Lighthill Acoustic´s Analogy
Hi community! (Firstly, sorry for mi English) I´m new in Fenics, and I´m trying to simulate an aerodynamic noise (from a Known velocity field (w) previously calculated with NavierStokes), but I have a problem with the Lightill Tensor
Here my code:
mesh_NS = Mesh()
with XDMFFile("mesh_NS.xdmf") as infile:
    infile.read(mesh_NS)
mvc = MeshValueCollection("size_t", mesh_NS, 2)
with XDMFFile("mf_NS.xdmf") as infile:
mf_NS = cpp.mesh.MeshFunctionSizet(mesh_NS, mvc)
T =70   # final time
num_steps =8000  # number of time steps
c = 340         # undisturbed speed of sound (m/s)
rho = 1.20          # density
W = VectorFunctionSpace(mesh_NS,'P', 2)
p=TrialFunction(W)
v=TestFunction(W)
w=Function(W)
w_1,w_2=as_vector((w[0],w[1]))
w_11=inner(w_1,w_1)
w_12=inner(w_1,w_2)
w_22=inner(w_2,w_2)
def f(w):
    return as_vector([[rho*(w_11.dx(0)+w_12.dx(1))],[rho*(w_12.dx(0)+w_22.dx(1))]])
p_0=Function(W)
p_1=Function(W)
n=FacetNormal(mesh_NS)
k=Constant(dt)
c=Constant(c)
a=dot(p,v)*dx + c*c*k*k*inner(nabla_grad(p),nabla_grad(v))*dx
L=((2*p_1) - p_0 + c*c*k*k*inner(f(w),v))*dx
timeseries_w = TimeSeries('NS_SC_200/velocitySC_200_series')
# Time-stepping
t = 0
for n in range(num_steps):
    # Update current time
    timeseries_w.retrieve(w.vector(),t)
    # Compute solution
    solve(a == L, p, bcp)
    #Update previous solution
    p_0.assign(p_1)
    p_1.assign(p)
etc.
My problem is in the inner product(f(w),v), in relation with de shape of f(w) function. Here is my error:
 File "/.../anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/operators.py", line 169, in inner
    return Inner(a, b)
  File ".../anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/tensoralgebra.py", line 161, in __new__
    error("Shapes do not match: %s and %s." % (ufl_err_str(a), ufl_err_str(b)))
  File "/.../anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/log.py", line 172, in error
ufl.log.UFLException: Shapes do not match: <ListTensor id=140540322902224> and <Argument id=140540322720352>.
Please!!! Does anyone how to solve it??
Please format your code using 3x` encapsulation, to format it properly.
def f(x):
    return x
Many thanks for your prompt answer!
I don´t know if I understand what you are appointing
I tried to do it in this way:
def f(w_11,w_12,w_22):
But it results in the same error:
File “/–/Acustica_lighthill.py”, line 75, in
L=((2p_1) - p_0 + cckk*inner(f(w_11,w_12,w_22),v))*dx
File “–/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/operators.py”, line 169, in inner
return Inner(a, b)
File “/–/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/tensoralgebra.py”, line 161, in new
error(“Shapes do not match: %s and %s.” % (ufl_err_str(a), ufl_err_str(b)))
File “/–/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/log.py”, line 172, in error
ufl.log.UFLException: Shapes do not match: and .
I´m lost…
I mean that you should format your code in the post such that it is readable and copyable for others. Ive modified your post with the suggested changes.
Ups, I didn´t notice ¡¡Many thanks!!
I can’t run your code, but it looks like f() is 2D and v is possible 3d. It would explain your mismatched shape error.
I can’t remember the legacy dolfinx syntax to check, it’s something like print(mesh.geometry().dim())
Sorry! My mesh it´s really tedious :grinning:
and I can´t write such a long code
If it helps I could try to upload de .xdmf files.
And the data for w is stored in a .h5 file (0,75 GB)
return as_vector([[rho*(w_11.dx(0)+w_12.dx(1))],[rho*(w_12.dx(0)+w_22.dx(1))], [0]])
And I got the same error
:pensive:
Well, consider looking at f().ufl_shape and v.ufl_shape to make sure they are appropriate.
