Issues with integration on interior boundary (dS)
I’ve been working on this problem where I have a PDE on an interface and I’m using dS in FEniCS for integration. But, the results are kind of off.
What’s interesting is that when I switch the PDE to be on the boundary and use ds instead, everything works fine. This makes me think there’s something up with the way I’m using dS.
Here is what i have done,
My mesh file is in .h5 format that is readable by dolfin fenics. "
mesh = Mesh()
h5_file = "/path_to_file/mesh_file.h5"
hdf = HDF5File(mesh.mpi_comm(), h5_file, "r")
hdf.read(mesh, "/mesh", False)
# define mesh parameters
nsd = mesh.topology().dim()
# read mesh functions
boundaries = MeshFunction("size_t", mesh, nsd - 1)
ds = ds(metadata={'quadrature_degree': 2}, subdomain_data=boundaries)
dS = dS(metadata={'quadrature_degree': 2}, subdomain_data=boundaries)
hdf.read(boundaries, "/boundaries")
domains = MeshFunction("size_t", mesh, nsd)
dx = dx(metadata={'quadrature_degree': 2}, subdomain_data=domains)
hdf.read(domains, "/domains")
Then i have my weak form as,
res_s = res_s + inner(P,grad(v)("+"))*dS(FLAG_INTERFACE) This weak form gave me bad results.
(All the discontinuous parameters required for defining P are restricted appropriately.)
I am not describing my entire problem as that would complicate my issue.
When i try res_s = res_s + inner(P,grad(v)("+"))*ds(FLAG_EXTERNAL_BOUNDARY) I get expected results.
Am I doing anything wrong with dS? My mesh looks good and all the boundaries are correctly tagged. (i tried with multiple other meshes as well).
See: Integrating over an interior surface - #4 by MiroK
and for any further questions please make a minimal reproducible example.
Thank you very much @dokken
However, I have one question, when i add the extra term Constant(0)*dx, i get an error saying,
This integral is missing an integration domain.
    L2 = dot(grad(f)('-'), n('-'))*dS(10) + Constant(0)*dx
  File "/home/dputluru/.conda/envs/cent7/2020.11-py38/fenicsproject/lib/python3.12/site-packages/ufl/measure.py", line 441, in __rmul__
    error("This integral is missing an integration domain.")
  File "/home/dputluru/.conda/envs/cent7/2020.11-py38/fenicsproject/lib/python3.12/site-packages/ufl/log.py", line 172, in error
ufl.log.UFLException: This integral is missing an integration domain.
No clue why it occured.
I used to define my dx as,
Now when i add
dx = Measure('dx', domain=mesh, subdomain_data=domains), it runs fine with sensible results.
Here is minimal working code if required,
mesh = Mesh()
h5_file = "dS_mesh.h5"
I = Identity(nsd)
h = CellDiameter(mesh)
x_i = SpatialCoordinate(mesh)
# start ----- new lines that made it work
dS = Measure('dS', domain=mesh, subdomain_data=boundaries, subdomain_id=10)
# end ----- new lines that made it work
# output paraview file for domains
output_file = File("domains.pvd")
output_file << domains
# Make up something with discontinuous gradient
# Define the level set function for the sphere (x^2 + y^2 + z^2 - 25 = 0)
class SphereLevelSet(UserExpression):
    def eval(self, value, x):
        r_sqr = x[0]**2 + x[1]**2 + x[2]**2
        value[0] = r_sqr - 25
    def value_shape(self):
        return ()
# Create the level set function
phi = SphereLevelSet(degree=1)
# Define the expression with different values inside and outside the sphere
class MyExpression(UserExpression):
    def __init__(self, level_set, **kwargs):
        super().__init__(**kwargs)
        self.level_set = level_set
        if self.level_set(x) <= 0:  # Inside the sphere
            value[0] = 0
        else:  # Outside the sphere
            # Linear increase proportional to the distance from the sphere's surface
            distance_from_surface = np.sqrt(self.level_set(x) + 25) - 5
            value[0] = distance_from_surface
        return ()
# Create and interpolate the expression
my_expression = MyExpression(phi, degree=1)
f = interpolate(my_expression, V)
# +, - sides are by default assigned arbitrarily so assembling below
# will not yield meaningful result
L0 = dot(grad(f)('+'), n('+'))*dS
print(assemble(L0))
L1 = dot(grad(f)('-'), n('-'))*dS(10)
print(assemble(L1))
# Add dummy terms that will allow for controlling restrictions
# This is (0, 0) * (1, 0) * 2
print(assemble(L2))
# This is (1, 0) . (-1, 0) * 2
L3 = dot(grad(f)('+'), n('+'))*dS(10) + Constant(0)*dx
print(assemble(L3))
“I think the issue is with the way i import my mesh. Hence i cannot use mshr package.”
I am unable to upload the mesh file here :frowning:
Add domain=mesh in
