Links from Docker image require token
I have tried the newest version of Fenics from here https://fenicsproject.org/download/ . I installed he Docker image, and when I run it, I got two HTTP links. One is broken (the browser does not open it), and the other asks for token. I tried to copy and paste the token from the URL as instructed, but it did not work (Invalid credentials). What should I do? Thank you!
You should use the http that starts with:
 http://127.0.0.1:8888/lab?token=herethecontainerspecifictokenappears
Thank you! This link works now. However, when I am trying to run the code in the Jupyter notebook (choosing dolfinx one) at the line “import dolfin” I get a mistake “No module named dolfin”. I didn’t have this mistake before when using Fenics on Anaconda. what should I do with it? Thank you!
The instructions tells you how to install the latest version of dolfin, called dolfinx.
To use the legacy code, dolfin, see: https://fenicsproject.org/download/archive/
