Meaning of .collapse()
I ran across a Dolfinx line (admittedly an older version) as
dolfinx.fem.locate_dofs_geometrical((V_u.sub(0), V_u.sub(0).collapse()), left)
where left is a function say
def left(x):
    return np.isclose(x[0], 0.0)
he code does run. I was trying to understand why the first argument of locate_dofs_geometrical contains a tuple of spaces.
But then the issue is I fail to understand what the collapse() method does, when applied to a Function Space.
From some posts on this forum it seems a map is build between parent and collapsed space.
Issue with locate_dofs_geometrical using V.sub(0).collapse, useful to apply BCs on a subspace.
But then I found explanations such as " When you collapse a subspace, a new FunctionSpace is created that has no knowledge of its parent function space" from Setting vector component-wise Dirichlet BCs.
I even tried to do some experiments, by issuing
blocked_dofs_left_u = dolfinx.fem.locate_dofs_geometrical(V_u.sub(0), left)
and checking how the BCs now behaved, applying a dummy displacement field. I get an error
Cannot tabulate coordinates for a FunctionSpace that is a subspace.
The syntax is the same as used for example in the Component-wise Dirichlet BC tutorial, the difference being a subspace is used where I get the error.
I have a workaround, an alternative that works, I am just very curios to understand what is going on.
Could somebody please point me in the direction, what is that
collapse() does exactly? Thanks
Imagine you have a Mixed element, lets say a Raviart Thomas space and a DG 0 space (space of cell-wise constants).
RT = ufl.FiniteElement("RT", mesh.ufl_cell(), 1)
DG0 = ufl.FiniteElement("DG", mesh.ufl_cell(), 0)
el = ufl.MixedElement(RT, DG0)
W = dolfinx.fem.FunctionSpace(mesh, el)
If we create a function in the mixed space, say up, we can check how many dofs we have in the problem:
up = dolfinx.fem.Function(W)
print(len(up.x.array))
which returns 520.
If we only want to work on the space of RT dofs, the 0th subspace of W, we call
V, V_to_W = W.sub(0).collapse()
u = dolfinx.fem.Function(V)
print(len(u.x.array), len(V_to_W))
Returning
320 320
Similarly, for the DG-0 space, we have
Q, Q_to_W = W.sub(1).collapse()
p = dolfinx.fem.Function(Q)
print(len(p.x.array), len(Q_to_W))
returning
200 200
As you can see here, collapse just gives you a function space over the ith element of the mixed element, and the second output is the map from each dof in the sub space, to the parent space.
If we keep on considering the first sub-space, the RT-space, whose dofs are defined by the facets of a cell, (with functionals being integrals over said facet), one cannot locate those geometrically, as the dof does not have a physical coordinate
dolfinx.fem.locate_dofs_geometrical(V, lambda x: x[0] < 0.5)
returns
  File "/fenics/shared/mwe123.py", line 24, in <module>
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/bcs.py", line 54, in locate_dofs_geometrical
    return _cpp.fem.locate_dofs_geometrical(V._cpp_object, marker)
RuntimeError: Cannot evaluate dof coordinates - this element does not have pointwise evaluation.
Thus, for the mixed-element W, one would need to work on the sub-space Q, if one want to use locate_dofs_topological, as the mixed-element cannot compute this.
As we want to have the dofs of the combined space, we send in the tuplet (W.sub(1), Q)), to being able to pass the mapping information on:
print(dolfinx.fem.locate_dofs_geometrical((W.sub(1), Q), lambda x: x[0] < 0.5))
returns
[array([ 87, 101, 119, 121, 135, 138, 156, 158, 160, 174, 177, 180, 198,
       200, 202, 204, 218, 221, 224, 227, 245, 247, 249, 251, 253, 267,
       270, 273, 276, 279, 296, 298, 300, 302, 304, 315, 318, 321, 324,
       327, 341, 343, 345, 347, 349, 358, 361, 364, 367, 370, 381, 383,
       385, 387, 389, 396, 399, 402, 405, 408, 416, 418, 420, 422, 424,
       429, 432, 435, 438, 441, 446, 448, 450, 452, 454, 457, 460, 463,
       466, 469, 471, 473, 475, 477, 480, 483, 486, 489, 491, 493, 495,
       498, 501, 504, 506, 508, 511, 514, 516, 519], dtype=int32), array([ 30,  36,  42,  43,  49,  50,  56,  57,  58,  64,  65,  66,  72,
        73,  74,  75,  81,  82,  83,  84,  90,  91,  92,  93,  94, 100,
       101, 102, 103, 104, 110, 111, 112, 113, 114, 119, 120, 121, 122,
       123, 128, 129, 130, 131, 132, 136, 137, 138, 139, 140, 144, 145,
       146, 147, 148, 151, 152, 153, 154, 155, 158, 159, 160, 161, 162,
       164, 165, 166, 167, 168, 170, 171, 172, 173, 174, 175, 176, 177,
       178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190,
       191, 192, 193, 194, 195, 196, 197, 198, 199], dtype=int32)]
where the first list is the dof entries in W, the second entry is the dof entries in Q.
You can verify that the second row is equivalent to the dofs in Q by calling:
print(dolfinx.fem.locate_dofs_geometrical(Q, lambda x: x[0] < 0.5))
Thank you very much for the detailed explanation, very useful.
Think I got it, the only remaining doubt remains on the syntax itself.
This is a minimal example
#from petsc4py.PETSc import VectorType
mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD,[[0,0],[1,1]],  [10, 10])
element = ufl.VectorElement('Lagrange',mesh.ufl_cell(),degree=1,dim=2)
V = dolfinx.fem.FunctionSpace(mesh, element)
def bottom(x):
    return np.isclose(x[1], 0.0)
V_y = V.sub(1).collapse()[0]
blocked_dofs_bottom = dolfinx.fem.locate_dofs_geometrical((V.sub(1), V_y), bottom)
zero_uy = dolfinx.fem.Function(V_y)
with zero_uy.vector.localForm() as bc_local:
    bc_local.set(0.0)
bc0 = dolfinx.fem.dirichletbc(zero_uy, blocked_dofs_bottom)
So now blocked_dofs_bottom is a list of two numpy arrays.
The docs for the dircihletbc (value, dofs, V) function say
dofs: Local indices of degrees of freedom in function space to
            which boundary condition applies. Expects array of size
            (number of dofs, 2) if function space of the problem, ``V``,
            is passed. Otherwise assumes function space of the problem
            is the same of function space of boundary values function.
        V: Function space of a problem to which boundary conditions are applied.
I am not sure if it is me or this is confusing. In the dirichletbc command above the V space, the third argument was not passed, an yet the second argument was an array of size (number of dofs, 2) (I take here is array here a general term incuding lists?). There are examples where the third argument is passed, and the second argument has size (number of dofs, 1).
Cannot reconcile this with the docs. It would make sense if what the docs were saying would be something like, "Expects array of size
(number of dofs, 2) if function space of the problem, V is different from the function space on which BC are applied, and dof indeces in both parent and derived space are provided in the second argument
You shoudl send in the third argument if you want to use this Dirichlet-condition on V.
This here indicates that if the space you are applying the bc to (V.sub(0)) is different to the function space that the value you are sending in, you need to pass a third argument (i.e. V.sub(0)).
Think I got it, thanks a lot.
