax.set_ylim(-1, 1)
ax.set_zlim(min_phih, max_phih)
# ax.set_aspect('equal')
ax.plot_trisurf(tri_plt, phi0.x.array, cmap=cmap, edgecolor='none', vmin=min_phih, vmax=max_phih)
def update(i):
    ax.clear()
    phi = read_field(dir, 'phi', i)
    domain = phi.function_space.mesh
    ax.plot_trisurf(tri_plt, phi.x.array, cmap=cmap, edgecolor='none', vmin=min_phih, vmax=max_phih)
    ax.set_title(f't = {times[i]:.4f}')
    ax.set_xlabel('x')
    ax.set_ylabel('y')
anim = FuncAnimation(fig, update, frames=len(times), interval=total_time/len(times))
In my attempts to find the issue I have tried (I can provide MWE)
  • Restart for the diffusion problem with only one field : this works well.
  • Just one step of transport problem where the velocity field is read with adios4dolfinx : this works well.
Do you have any idea of what is going wrong when restarting? The reading of the function is fine, I have checked that, but solving a linear system built from the functions goes wrong.
Is it my read_field function which is not suited for this problem?
Thank you very much for your help,
Théophile