The way you’ve used ufl.as_vector is a little odd, consider the following:
In [1]: import ufl
In [2]: ufl.as_vector([[1], [2]]).ufl_shape
Out[2]: (2, 1)
In [3]: ufl.as_vector([1, 2]).ufl_shape
Out[3]: (2,)
which if you try to compute in an inner product throws a similar error:
In [4]: ufl.inner(ufl.as_vector([[1], [2]]), ufl.as_vector([1, 2]))
Shapes do not match: <ListTensor id=140128052927232> and <ListTensor id=140127900825984>.
UFLException                              Traceback (most recent call last)
<ipython-input-4-eaf5f6ad9ebb> in <module>
----> 1 ufl.inner(ufl.as_vector([[1], [2]]), ufl.as_vector([1, 2]))
Yes!! I´ve done what you said, and effectively, it was the problem in the inner product I changed the shape of f(), and now it seems that shapes match (both, f() and v, are(2,)).
     return as_vector(([rho*(w_11.dx(0)+w_12.dx(1)),rho*(w_12.dx(0)+w_22.dx(1))]))
But…the problem remains with the sum of the inner product and the error says:
Can’t add expressions with different shapes.
File “/–.py”, line 85, in
File “/–/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/exproperators.py”, line 212, in _add
return Sum(self, o)
File “/–/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/algebra.py”, line 53, in new
error(“Can’t add expressions with different shapes.”)
ufl.log.UFLException: Can’t add expressions with different shapes.
I checked the shapes, and I´m trying to sum shapes(2,) and ().
print(((2*p_1) - p_0).ufl_shape)
The answer is (2,)
print((c*c*k*k*inner(f(w_11,w_12,w_22),v)).ufl_shape)
The answer is ()
I don’t understand the general shape of your formulation and the RHS of your equation, since seems that f(w) is a vector. Lighhill’s analogy returns a scalar, through the double divergence of Lighthill Tensor. What you have is basically something that resembles a specific volume velocity distribution that is, indeed, a scalar.
What you should put in the wave equation has to be scalar and you should work always with scalar fields, derived from the vector fields.
I agree with you, I´m sure I need to work with scalars and I´m sure the error is in the variational formulation, but…
That´s the basis of my f() expression as the source term
Anyway, I think my mistake lies in the variational formulation because I didn´t apply the Green theorem in the integral of this term (f()). I´m trying to…
I´m very grateful for your help! Being able to solve this is very important to me.
oook , I’ve just noticed…and
imagen is not equal to
imagen
imagen =
imagen
So, I need to recalculate my FV.
Many many thanks!!
Sorry for my late response but yes, the mistake is that that is not a divergence but a double divergence, that makes the lightill tensor source a scalar field.
Anyway, my advise is to compute the source field inside the cfd code and import it in fenics, that solves the standard non-homogeneous wave Equation
You don´t have to apologize! I´m very grateful for all your responses. I resolved the problem with the variational formulation, but, what I was trying to do doesn´t work. I mean: I tried to import mi flux solution (w) and split its components (w_1, w_2) to compute the Lighthill tensor, but it seems that when you export a timeseries .h5 file, you don’t have access to the components of the vector of the flux field (in this case).
So, I took your advice and I included the computation of the Lighthill Tensor into the Navier Stokes code in fenics. But, I´m lost with the postprocesing.
Here it´s my code:
set_log_level(LogLevel.ERROR)
mesh_NS = Mesh()
# Set parameter values (air)
T =70   # final time
mu = 0.000018         # dynamic viscosity
# Define function spaces
V = VectorFunctionSpace(mesh_NS, 'P', 2)
Q = FunctionSpace(mesh_NS, 'P', 1)
#Boundaries
#Already defined in the mesh
#11:'aerogenerador'
#12:'fronteras superior e inferior'.
