Mapping 2D numpy array into dolfinx function
I want to get a dolfinx function of my 2D matplotlib contourplot. The functions I want to make are as follows;
There is no polynomial to satisfy these contourplots. Is it possible to map my 2D numpy array into dolfinx function?
Thanks for your answer in advance.
You can tabulate the dof coordinates of your function space (assuming they are a Lagrange space/scalar valued), and use the dolfinx.fem.Function.x.array to Get the values at the corresponding degrees of freedom.
Then you can use any of the solutions from: python - Make contour of scatter - Stack Overflow
Thanks for your answer Dokken, but I want to do exact opposite thing you have mentioned. I want to go from 2D numpy array to dolfinx function.
You need to make a function that is able to evaluate the functions at any point (x,y) in the domain.
You should use an interpolator (for instance scipy.interpolate.interp2d — SciPy v1.7.1 Manual)
from scipy import interpolate
x = np.arange(-5.01, 5.01, 0.25)
y = np.arange(-5.01, 5.01, 0.25)
xx, yy = np.meshgrid(x, y)
z = np.sin(xx**2+yy**2)
f = interpolate.interp2d(x, y, z, kind='cubic')
def g(x):
    return f(x[0], x[1])
u = dolfinx.fem.Function(V)
u.interpolate(g)
What is g in u.interpolate(g)?
Can I use this code to read a 2D image in dolfinx?
Thank you
g is a function that takes in an array of coordinates (on the form [[x_0, x_1, ...., x_n], [y_0,..., y_n], [z_0,..,z_n]] and returns a value per [x_i,y_i,z_i] coordinate.
As long as you have a function that can take physical coordinate (x,y,z) and return a value from the image, you can create an interpolation operator.
If someone faces a similar problem, I would note that interp2d was deprecated in the newer scipy releases. The alternative is to use a RegularGridInterpolator, but that would require a little tweak to the function proposed by dokken:
f = RegularGridInterpolator((x, y), z, method='linear')
def g(x):
    return f(np.array([x[0], x[1]]).T)
u = fem.Function(V)
u.interpolate(g)
