dbrown
September 21, 2024, 6:10pm
1
Hi all, I’m using dolfinx 0.8.0 with Python 3.11 and trying to locate all the vertices on a boundary. For a single process this code works ok, but as soon as I use 2 or more I find that locate_entities returns vertices that clearly don’t satisfy the marker function:
from dolfinx.mesh import create_unit_cube, locate_entities
comm = MPI.COMM_WORLD
mesh = create_unit_cube(comm, 5, 5, 5)
idx = locate_entities(mesh, 0, lambda x: np.isclose(x[2], 0))
coords = mesh.geometry.x[idx]
assert np.allclose(coords[:, 2], 0, atol=1e-6), f"rank={comm.rank}: Boundary error: {coords[:, 2]}"
I run this using mpirun -n 2 python error.py and it returns something like:
AssertionError: rank=0: Boundary error: [0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0.
0. 0. 0. 0. 0.8 1. 0.6 0.8 0. 0. 0. 0.2]
AssertionError: rank=1: Boundary error: [0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0.2 0.4 0.2 0.2]
mpirun -n 1 python error.py runs fine. I assume I am doing something wrong in terms of selecting vertices across different processes?
dokken
September 21, 2024, 9:08pm
2
You are mixing the indices of topology (vertices, edges,facets and cells) with geometry (the physical nodes making up the grid).
To map from vertices to geometry nodes (those located in mesh.geometry.x) use
entities_to_geometry
https://docs.fenicsproject.org/dolfinx/v0.8.0/python/generated/dolfinx.mesh.html#dolfinx.mesh.entities_to_geometry
that can map the indices given in idx to indices in mesh.geometry.x
dbrown
September 21, 2024, 9:36pm
3
I see thanks, that makes sense! For those that come across this later this now works:
from dolfinx.mesh import create_unit_cube, locate_entities, entities_to_geometry
entity_idx = locate_entities(mesh, 0, lambda x: np.isclose(x[2], 0))
idx = entities_to_geometry(mesh, 0, entity_idx)
coords = mesh.geometry.x[idx[:, 0]]
assert np.allclose(coords[:, 2], 0, atol=1e-6), f"rank={comm.rank}: coordinates: {coords[:, 2]}"
Also, is there a particular reason that entities_to_geometry returns an (N, 1) shaped array of indices rather than (N,)?
mesh.geometry.x[idx] still works but returns a (N,1,3) shaped array of coordinates which seemed odd.
dokken
September 22, 2024, 4:15am
4
Since entities can be edges, facets or cells, it would return (num entities, num nodes per entity). Since your case is a vertex, there is only one node (1-1 map).
I would call:
idx = entities_to_geometry(mesh, 0, entity_idx).flatten()
Rather than doing it after
