Hello everyone!
I’m moving my code for adaptive refinement algorithm from Firedrake with Netgen to FEniCSx.
The initial meshes for both platforms are the same:
which is generated by the following
from netgen.csg import OrthoBrick, Pnt, CSGeometry
import ngsPETSc.utils.fenicsx as ngfx
from dolfinx.fem import (
functionspace, Function
cube1 = OrthoBrick(Pnt(-1,-1,0), Pnt(0,0,1))
cube2 = OrthoBrick(Pnt(0,-1,0), Pnt(1,0,1))
cube3 = OrthoBrick(Pnt(-1,0,0), Pnt(0,1,1))
geo = CSGeometry()
geo.Add(cube1 + cube2 + cube3)
geoModel = ngfx.GeometricModel(geo, MPI.COMM_WORLD)
domain, (ct, ft), region_map = geoModel.model_to_mesh(gdim=3, hmax=1.0)
The uniform refinement in Firedrake is implemented with the following code
# Firedrake code
msh = msh.refine_marked_elements(
Function(FunctionSpace(msh, 'DG', 0)).interpolate(1.0))
which generates the following finer mesh
I tried the Netgen refine in FEniCSx but it produces an error:
DG0 = functionspace(domain, ('DG', 0))
markers = Function(DG0)
markers.x.array[:] = 1.0
markers = np.flatnonzero(np.isclose(markers.x.array.astype(np.int32), 1))
domain, (_, ft) = geoModel.refineMarkedElements(domain.topology.dim, markers)
with the error message:
AttributeError Traceback (most recent call last)
Cell In[8], line 24
21 markers.x.array[:] = 1.0
23 markers = np.flatnonzero(np.isclose(markers.x.array.astype(np.int32), 1))
---> 24 domain, (_, ft) = geoModel.refineMarkedElements(domain.topology.dim, markers)
File /dolfinx-env/lib/python3.12/site-packages/ngsPETSc/utils/fenicsx.py:619, in GeometricModel.refineMarkedElements(self, dim, elements, netgen_flags)
617 el.refine = False
618 if not refine_faces and dim == 3:
--> 619 _dim_to_element_wrapper(self.ngmesh)[2]().Numpy()["refine"] = 0
620 self.ngmesh.Refine(adaptive=True)
621 self.ngmesh.Curve(1) # Reset mesh to be linear
AttributeError: 'netgen.libngpy._meshing.Array_N6netgen9Element2dE_N6netgen19SurfaceElementIndexE' object has no attribute 'Numpy'
I also try the uniform refinement imported as from dolfinx.mesh import uniform_refine but it gives a different result:
I’m trying to get the same refined mesh in FEniCSx that I got in Firedrake. I’m using the FEniCSx environment described in the tutorial: Adaptive mesh refinement with NetGen and DOLFINx — FEniCSx tutorial.
I’d appreciate any guidance on this issue. Thank you!
