Marking the Parts of a Boundary Face based on Function Values defined over the Mesh
Hello all,
I am currently solving a problem in which I need to apply a boundary condition on only particular parts of a boundary face. I have explained the details below, with the code that I’m working with.
The domain is a unit cube ranging from x = 0 to 1, y = 0 to 1 and z = -1 to 0.
I have a function that is defined over the domain. I have assigned it to random values as shown in the code below.
Now, based on the values of this function on the Top Boundary Face (z=0), I need to appropriately mark this boundary face.
That is, if this function is less than zero on the Top boundary, I want to mark those parts of the Top Boundary as 2.
If this function is greater than or equal to zero on the Top boundary, then I want to mark those parts of the Top Boundary as 1.
(For my specific case, this function needs to be defined over the entire domain)
Please see the code below.
N = 30
mesh = UnitCubeMesh.create(N, N, N//2, CellType.Type.hexahedron)
# mesh is mapped to a [-1;0] domain along z
mesh.coordinates()[:, 2] = -mesh.coordinates()[:, 2]
# Top boundary: z = 0
class Top(SubDomain):
        return near(x[2], 0.) and on_boundary
# exterior facets MeshFunction
facets = MeshFunction("size_t", mesh, 2)
facets.set_all(0)
Top().mark(facets, 1)                 # Marking the entire top boundary as 1 initially
ds = Measure('ds', subdomain_data=facets)
# Function based on which the Top boundary (z=0) needs to be marked
V2 = FunctionSpace(mesh, "CG", 1)
indicator = Function(V2)
dim = V2.dim()
N = mesh.geometry().dim()
coor = V2.tabulate_dof_coordinates().reshape(dim,N)
fx_dofs = V2.dofmap().dofs()
x = coor[:, 0]   # x-coordiantes
y = coor[:, 1]   # y-coordinates
fx_x, fx_y = x[fx_dofs], y[fx_dofs]  # x, y of components
# there are a few operations I need to do based on the x any y co-ordinates,
# but I have simplied it to a random function (as shown below) for now
fx = np.random.randn(*fx_x.shape)
# Final indicator function
indicator.vector()[fx_dofs] = fx
print(fx)
I want to do something like this,
if(indicator function on top boundary >= 0) --> mark those co-ordinates on the Top boundary as 1.
if(indicator function on top boundary < 0) --> mark those co-ordinates on the Top boundary as 2.
I am then hoping to use the marked regions of the boundary - ds(1) and ds(2) in the Variational Formulation.
Thank you all in advance for taking time to help me with the issue !
You need to clarify a few things. Say that we have a one of the top facets, which would be a quadrilateral.
This consists of four dofs, one at each vertex.
What do you want to happen if 1 or 2 of the dofs has a value >=0 and the others have value < 0?
Please also note that the support for hexahedral elements are very limited in dolfin, and I would advise you to use dolfin-x for such problems.
Dear @dokken,
Thank you so much for the reply and clarification. I am now able to understand the picture.
My understanding based on your explanation is that we cannot mark individual co-ordintaes on the top boundary for using in the variational formulation; we can only mark the facets - and each facet has four dofs. Is my understanding correct?
I have initially marked the entire top boundary as 1.
I would like to now do the following: if the function is >= 0 at more than 2 dofs of a top boundary facet, then I want mark those top boundary facets as 2. Can you please help me with a code for this?
Thank you in advance for your help.
Here is an implementation of such a function.
In my code, I only add the facet if there are 2 or more markers satisfying my constraint:
class Topboundary(SubDomain):
        return x[2] > 1-DOLFIN_EPS
mesh = UnitCubeMesh(3,3,3)
tdim = mesh.topology().dim()
fdim = tdim - 1
mesh.init(tdim, fdim)
mesh.init(fdim, tdim)
marker = MeshFunction("size_t", mesh, mesh.topology().dim() - 1, 0)
Topboundary().mark(marker, 1)
c_2_f = mesh.topology()(tdim, fdim)
f_2_c = mesh.topology()(fdim, tdim)
u = interpolate(Expression("x[0]", degree=1), V)
facet_indices = marker.where_equal(1)
petsc_vec = u.vector().vec()
marked_facets = []
with petsc_vec.localForm() as loc:
    petsc_array = loc.array
    for facet in facet_indices:
        cells = f_2_c(facet)
        assert(len(cells)==1)
        cell = cells[0]
        facets = c_2_f(cell)
        local_index = np.argwhere(facets==facet)[0,0]
        local_dof_indices = V.dofmap().entity_closure_dofs(mesh, fdim, [local_index])
        facet_dofs = V.dofmap().cell_dofs(cell)
        num_marked =  0
        values = petsc_array[facet_dofs]
        for value in values:
            if value > 0.5:
                num_marked += 1
        if num_marked > 1:
            marked_facets.append(facet)
marker.array()[marked_facets] = 2
File("marker.pvd") << marker
print(marked_facets)
Dear @dokken,
Thank you so much for sharing the code and helping me with the problem !
Hello dokken!
I am trying to understand your code. Could you tell me the difference between entity_closure_dofs and entity_dofs. entity_closure_dofs worked here but entity_dofs failed. Besides, I found that num_entity_dofs(0) returns 2 and num_entity_dofs(dim) with dim=1,2 returns 0 for 2D mesh. num_entity_closure_dofs works. I have read the source code, still confusing about these functions.
Entity_dofs lists the degrees of freedom that are associated with the entity.
See for instance: DefElement
or
DefElement
for examples where the associated entity for each basis function is listed.
The entity closure dofs loops through all entities of a lower dimension (for a facet it loops through vertices, edges and facets) and finds all dofs associated with any of these entities.
For a cell it loops through (vertices, edges, facets and the cell itself).
For an edge in 3D it would only loop through (vertices and the edge itself).
Thank you very much!
I undstand it. In 3D, num_entity_dofs returns [1,0,0,0] for P1 scalar element and it returns [1,1,0,0] for P2 scalar element.num_entity_closure_dofs returns [1,2,3,4] for P1 scalar element and it returns [1,3,6,10] for P2 scalar element.
Thanks again!
