Hello FEniCS community,
I’m still quite new to FEniCS, and this post is more about conceptual questions. Upon adapting and reproducing the demo code (Stokes equations using Taylor-Hood elements — DOLFINx 0.10.0.0 documentation) on my own machine with DOLFINx 0.9.0 on Mac, I’m wondering what is causing the mixed direct solver to give such weird results. The Taylor-Hood elements are supposed to be stable regardless of discretization parameters, and I’m not even sure if the problem is about numerical stability. Certainly, the mixed direct solver still converges, but it converges to a wrong solution.
Does it mean the mixed direct solver should not be used for any Stokes problem? Or is there any way or criterion to verify if the result given by a mixed direct solver is reliable? Further, how can one know the nested solver or the blocked iterative solver is reliable? (Assume the numerical method is in principle well-posed) I understand the complications due to the variational problem is of the saddle point type, but could anyone help me relating that to the mixed solver and how that could cause the trouble demonstrated in the demo code?
A working example (though not minimal, my apologies) is below, though the question is merely conceptual. Any of your help is greatly appreciated!
try:
if not dolfinx.has_petsc:
print("This demo requires DOLFINx to be compiled with PETSc enabled.")
exit(0)
except ModuleNotFoundError:
print("This demo requires petsc4py.")
exit(0)
from dolfinx import default_real_type, fem, la
from dolfinx.fem import (
Constant,
Function,
dirichletbc,
extract_function_spaces,
form,
functionspace,
locate_dofs_topological,
from dolfinx.fem.petsc import assemble_matrix_block, assemble_vector_block
from dolfinx.mesh import CellType, create_rectangle, locate_entities_boundary
from ufl import div, dx, grad, inner
import pyvista
opts = PETSc.Options()
opts["mat_superlu_dist_iterrefine"] = True
# Create mesh
msh = create_rectangle(
MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])], [32, 32], CellType.triangle
P2 = element("Lagrange", msh.basix_cell(), 2, shape=(msh.geometry.dim,), dtype=default_real_type)
P1 = element("Lagrange", msh.basix_cell(), 1, dtype=default_real_type)
V, Q = functionspace(msh, P2), functionspace(msh, P1)
# Boundary conditions for the velocity field are defined:
# Function to mark x = 0, x = 1 and y = 0
def noslip_boundary(x):
return np.isclose(x[0], 0.0) | np.isclose(x[0], 1.0) | np.isclose(x[1], 0.0)
# Function to mark the lid (y = 1)
def lid(x):
return np.isclose(x[1], 1.0)
# Lid velocity
def lid_velocity_expression(x):
return np.stack((np.ones(x.shape[1]), np.zeros(x.shape[1])))
# No-slip condition on boundaries where x = 0, x = 1, and y = 0
noslip = np.zeros(msh.geometry.dim, dtype=PETSc.ScalarType) # type: ignore
facets = locate_entities_boundary(msh, 1, noslip_boundary)
bc0 = dirichletbc(noslip, locate_dofs_topological(V, 1, facets), V)
# Driving (lid) velocity condition on top boundary (y = 1)
lid_velocity = Function(V)
lid_velocity.interpolate(lid_velocity_expression)
facets = locate_entities_boundary(msh, 1, lid)
bc1 = dirichletbc(lid_velocity, locate_dofs_topological(V, 1, facets))
bcs = [bc0, bc1]
# The bilinear and linear forms for the Stokes equations are defined
# using a a blocked structure:
(u, p) = ufl.TrialFunction(V), ufl.TrialFunction(Q)
(v, q) = ufl.TestFunction(V), ufl.TestFunction(Q)
f = Constant(msh, (PETSc.ScalarType(0), PETSc.ScalarType(0))) # type: ignore