#13:'entrada flujo'
#14:'salida flujo'
p = TrialFunction(Q)
q = TestFunction(Q)
# Define functions for solutions at previous and current time steps
u_n = Function(V)
u_  = Function(V)
p_n = Function(Q)
p_  = Function(Q)
# Define boundary conditions
U_x=0.044
bcu_inflow = DirichletBC(V,  Constant((U_x, 0)),mf_NS, 13)
bcu_cylinder = DirichletBC(V, Constant((0, 0)),mf_NS, 11)
bcu_walls = DirichletBC(V.sub(1), Constant(0),mf_NS, 12) #symmetry conditions
bcp_outflow = DirichletBC(Q, Constant(0),mf_NS, 14)
bcu = [bcu_inflow,bcu_cylinder,bcu_walls]
bcp = [bcp_outflow]
U  = 0.5*(u_n + u)
n  = FacetNormal(mesh_NS)
f  = Constant((0, 0))
k  = Constant(dt)
mu = Constant(mu)
rho = Constant(rho)
# Define symmetric gradient
    return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
    return 2*mu*epsilon(u) - p*Identity(len(u))
# Define variational problem for step 1
F1 = rho*dot((u - u_n) / k, v)*dx \
   + rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx \
   + inner(sigma(U, p_n), epsilon(v))*dx \
   + dot(p_n*n, v)*ds - dot(mu*nabla_grad(U)*n, v)*ds \
   - dot(f, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q))*dx
L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/k)*div(u_)*q*dx
a3 = dot(u, v)*dx
L3 = dot(u_, v)*dx - k*dot(nabla_grad(p_ - p_n), v)*dx
# Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
# Apply boundary conditions to matrices
[bc.apply(A1) for bc in bcu]
[bc.apply(A2) for bc in bcp]
# Create XDMF files for visualization output
xdmffile_u = XDMFFile('NS_SC_200/velocitySC_200.xdmf')
xdmffile_p = XDMFFile('NS_SC_200/pressureSC_200.xdmf')
xdmffile_TL = XDMFFile('NS_SC_200/Lighthill_tensor_200.xdmf')
# Create time series (for use in other .py. Mirar https://github.com/hplgit/fenics-tutorial/blob/master/pub/python/vol1/ft09_reaction_system.py)
timeseries_u = TimeSeries('NS_SC_200/velocitySC_200_series')
timeseries_p = TimeSeries('NS_SC_200/pressureSC_200_series')
timeseries_TL = TimeSeries('NS_SC_200/Lighthill_tensor_200_series')
# Create progress bar
progress = Progress('Time-stepping', num_steps)
# Time-stepping
t = 0
    b1 = assemble(L1)
    [bc.apply(b1) for bc in bcu]
    solve(A1, u_.vector(), b1, 'bicgstab', 'hypre_amg')
    b2 = assemble(L2)
    [bc.apply(b2) for bc in bcp]
    solve(A2, p_.vector(), b2, 'bicgstab', 'hypre_amg')
    b3 = assemble(L3)
    solve(A3, u_.vector(), b3, 'cg', 'sor')
    #Ligthill Tensor
    def TL(u):
        V = u.function_space()
        mesh_NS=V.mesh
        (u_1,u_2)=u.split(True)
        u_11=inner(u_1,u_1)
        u_12=inner(u_1,u_2)
        u_22=inner(u_2,u_2)
        u_11=Function(V)
        u_12=Function(V)
        u_22=Function(V)
        degree=V.ufl_element().degree()
        L=VectorFunctionSpace(mesh_NS,'P',degree)
        TL=project(([rho*(u_11.dx(0)+u_12.dx(1)),rho*(u_12.dx(0)+u_22.dx(1))]),L)
        return TL
    # Save solution to file (XDMF/HDF5) Para visualización
    xdmffile_u.write(u_, t)
    xdmffile_p.write(p_, t)
    xdmffile_TL.write(TL, t)
    # Save nodal values to file (para importar en otro .py)
    timeseries_u.store(u_.vector(), t)
    timeseries_p.store(p_.vector(), t)
    timeseries_TL.store(TL.vector(), t)
    # Update previous solution
    u_n.assign(u_)
    p_n.assign(p_)
    # Update progress bar
    set_log_level(LogLevel.PROGRESS)
    progress += 1
    print('u max:', u_.vector().get_local().max())
    print('p max:', p_.vector().get_local().max())
…and it always results in the same error:
File “/mnt/—.py”, line 220, in
AttributeError: ‘function’ object has no attribute ‘_cpp_object’
Thanks!
