Iterative solver performance severely reduced using MixedElement
In anticipation of adding more equations I’m trying to make use of the MixedElement by default. For example with the ft06 linear elasticity tutorial I simply replace “V = VectorFunctionSpace(mesh, ‘P’, 1)” with
V1 = VectorElement('CG', mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, MixedElement([V1]))
this works, but when the mesh is much denser I notice that iterative solver performance is a magnitude worse (slower) than not using MixedElement, for example using
solve(a == L, u, bc, solver_parameters={"linear_solver": "cg", "preconditioner": "amg"})
It doesn’t seem that this should be the case (as the system to solve should be identical), but I’m possibly missing something fundamental here. Is there some way to still use MixedElement without potentially limiting iterative solver performance?
I would suggest moving to dolfinx, as the impact on solver performance on MixedElements have been reduced, as shown in the following minimal example:
import dolfinx.io
import time
def problem(Nx, Ny, Nz, vector_space:bool=True):
    # Scaled variables
    L = 1; W = 0.2
    mu = 1
    rho = 1
    delta = W/L
    gamma = 0.4*delta**2
    beta = 1.25
    lambda_ = beta
    g = gamma
    mesh = dolfinx.BoxMesh(MPI.COMM_WORLD, np.array([[0, 0, 0],[L, W, W]]), [Nx, Ny, Nz],
    dolfinx.mesh.CellType.tetrahedron)
    if vector_space:
        V = dolfinx.VectorFunctionSpace(mesh, ('P', 1))
        V1 = ufl.VectorElement('CG', mesh.ufl_cell(), 1)
        V = dolfinx.FunctionSpace(mesh, ufl.MixedElement([V1]))
    # Define boundary condition
    def clamped_boundary(x):
        return np.isclose(x[0], 0)
    if V.num_sub_spaces() == 1:
        V0 = V.sub(0).collapse()
        u_bc = dolfinx.Function(V0)
        u_bc.x.array[:] = 0
        clamped_dofs = dolfinx.fem.locate_dofs_geometrical((V.sub(0),V0), clamped_boundary)
        bc = dolfinx.DirichletBC(u_bc, clamped_dofs, V.sub(0))
        clamped_dofs = dolfinx.fem.locate_dofs_geometrical(V, clamped_boundary)
        u_bc = dolfinx.Function(V)
        u_bc.x.array[:] = 0
        bc = dolfinx.DirichletBC(u_bc, clamped_dofs)
    # Define strain and stress
        return 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
        #return sym(nabla_grad(u))
    def sigma(u):
        return lambda_*ufl.nabla_div(u)*ufl.Identity(d) + 2*mu*epsilon(u)
    u = ufl.TrialFunction(V)
    d = len(u)  # space dimension
    f = dolfinx.Constant(mesh, (0, 0, -rho*g))
    T = dolfinx.Constant(mesh, (0, 0, 0))
    a = ufl.inner(sigma(u), epsilon(v))*ufl.dx
    L = ufl.dot(f, v)*ufl.dx + ufl.dot(T, v)*ufl.ds
    problem = dolfinx.fem.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "cg", "pc_type": "gamg"})
    start =time.time()
    u = problem.solve()
    end = time.time()
    print(f"Vector: {vector_space}, {Nx}x{Ny}x{Nz}: Solve time: {end-start}")
    with dolfinx.io.XDMFFile(MPI.COMM_WORLD, f"u_{Nx}_{Ny}_{Nz}_{vector_space}.xdmf", "w") as xdmf:
        xdmf.write_mesh(mesh)
        if V.num_sub_spaces()==1:
            xdmf.write_function(u.sub(0))
            xdmf.write_function(u)
if __name__ == "__main__":
    Nxs = [10,20,40]
    Nys = [3,6,12]
    Nzs = [3,6,12]
    for Nx, Ny, Nz in zip(Nxs, Nys, Nzs):
       for vector in [True, False]:
           problem(Nx, Ny, Nz, vector)
yielding
Vector: True, 10x3x3: Solve time: 0.0059337615966796875
Vector: False, 10x3x3: Solve time: 0.008495569229125977
Vector: True, 20x6x6: Solve time: 0.05466961860656738
Vector: False, 20x6x6: Solve time: 0.06971216201782227
Vector: True, 40x12x12: Solve time: 0.5019056797027588
Vector: False, 40x12x12: Solve time: 0.5771362781524658
For more information about DOLFINx, you could have a look at my tutorial: The FEniCSx tutorial — FEniCSx tutorial
One should also distinguish between solver performance and the time it takes to assemble the left and right hand sides, and actually run the iterative solver.
