Mesh refinement gives solution with zero values
Hi everyone!
I’m trying to refine one specific area of a mesh in the magnetostatics example from the tutorial. And when plotting I got zero values for the results and encountered with this error:
home/manuel/anaconda3/envs/fenics2018/lib/python3.7/site-packages/matplotlib/quiver.py:686: RuntimeWarning: divide by zero encountered in double_scalars
  length = a * (widthu_per_lenu / (self.scale * self.width))
/home/manuel/anaconda3/envs/fenics2018/lib/python3.7/site-packages/matplotlib/quiver.py:686: RuntimeWarning: invalid value encountered in multiply
/home/manuel/anaconda3/envs/fenics2018/lib/python3.7/site-packages/matplotlib/quiver.py:738: RuntimeWarning: invalid value encountered in less
  short = np.repeat(length < minsh, 8, axis=1)
/home/manuel/anaconda3/envs/fenics2018/lib/python3.7/site-packages/matplotlib/quiver.py:751: RuntimeWarning: invalid value encountered in less
  tooshort = length < self.minlength
the code is basically the magnetostatics example with a mesh refinement condition:
from math import sin, cos, pi
a = 1.0
b = 1.2
c_1 = 0.8
c_2 = 1.4
r = 0.1
R = 5.0
n = 10
domain = Circle(Point(0, 0), R)
cylinder = Circle(Point(0, 0), b) - Circle(Point(0, 0), a)
angles_N = [i*2*pi/n for i in range(n)]
angles_S = [(i + 0.5)*2*pi/n for i in range(n)]
wires_N = [Circle(Point(c_1*cos(v), c_1*sin(v)), r) for v in angles_N]
wires_S = [Circle(Point(c_2*cos(v), c_2*sin(v)), r) for v in angles_S]
domain.set_subdomain(1, cylinder)
for (i, wire) in enumerate(wires_N):
    domain.set_subdomain(2 + i, wire)
for (i, wire) in enumerate(wires_S):
    domain.set_subdomain(2 + n + i, wire)
mesh = generate_mesh(domain, 32)
cell_markers = MeshFunction("bool", mesh, mesh.topology().dim())
cell_markers.set_all(False)
for cell in cells(mesh):
    p = cell.midpoint()
    if  2 < p.x() < 3 and  2.5 < p.y() < 3.5 :
    	cell_markers[cell] = True
mesh = refine(mesh, cell_markers)
bc = DirichletBC(V, Constant(0), 'on_boundary')
markers = MeshFunction('size_t', mesh, 2, mesh.domains())
dx = Measure('dx', domain=mesh, subdomain_data=markers)
J_N = Constant(1.0)
J_S = Constant(-1.0)
class Permeability(UserExpression): #cambio
        super(Permeability, self).__init__(**kwargs) #agregado
        self.markers = markers
        if self.markers[cell.index] == 0:
            values[0] = 4*pi*1
        elif self.markers[cell.index] == 1:
            values[0] = 1
            values[0] = 1
mu = Permeability(markers, degree=1)
A_z = TrialFunction(V)
a = (1 / mu)*dot(grad(A_z), grad(v))*dx
L_N = sum(J_N*v*dx(i) for i in range(2, 2 + n))
L_S = sum(J_S*v*dx(i) for i in range(2 + n, 2 + 2*n))
L = L_N + L_S
A_z = Function(V)
solve(a == L, A_z, bc)
W = VectorFunctionSpace(mesh, 'P', 1)
B = project(as_vector((A_z.dx(1), -A_z.dx(0))), W)
thanks for reading and any help will be appreciated
Please format your code using 3 times `. Also please remove all lines of code not needed to reproduce the error.
Yes , will do that. Thanks.
To me the problem seems to be the permability, as all values are set to 1.
You can confirm this by removing the refine command and still getting a 0 solution.
I removed the refine command and got a vectors and values for B. But when activate the refine command, I got no vectors of B and when plotting in paraview the results of B are 0. Even if the iron permeability is set to 1500, still got 0 values of B when the refine command is active.
I strongly doubt that, as you can clearly see from just printing the markers before and after refinement:
a = 1.0
b = 1.2
c_1 = 0.8
c_2 = 1.4
r = 0.1
R = 5.0
n = 10
    p = cell.midpoint()
print(markers.array(), min(markers.array()), max(markers.array()))
mesh = refine(mesh)
which returns
[20 21 21 ...,  0  0  0] 0 21
[18446744073709551615 18446744073709551615 18446744073709551615 ...,
 18446744073709551615 18446744073709551615 18446744073709551615] 18446744073709551615 18446744073709551615
This means that your mesh.domains() are not carried over when you refine the mesh.
However, if you use the adapt function to redefine your markers:
markers = adapt(markers, mesh)
everything should work.
Full working code (where I have also changed the space you are projecting B into to something suitable):
a = 1.0
b = 1.2
c_1 = 0.8
c_2 = 1.4
r = 0.1
R = 5.0
n = 10
    p = cell.midpoint()
# Refine mesh in given area
J_N = Constant(1.0)
            values[0] = 4*pi*1
            values[0] = 1
            values[0] = 1
perm = project(mu, FunctionSpace(mesh, "DG", 0))
L = L_N + L_S
A_z = Function(V)
W = VectorFunctionSpace(mesh, 'DG', 0)
File("B.pvd") << B
Thank you very much for the code example, worked great.
I’ll continue working and studying.
Cheers