a = form([[inner(grad(u), grad(v)) * dx, inner(p, div(v)) * dx], [inner(div(u), q) * dx, None]])
L = form([inner(f, v) * dx, inner(Constant(msh, PETSc.ScalarType(0)), q) * dx]) # type: ignore
# A block-diagonal preconditioner will be used with the iterative
# solvers for this problem:
a_p11 = form(inner(p, q) * dx)
a_p = [[a[0][0], None], [None, a_p11]]
def view_flow(V, u, msh):
# pyvista.start_xvfb()
topology, cell_types, geometry = vtk_mesh(V)
values = np.zeros((geometry.shape[0], 3), dtype=np.float64)
values[:, :len(u)] = u.x.array.real.reshape((geometry.shape[0], len(u)))
# Create a point cloud of glyphs
function_grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
function_grid["u"] = values
glyphs = function_grid.glyph(orient="u", factor=0.5)
# Create a pyvista-grid for the mesh
msh.topology.create_connectivity(msh.topology.dim, msh.topology.dim)
grid = pyvista.UnstructuredGrid(*vtk_mesh(msh, msh.topology.dim))
# Create plotter
plotter = pyvista.Plotter()
plotter.add_mesh(grid, style="wireframe", color="k")
plotter.add_mesh(glyphs)
plotter.view_xy()
if not pyvista.OFF_SCREEN:
plotter.show()
fig_as_array = plotter.screenshot("glyphs.png")
def nested_iterative_solver():
"""Solve the Stokes problem using nest matrices and an iterative solver."""
# Assemble nested matrix operators
A = fem.petsc.assemble_matrix_nest(a, bcs=bcs)
# Create a nested matrix P to use as the preconditioner. The
# top-left block of P is shared with the top-left block of A. The
# bottom-right diagonal entry is assembled from the form a_p11:
P11 = fem.petsc.assemble_matrix(a_p11, [])
P = PETSc.Mat().createNest([[A.getNestSubMatrix(0, 0), None], [None, P11]])
P.assemble()
A00 = A.getNestSubMatrix(0, 0)
A00.setOption(PETSc.Mat.Option.SPD, True)
P00, P11 = P.getNestSubMatrix(0, 0), P.getNestSubMatrix(1, 1)
P00.setOption(PETSc.Mat.Option.SPD, True)
P11.setOption(PETSc.Mat.Option.SPD, True)
# Assemble right-hand side vector
b = fem.petsc.assemble_vector_nest(L)
# Modify ('lift') the RHS for Dirichlet boundary conditions
fem.petsc.apply_lifting_nest(b, a, bcs=bcs)
# Sum contributions for vector entries that are share across
# parallel processes
for b_sub in b.getNestSubVecs():
b_sub.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
# Set Dirichlet boundary condition values in the RHS vector
bcs0 = fem.bcs_by_block(extract_function_spaces(L), bcs)
fem.petsc.set_bc_nest(b, bcs0)
# The pressure field is determined only up to a constant. We supply
# a vector that spans the nullspace to the solver, and any component
# of the solution in this direction will be eliminated during the
# solution process.
null_vec = fem.petsc.create_vector_nest(L)
# Set velocity part to zero and the pressure part to a non-zero
# constant
null_vecs = null_vec.getNestSubVecs()
null_vecs[0].set(0.0), null_vecs[1].set(1.0)
# Normalize the vector that spans the nullspace, create a nullspace
# object, and attach it to the matrix
null_vec.normalize()
nsp = PETSc.NullSpace().create(vectors=[null_vec])
assert nsp.test(A)
A.setNullSpace(nsp)
# Create a MINRES Krylov solver and a block-diagonal preconditioner
# using PETSc's additive fieldsplit preconditioner
ksp.setOperators(A, P)
ksp.setType("minres")
ksp.setTolerances(rtol=1e-9)
ksp.getPC().setType("fieldsplit")
ksp.getPC().setFieldSplitType(PETSc.PC.CompositeType.ADDITIVE)
# Define the matrix blocks in the preconditioner with the velocity
# and pressure matrix index sets
nested_IS = P.getNestISs()
ksp.getPC().setFieldSplitIS(("u", nested_IS[0][0]), ("p", nested_IS[0][1]))
