Local Refinement of SubDomain
Hi Everyone,
I want to refine the mesh in the solid domain of the fluid structure interaction problem. For that, I am using a refine() function and a boolean mesh function. However, I believe I am losing markers, and I need to use adapt() because my relative and absolute residuals have become nan. But I’m not sure how or where to use adapt(). Please help me figure out how to locally refine it.
from ufl import indices, Jacobian, Min
# Parameters defining domain geometry:
SOLID_LEFT = 0.45
SOLID_RIGHT = 0.55
SOLID_TOP = 0.5
OMEGA_H = 0.75
OMEGA_W = 1.0
# Define the mshr geometrical primitives for this domain:
r_Omega = Rectangle(Point(0,0),Point(OMEGA_W,OMEGA_H))
r_Omega_s = Rectangle(Point(SOLID_LEFT,0),
                      Point(SOLID_RIGHT,SOLID_TOP))
SOLID_FLAG = 1
r_Omega.set_subdomain(SOLID_FLAG,r_Omega_s)
# Define subdomains for use in boundary condition definitions:
class Walls(SubDomain):
        return (on_boundary
                and ((x[1] < DOLFIN_EPS)
                     or (x[1] > (OMEGA_H - DOLFIN_EPS))))
class Inflow(SubDomain):
        return (on_boundary and (x[0] < DOLFIN_EPS))
class Outflow(SubDomain):
        return (on_boundary and (x[0] > (OMEGA_W - DOLFIN_EPS)))
class SolidDomainClosure(SubDomain):
        return (x[0] > SOLID_LEFT - DOLFIN_EPS
                and x[0] < SOLID_RIGHT + DOLFIN_EPS
                and x[1] < SOLID_TOP + DOLFIN_EPS)
mesh = generate_mesh(r_Omega, 70)
d = mesh.geometry().dim()
DomainToRefine= CompiledSubDomain("x[0] > 0.45 - DOLFIN_EPS and x[0] < 0.55 + DOLFIN_EPS and x[1] < 0.5 + DOLFIN_EPS")
 r_markers = MeshFunction("bool", mesh, d, False)
DomainToRefine.mark(r_markers, True)
refinedMesh = refine(mesh,r_markers)
mesh=refinedMesh
markers = MeshFunction('size_t', mesh, d, mesh.domains())
bdry_markers = MeshFunction('size_t', mesh, d-1,0)
OUTFLOW_FLAG = 2
Outflow().mark(bdry_markers,OUTFLOW_FLAG)
dx = dx(metadata={'quadrature_degree': 2},
        subdomain_data=markers)
ds = ds(metadata={'quadrature_degree': 2},
        subdomain_data=bdry_markers)
cell = mesh.ufl_cell()
Ve = VectorElement("CG", cell, 1)
Qe = FiniteElement("CG", cell, 1)
VQe = MixedElement((Ve,Qe))
W = FunctionSpace(mesh,VQe)
V = FunctionSpace(mesh,Ve)
First please use 3x` encapsulation to format the code, ie
```python
#add code here
Secondly, consider
You have not defined boundary markers (bdry_markers), so I cannot really help you any further with your post.
Also I don’t see the point of creating markers, as the original mesh as there are no markers of dimension mesh.geometry().dim().
Hi Dokken,
Thank you for your response!
I have updated the code with some other subdomains if you looking for them.
Outflow() is needed to apply stable Neumann BC i.e. zero traction BC at the outlet. That is why I am marking Outflow(). Please let me know if you need further information.
is still not defined.
Sorry, just updated!
I am not sure what your issue is, as the following code runs as expected:
SOLID_LEFT = 0.45
SOLID_RIGHT = 0.55
SOLID_TOP = 0.5
OMEGA_H = 0.75
OMEGA_W = 1.0
r_Omega = Rectangle(Point(0, 0), Point(OMEGA_W, OMEGA_H))
r_Omega_s = Rectangle(Point(SOLID_LEFT, 0), Point(SOLID_RIGHT, SOLID_TOP))
SOLID_FLAG = 1
r_Omega.set_subdomain(SOLID_FLAG, r_Omega_s)
        return on_boundary and ((x[1] < DOLFIN_EPS) or (x[1] > (OMEGA_H - DOLFIN_EPS)))
        return on_boundary and (x[0] < DOLFIN_EPS)
        return on_boundary and (x[0] > (OMEGA_W - DOLFIN_EPS))
        return (
outflow = Outflow()
OUTFLOW_FLAG = 2
d = mesh.topology().dim()
# Generate initial outflow marker
boundary_marker = MeshFunction("size_t", mesh, d - 1, 0)
outflow.mark(boundary_marker, OUTFLOW_FLAG)
File("initial_marker.pvd") << boundary_marker
# Refine mesh
DomainToRefine = CompiledSubDomain(
refinedMesh = refine(mesh, r_markers)
mesh = refinedMesh
# Create new boundary marker
File("new_marker.pvd") << boundary_marker
yielding
The issue is that if I don’t locally refine the mesh (uniform refinement), my code works great. However, if locally refine it (mesh=refinedMesh), my relative and absolute residuals attain NaN values. I emailed you; please check it.
Thank you!
Actually, the issue is with losing domain markers after refinement. The r_omega_s domain with marker ‘SOLID_FLAG’ is lost after refinement. Please have a look at the code and images.
Thank you!
####### Domain and mesh setup #######
SOLID_LEFT = 0.45
SOLID_RIGHT = 0.55
SOLID_TOP = 0.5
OMEGA_H = 0.75
OMEGA_W = 1.0
REF_MARGIN = 0.1
# Enumerate subdomain markers
FLUID_FLAG = 0
SOLID_FLAG = 1
# Zero is the default flag, and does not need to be
# explicitly set for the fluid subdomain.
# Parameters defining refinement level:
N = 64
# Generate mesh of Omega, which will have a fitted
# subdomain for Omega_s.
mesh = generate_mesh(r_Omega, N)
# Mesh-derived quantities:
File("initial_marker.pvd") << markers
# Refine mesh
mesh = refinedMesh
File("after_refinement_marker.pvd") << markers
Once mesh is refined with refine(), just add following line after mesh=refinedMesh
markers = adapt(markers,mesh)
So, the complete code will look like
SOLID_LEFT = 0.45
SOLID_RIGHT = 0.55
SOLID_TOP = 0.5
OMEGA_H = 0.75
OMEGA_W = 1.0
REF_MARGIN = 0.1
FLUID_FLAG = 0
SOLID_FLAG = 1
N = 64
# Refine mesh
mesh = refinedMesh
