Dear Dolfinx Developers,
First and foremost, I would like to express my deepest gratitude and respect for the outstanding work you have accomplished with Dolfinx.
As a researcher in architectural engineering, I am currently working on a research paper utilizing Dolfinx. In our field, we commonly model 1D steel reinforcements as line elements embedded within 3D concrete structures.
To achieve this, I have modeled a 3D concrete volume and 1D steel reinforcements using GMSH, as shown in the code below. However, when I attempt to execute the code, it does not run as expected.
Would it be possible to seek your advice on resolving this issue?
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
Created on Wed Jan 8 18:54:54 2025
@author: hoseong
import math
from dolfinx.mesh import create_mesh
from dolfinx.io import gmshio
import pyvista as pv
import pyvista
from dolfinx import mesh, fem, plot, io, default_scalar_type
########################Mesh creation#######################
gmsh.model.add('DFG 3D')
#define dimension
length_member = 500
width_member = 100
depth_member = 100
cover_spacing_longitudinal_rebar = 20
embedded_length_longitudinal_rebar = 400
diameter_longitudinal_rebar = 8
#####tag list#####
#volume 1X0
tag_volume_concrete = 130
#Line 1X000
tag_line_longitudinal_rebar = 11000
tag_line_transverse_rebar = 12000
#Point 1X0000
tag_point_count_longitudinal_rebar = 120000
tag_point_count_transverse_rebar = 120000
#volume 2X0
marker_volume_longitudinal_rebar = 210
marker_volume_transverse_rebar = 220
marker_volume_concrete = 230
#Surface 2X00
marker_surface_longitudinal_rebar = 2100
marker_surface_transverse_rebar = 2200
##### model concrete #####
domain_concrete = gmsh.model.occ.addBox(0, 0, 0, length_member, width_member, depth_member, tag=tag_volume_concrete)
##### generate concrete #####
gmsh.model.occ.synchronize()
##### model rebar #####
gmsh.model.occ.addPoint(length_member / 2 - embedded_length_longitudinal_rebar / 2, width_member / 2, cover_spacing_longitudinal_rebar + diameter_longitudinal_rebar / 2, tag=tag_point_count_longitudinal_rebar)
gmsh.model.occ.addPoint(length_member / 2 + embedded_length_longitudinal_rebar / 2, width_member / 2, cover_spacing_longitudinal_rebar + diameter_longitudinal_rebar / 2, tag=tag_point_count_longitudinal_rebar+1)
domain_longitudinal_rebar = gmsh.model.occ.addLine(tag_point_count_longitudinal_rebar, tag_point_count_longitudinal_rebar+1, tag=tag_line_longitudinal_rebar)
##### embed straight line #####
gmsh.model.mesh.embed(1, [tag_line_longitudinal_rebar], 3, tag_volume_concrete)
gmsh.model.occ.removeAllDuplicates()
volume_3D = gmsh.model.getEntities(dim=3)
##### allocate marker and name #####
gmsh.model.addPhysicalGroup(3, [tag_volume_concrete], marker_volume_concrete)
gmsh.model.setPhysicalName(3, marker_volume_concrete, 'volume_concrete')
gmsh.model.addPhysicalGroup(1, [tag_line_longitudinal_rebar], marker_volume_longitudinal_rebar)
gmsh.model.setPhysicalName(1, marker_volume_longitudinal_rebar, 'line_transverse_rebar')
resolution = 25
gmsh.model.mesh.setSize(gmsh.model.getEntities(1), resolution) # 1D 선
gmsh.option.setNumber('Mesh.MeshSizeMin', 0.01 * resolution)
gmsh.option.setNumber('Mesh.MeshSizeMax', 10 * resolution)
gmsh.option.setNumber("Mesh.MshFileVersion", 4.1) # MSH 파일 버전 (4.1, 2.2 등)
gmsh.option.setNumber("Mesh.Binary", 0) # ASCII 형식 (Binary 사용 시 1)
#Generate mesh 3 : Cell, 2 : Facet, 1 : Edge
gmsh.model.mesh.generate(3)
#save model
gmsh_model=gmsh.model
#save msh file
gmsh.fltk.run()
gmsh.write('mesh3D.msh')
gmsh.finalize()
# gmsh.model.occ.synchronize()
# gmsh.fltk.run()
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={
"name_to_read": [cell_data]})
return out_mesh
# read msh file
mesh1 = meshio.read("mesh3D.msh")
mesh2=create_mesh(mesh1,"tetra")
# Save 3D mesh
meshio.write("mesh3D.xdmf" , mesh2)
# Save 1D mesh
mesh3=create_mesh(mesh1,"line")
meshio.write("mesh1D.xdmf", mesh3)
with XDMFFile(MPI.COMM_WORLD, "mesh3D.xdmf", "r") as xdmf:
domain_3D = xdmf.read_mesh(name="Grid")
#Save cell tag
cell_marker_1 = xdmf.read_meshtags(domain_3D, name="Grid")
xdmf.close()
with XDMFFile(MPI.COMM_WORLD, "mesh1D.xdmf", "r") as xdmf:
domain_1D = xdmf.read_mesh(name="Grid")
#Save cell tag
# edge_marker_2 = xdmf.read_meshtags(domain_1D, name="Grid")
xdmf.close()
########################solve#######################
# Scaled variable
mu = 1
rho = 1
delta = width_member / length_member
gamma = 0.4 * delta**2
beta = 1.25
lambda_ = beta
g = gamma
stiffness_axial=1
V = fem.functionspace(domain_3D, ("Lagrange", 1, (3, ))) #tetra element calculate stress and strain at quadrature points
def clamped_boundary(x):
return np.isclose(x[0], 0)
fdim = domain_3D.topology.dim - 1
boundary_facets = mesh.locate_entities_boundary(domain_3D, fdim, clamped_boundary)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
T = fem.Constant(domain_3D, default_scalar_type((0, 0, 0)))
ds_3D = ufl.Measure("ds", domain=domain_3D)
dx_3D = ufl.Measure("dx", domain=domain_3D)
dx_1D = ufl.Measure("dx", domain=domain_1D)
def epsilon_3D(u):
return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma_3D(u):
return lambda_ * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2 * mu * epsilon_3D(u)
def tangent_calculation(domain_1D):
tangent_matrix=ufl.Jacobian(domain_1D) # shape is (3,1)
return ufl.as_vector([tangent_matrix[0,0], tangent_matrix[1, 0], tangent_matrix[2, 0]])/ufl.sqrt(ufl.inner(tangent_matrix,tangent_matrix))
def epsilon_1D(delta_displacement_Vector, domain_1D):
tangent_vector=tangent_calculation(domain_1D)
axial_strain=ufl.dot(ufl.dot(ufl.grad(delta_displacement_Vector),
tangent_vector),tangent_vector)
return axial_strain
def sigma_1D(u,domain_1D):
return stiffness_axial* epsilon_1D(u,domain_1D)
u = ufl.TrialFunction(V)
f = fem.Constant(domain_3D, default_scalar_type((0, 0, -rho * g)))
a = ufl.inner(sigma_3D(u), epsilon_3D(v)) * dx_3D
a += sigma_1D(u,domain_1D)*epsilon_1D(v,domain_1D)* dx_1D
L = ufl.dot(f, v) * ufl.dx + ufl.dot(T, v) * ds_3D
uh = problem.solve()
