Mapped quadrature points, weights and solution at these quadrature points
Please note that the answer to this question is over a year old, using an older version of DOLFINx, it is quite straightforward to make it compatible with 0.7.x, i.e.
import basix
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 2, 2)
quadrature_degree = 1
V = dolfinx.fem.FunctionSpace(mesh, ufl.FiniteElement(
    "Quadrature", mesh.ufl_cell(), quadrature_degree, quad_scheme="default"))
quadrature_points, wts = basix.make_quadrature(
    basix.cell.string_to_type(mesh.topology.cell_name()), quadrature_degree)
x_expr = dolfinx.fem.Expression(x, quadrature_points)
detJ = dolfinx.fem.Expression(ufl.JacobianDeterminant(mesh), quadrature_points)
for i in range(mesh.topology.index_map(mesh.topology.dim).size_local):
    print(
        f"Cell {i}, quadrature points {x_expr.eval(mesh, [i])}, detJ {detJ.eval(mesh, [i])}")
gives
Cell 0, quadrature points [[0.83333333 0.16666667]], detJ [[0.25]]
Cell 1, quadrature points [[0.66666667 0.33333333]], detJ [[-0.25]]
Cell 2, quadrature points [[0.33333333 0.16666667]], detJ [[0.25]]
Cell 3, quadrature points [[0.83333333 0.66666667]], detJ [[0.25]]
Cell 4, quadrature points [[0.16666667 0.33333333]], detJ [[-0.25]]
Cell 5, quadrature points [[0.66666667 0.83333333]], detJ [[-0.25]]
Cell 6, quadrature points [[0.33333333 0.66666667]], detJ [[0.25]]
Cell 7, quadrature points [[0.16666667 0.83333333]], detJ [[-0.25]]