# Set the preconditioners for each block. For the top-left
# Laplace-type operator we use algebraic multigrid. For the
# lower-right block we use a Jacobi preconditioner. By default, GAMG
# will infer the correct near-nullspace from the matrix block size.
ksp_u, ksp_p = ksp.getPC().getFieldSplitSubKSP()
ksp_u.setType("preonly")
ksp_u.getPC().setType("gamg")
ksp_p.setType("preonly")
ksp_p.getPC().setType("jacobi")
# Create finite element {py:class}`Function <dolfinx.fem.Function>`s
# for the velocity (on the space `V`) and for the pressure (on the
# space `Q`). The vectors for `u` and `p` are combined to form a
# nested vector and the system is solved.
u, p = Function(V), Function(Q)
x = PETSc.Vec().createNest([la.create_petsc_vector_wrap(u.x), la.create_petsc_vector_wrap(p.x)])
ksp.solve(b, x)
# Compute norms of the solution vectors
norm_u = la.norm(u.x)
norm_p = la.norm(p.x)
if MPI.COMM_WORLD.rank == 0:
print(f"(A) Norm of velocity coefficient vector (nested, iterative): {norm_u}")
print(f"(A) Norm of pressure coefficient vector (nested, iterative): {norm_p}")
return norm_u, norm_p
def block_operators():
"""Return block operators and block RHS vector for the Stokes
problem"""
# Assembler matrix operator, preconditioner and RHS vector into
# single objects but preserving block structure
A = assemble_matrix_block(a, bcs=bcs)
P = assemble_matrix_block(a_p, bcs=bcs)
P.assemble()
b = assemble_vector_block(L, a, bcs=bcs)
# Set the nullspace for pressure (since pressure is determined only
# up to a constant)
null_vec = A.createVecLeft()
offset = V.dofmap.index_map.size_local * V.dofmap.index_map_bs
null_vec.array[offset:] = 1.0
assert nsp.test(A)
A.setNullSpace(nsp)
return A, P, b
# The following function solves the Stokes problem using a
# block-diagonal preconditioner and monolithic PETSc matrices.
def block_iterative_solver():
"""Solve the Stokes problem using blocked matrices and an iterative
solver."""
# Assembler the operators and RHS vector
A, P, b = block_operators()
# Build PETSc index sets for each field (global dof indices for each
# field)
V_map = V.dofmap.index_map
Q_map = Q.dofmap.index_map
offset_u = V_map.local_range[0] * V.dofmap.index_map_bs + Q_map.local_range[0]
offset_p = offset_u + V_map.size_local * V.dofmap.index_map_bs
is_u = PETSc.IS().createStride(
V_map.size_local * V.dofmap.index_map_bs, offset_u, 1, comm=PETSc.COMM_SELF
is_p = PETSc.IS().createStride(Q_map.size_local, offset_p, 1, comm=PETSc.COMM_SELF)
ksp.getPC().setFieldSplitIS(("u", is_u), ("p", is_p))
# Configure velocity and pressure sub-solvers
# The matrix A combined the vector velocity and scalar pressure
# parts, hence has a block size of 1. Unlike the MatNest case, GAMG
# cannot infer the correct near-nullspace from the matrix block
# size. Therefore, we set block size on the top-left block of the
# preconditioner so that GAMG can infer the appropriate near
# nullspace.
ksp.getPC().setUp()
Pu, _ = ksp_u.getPC().getOperators()
Pu.setBlockSize(msh.topology.dim)
# Create a block vector (x) to store the full solution and solve
x = A.createVecRight()
ksp.solve(b, x)
# Create Functions to split u and p
offset = V_map.size_local * V.dofmap.index_map_bs
u.x.array[:offset] = x.array_r[:offset]
p.x.array[: (len(x.array_r) - offset)] = x.array_r[offset:]
# Compute the $L^2$ norms of the solution vectors
norm_u, norm_p = la.norm(u.x), la.norm(p.x)
print(f"(B) Norm of velocity coefficient vector (blocked, iterative): {norm_u}")
print(f"(B) Norm of pressure coefficient vector (blocked, iterative): {norm_p}")
def block_direct_solver():
"""Solve the Stokes problem using blocked matrices and a direct
solver."""
