Hi dokken, the code is:
from dolfinx import mesh, fem, io, plot, default_scalar_type, log
import os
from tqdm import tqdm
import csv
import sys
lambda_ = 400889.871e6 ## unit is Pa
mu = 80.194e6
nu = lambda_/(2*(lambda_ + mu)) ## 3D domain
E = mu*(3*lambda_ + 2*mu)/(lambda_ + mu) ## 3D domain
### (1a) define the 3D domain
coords_lower_left = [0.0, 0.0, 0.0]
Lx, Ly, Lz = 1.0e-3, 1.0e-3, 1.0e-3
coords_upper_right = [Lx, Ly, Lz]
nx, ny, nz = 8, 8, 8
num_elements = [nx, ny, nz]
domain = mesh.create_box(MPI.COMM_WORLD, [coords_lower_left, coords_upper_right], num_elements, mesh.CellType.hexahedron)
### (1b) set element types
element_u = ufl.VectorElement("CG", domain.ufl_cell(), degree=2) ## vector: displacement
element_p= ufl.FiniteElement("CG", domain.ufl_cell(), degree=1) ## scalar: pressure
element_mix = ufl.MixedElement([element_u, element_p])
# element_mix = mixed_element([element_u, element_p], gdim=3)
V = fem.FunctionSpace(domain, element_mix)
V_disp = V.sub(0)
V_press = V.sub(1)
num_subs = V.element.num_sub_elements
spaces = []
maps = []
for i in range(num_subs):
space_i, map_i = V.sub(i).collapse()
spaces.append(space_i)
maps.append(map_i)
### displacement component in x, y, z direction
V_disp_x = V_disp.sub(0)
V_disp_y = V_disp.sub(1)
V_disp_z = V_disp.sub(2)
### define surface
def front(x):
return np.isclose(x[0], Lx, atol=1.0e-8)
def right(x):
return np.isclose(x[1], Ly, atol=1.0e-8) ## y=Ly
def bottom(x):
return np.isclose(x[2], 0, atol=1.0e-8) ## z=0
def top(x):
return np.isclose(x[2], Lz, atol=1.0e-8) ## z=Lz
### sub-domain surface where traction force is applied
def Omega_traction(x):
return np.logical_and(np.logical_and(x[0]>=0.5*Lx, x[1]>=0.5*Ly), np.isclose(x[2],Lz, atol=1e-8))
### constraint displacement component on surface
value_zero= fem.Constant(domain, 0.0)
### front: ux=0
facet_front = mesh.locate_entities_boundary(domain, fdim, front)
dofs_front_x = fem.locate_dofs_topological(V_disp_x, fdim, facet_front)
bc_front_x = fem.dirichletbc(value_zero, dofs_front_x, V_disp_x)
### right: uy=0
facet_right = mesh.locate_entities_boundary(domain, fdim, right)
dofs_right_y = fem.locate_dofs_topological(V_disp_y, fdim, facet_right)
bc_right_y = fem.dirichletbc(value_zero, dofs_right_y, V_disp_y)
### bottom: uz=0
facet_bottom = mesh.locate_entities_boundary(domain, fdim, bottom)
dofs_bottom_z = fem.locate_dofs_topological(V_disp_z, fdim, facet_bottom)
bc_bottom_z = fem.dirichletbc(value_zero, dofs_bottom_z, V_disp_z)
### top: ux=0 & uy=0
facet_top = mesh.locate_entities_boundary(domain, fdim, top)
dofs_top_x = fem.locate_dofs_topological(V_disp_x, fdim, facet_top)
dofs_top_y = fem.locate_dofs_topological(V_disp_y, fdim, facet_top)
bc_top_x = fem.dirichletbc(value_zero, dofs_top_x, V_disp_x)
bc_top_y = fem.dirichletbc(value_zero, dofs_top_y, V_disp_y)
bcs = [bc_front_x, bc_right_y, bc_bottom_z, bc_top_x, bc_top_y]
### 2.2 apply the traction force
traction = fem.Constant(domain, default_scalar_type((0.0, 0.0, 0.0)))
facet_indices_Omega = mesh.locate_entities_boundary(domain, fdim, Omega_traction)
tag_Omega = 5
facet_tag_Omega = mesh.meshtags(domain, fdim, facet_indices_Omega, tag_Omega)
### trail and test function
state = fem.Function(V)
u, p = ufl.split(state)
# u, p = ufl.TrialFunctions(V)
v, q = ufl.TestFunctions(V)
#### Kinematics
d = len(u)
I = ufl.variable(ufl.Identity(d))
F = ufl.variable(I + ufl.grad(u))
C = ufl.variable(F.T * F)
Ic = ufl.variable(ufl.tr(C))
J = ufl.variable(ufl.det(F)) ##
psi_dev = mu/2*(Ic - 3) - mu*ufl.ln(J)
psi_imp = p * ufl.ln(J) - (1/(2*lambda_))*p**2
psi = psi_dev + psi_imp
### test: apply the traction force on the top surface
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag_Omega, metadata=metadata)
PK1 = ufl.diff(psi, F)
a = ufl.inner(ufl.grad(v), PK1)*dx + q * (ufl.ln(J) - (1/lambda_)*p) * dx
L = ufl.dot(v, traction)* ds(tag_Omega)
R = a - L
problem = NonlinearProblem(R, state, bcs)
solver = NewtonSolver(domain.comm, problem)
### Set Newton solver options
solver.atol = 1e-6
solver.rtol = 1e-6
# log.set_log_level(log.LogLevel.INFO)
steps = 60
traction_final = -60e6
traction_interval = traction_final/steps
for n in tqdm(range(0, steps+1)):
traction.value[2] = n * traction_interval
num_its, converged = solver.solve(state)
assert (converged)
u_sol, p_sol = state.split()
u_sol.x.scatter_forward() #### update the solution
p_sol.x.scatter_forward()
state.x.scatter_forward()
