I’m installing Fenics from source on macOS Sonoma with an Intel Chip. We’re starting a project based on FEniCS.jl wrapper, which is why I require the legacy version.
I’ve tried installing from the Docker container without success following the instruction from the guide I get:
Unable to find image 'quay.io/fenicsproject/stable:current' locally
current: Pulling from fenicsproject/stable
docker: [DEPRECATION NOTICE] Docker Image Format v1 and Docker Image manifest version 2, schema 1 support is disabled by default and will be removed in an upcoming release. Suggest the author of quay.io/fenicsproject/stable:current to upgrade the image to the OCI Format or Docker Image manifest v2, schema 2. More information at https://docs.docker.com/go/deprecated-image-specs/.
See 'docker run --help'.
I’ve also tried using docker using this image. The container immediately crashes.
I’ve decided to build directly from source, and I’m able to install fenics-ffc.
import ffc
print(ffc.__version__)
2019.1.0.post0
I clone the corresponding dolphin version and doing cmake .. throws error messages when creating the demo files.
-- Generating form files in demo, test and bench directories. May take some time...
CMake Error at CMakeLists.txt:626 (message):
Generation of form files failed:
Compiling 1 forms in demo/undocumented/multimesh-stokes/cpp...
ffc -l dolfin -s -O -r auto MultiMeshStokes.ufl
AttributeError: module 'numpy' has no attribute 'product'
-- Configuring incomplete, errors occurred!
I’m not sure what version of numpy to specify in my venv or what other flags should I indicate when calling cmake
I appreciate any guidance!