# Assembler the block operator and RHS vector
A, _, b = block_operators()
# Create a solver
ksp.setOperators(A)
ksp.setType("preonly")
# Set the solver type to MUMPS (LU solver) and configure MUMPS to
# handle pressure nullspace
pc = ksp.getPC()
pc.setType("lu")
pc.setFactorSolverType("superlu_dist")
try:
pc.setFactorSetUpSolverType()
except PETSc.Error as e:
if e.ierr == 92:
print("The required PETSc solver/preconditioner is not available. Exiting.")
print(e)
exit(0)
raise e
# pc.getFactorMatrix().setMumpsIcntl(icntl=24, ival=1) # For pressure nullspace
# pc.getFactorMatrix().setMumpsIcntl(icntl=25, ival=0) # For pressure nullspace
# Create a block vector (x) to store the full solution, and solve
x = A.createVecLeft()
ksp.solve(b, x)
# Create Functions and scatter x solution
# Compute the $L^2$ norms of the u and p vectors
print(f"(C) Norm of velocity coefficient vector (blocked, direct): {norm_u}")
print(f"(C) Norm of pressure coefficient vector (blocked, direct): {norm_p}")
def mixed_direct():
# Create the Taylot-Hood function space
TH = mixed_element([P2, P1])
W = functionspace(msh, TH)
# No slip boundary condition
W0 = W.sub(0)
Q, _ = W0.collapse()
noslip = Function(Q)
dofs = locate_dofs_topological((W0, Q), 1, facets)
bc0 = dirichletbc(noslip, dofs, W0)
# Driving velocity condition u = (1, 0) on top boundary (y = 1)
lid_velocity = Function(Q)
bc1 = dirichletbc(lid_velocity, dofs, W0)
bcs = [bc0, bc1]
(v, q) = ufl.TestFunctions(W)
f = Function(Q)
a = form((inner(grad(u), grad(v)) + inner(p, div(v)) + inner(div(u), q)) * dx)
L = form(inner(f, v) * dx)
# Assemble LHS matrix and RHS vector
A = fem.petsc.assemble_matrix(a, bcs=bcs)
b = fem.petsc.assemble_vector(L)
fem.petsc.apply_lifting(b, [a], bcs=[bcs])
for bc in bcs:
bc.set(b)
# Create and configure solver
ksp.setOperators(A)
# Configure MUMPS to handle pressure nullspace
pc = ksp.getPC()
pc.setType("lu")
# pc.setFactorSolverType("mumps")
# pc.setFactorSetUpSolverType()
# Compute the solution
U = Function(W)
try:
ksp.solve(b, U.x.petsc_vec)
if e.ierr == 92:
print(e)
exit(0)
raise e
u, p = U.sub(0).collapse(), U.sub(1).collapse()
# Compute norms
print(f"(D) Norm of velocity coefficient vector (monolithic, direct): {norm_u}")
print(f"(D) Norm of pressure coefficient vector (monolithic, direct): {norm_p}")
return norm_u, norm_u
# Solve using PETSc MatNest
norm_u_0, norm_p_0 = nested_iterative_solver()
# Solve using PETSc block matrices and an iterative solver
norm_u_1, norm_p_1 = block_iterative_solver()
np.testing.assert_allclose(norm_u_1, norm_u_0, rtol=1e-4)
# Solve using PETSc block matrices and an LU solver
norm_u_2, norm_p_2 = block_direct_solver()
np.testing.assert_allclose(norm_u_2, norm_u_0, rtol=1e-4)
np.testing.assert_allclose(norm_p_2, norm_p_0, rtol=1e-4)
# Solve using a non-blocked matrix and an LU solver
norm_u_3, norm_p_3 = mixed_direct()
np.testing.assert_allclose(norm_u_3, norm_u_0, rtol=1e-4)