I think the question is…¿How to compute a function when it depends on .dx()(as an Expression do) and the results for the trial function? May be it deserves another topic…
The function TL(u) that you define wants an argument u and seems that when you are writing it you are not providing any “u”.
I tried as follow:
    def TL(u_11,u_12,u_22):
        "Return de Lighthill Tensor projected into same space as u"
        u=TrialFunction(V)
        mesh_NS = V.mesh()
        u_1,u_2=split(u)
        u_1=Function(V)
        u_2=Function(V)
        u_11=inner(u_1,u_1)
        u_12=inner(u_1,u_2)
        u_22=inner(u_2,u_2)
        u_11=Function(V)
        u_12=Function(V)
        u_22=Function(V)
        TL=project(as_vector([rho*(u_11.dx(0)+u_12.dx(1)),rho*(u_12.dx(0)+u_22.dx(1))]),L)
        return TL
File “/mnt/–.py”, line 222, in
You are defining TL twice, once as
And then as the return type
You should use unique names for each of these definitions to avoid conflicts
Yes!!
:partying_face: :partying_face:
I think I did it…Now the code is running, and it’s something new!
(It will finish in several hours, I´ll tell you if it definitely works)
Here is my code:
mesh_NS = Mesh()
T =70   # final time
V = VectorFunctionSpace(mesh_NS, 'P', 2)#para la velocidad
Q = FunctionSpace(mesh_NS, 'P', 1)#para la presión
#Boundaries
#Los tenemos definidos ya en los grupos físicos de la malla:
#11:'aerogenerador'
#13:'entrada flujo'
#14:'salida flujo'
q = TestFunction(Q)
u_n = Function(V)
u_  = Function(V)
p_n = Function(Q)
p_  = Function(Q)
u_1,u_2=split(u)
u_1=Function(V)
u_2=Function(V)
u_11=Function(V)
u_12=Function(V)
u_22=Function(V)
u_11=inner(u_1,u_1)
u_12=inner(u_1,u_2)
u_22=inner(u_2,u_2)
U_x=0.044
bcp = [bcp_outflow]
U  = 0.5*(u_n + u)
k  = Constant(dt)
mu = Constant(mu)
rho = Constant(rho)
def sigma(u, p):
   - dot(f, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
a3 = dot(u, v)*dx
# Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
xdmffile_u = XDMFFile('NS_and_TL/velocitySC_200.xdmf')
xdmffile_p = XDMFFile('NS_and_TL/pressureSC_200.xdmf')
xdmffile_TL = XDMFFile('NS_and_TL/Lighthill_tensor_200.xdmf')
# Create time series (for use in acoustic .py)
timeseries_u = TimeSeries('NS_and_TL/velocitySC_200_series')
timeseries_p = TimeSeries('NS_and_TL/pressureSC_200_series')
timeseries_TL = TimeSeries('NS_and_TL/Lighthill_tensor_200_series')
# Time-stepping
t = 0
    b1 = assemble(L1)
    b2 = assemble(L2)
    b3 = assemble(L3)
    #Resuelvo tensor de Lighthill
    # Tensor_Lighthill
        u_1,u_2=split(u)
        u_1=Function(V)
        u_2=Function(V)
        u_11=Function(V)
        u_12=Function(V)
        u_22=Function(V)
        u_11=inner(u_1,u_1)
        u_12=inner(u_1,u_2)
        u_22=inner(u_2,u_2)
        return TL
    xdmffile_TL.write(TL(u_11,u_12,u_22), t)
    timeseries_TL.store(TL(u_11,u_12,u_22).vector(), t)
    u_n.assign(u_)
    p_n.assign(p_)
    progress += 1
I did some changes, but the most important, appart from the definition of TL() as a function of u_11_u_12 and u_22 is that I had to define u_11,u_12,u_22 in the beginning too, and when a I tried to write the TL to the xdmffile and timeseries, I had to write TL(u_11,u_12,u_22) (I agree with you dokken, I should avoid different names for the same function).
Many thanks to all of you!
