Mesh size error to calculate stress in 3d elasticity
In a 3d linear elasticity model i hope to calculate Displacement and Stress tensor and i had a error for the model mesh size. I found the solution in UMFPACK error: out of memory despite system having free memory - #12 by ncarmona, but it only works to calculate the solution for u, when i try to calculate the Stress Tensor i have an error again. The code is:
from dolfin import*
from mshr import*
from fenics import*
from ufl import nabla_div
mesh = Mesh("Caseron_actual.xml")
#plot(mesh);
#Scaled Variables
E = Constant(20e3) #Módulo de Young
nu = Constant(0.3) #Radio de Poisson
mu = E/(2*(1+nu)) #Módulo de cizalle
lambda_ = E*nu/((1+nu)*(1-2*nu)) #Lamé
rho = Constant(0.027) #densidad
# Strain function
    return sym(nabla_grad(u))
# Stress function
def sigma(u):
    return lambda_*nabla_div(u)*Identity(3) + 2*mu*epsilon(u)
# lambda is a reserved python keyword, naming convention recommends using a single trailing underscore for such cases
#Load
g_z = 0.0
b_z = -rho
g = Constant((0.0,g_z,0.0))
b = Constant((0.0,0.0,b_z))
#Function Spaces
V = VectorFunctionSpace(mesh, "P", 2)
u_tr = TrialFunction(V)
u_test = TestFunction(V)
a = inner(sigma(u_tr),epsilon(u_test))*dx #bilineal form
l = dot(b,u_test)*dx + dot(g, u_test)*ds #lineal form
x_max = 1216.0
y_max = 929.
tol=1e-8
def bottom(x, on_boundary):
    return (on_boundary and near(x[2],0,tol))
bc1 =DirichletBC(V.sub(2), Constant(0.),bottom)
def left(x, on_boundary):
    return (on_boundary and near(x[0], 0,tol))
bc2 =DirichletBC(V.sub(0), Constant(0.),left)
def right(x, on_boundary):
    return (on_boundary and near(x[0], x_max,tol))
bc3 =DirichletBC(V.sub(0), Constant(0.),right)
def north(x, on_boundary):
    return (on_boundary and near(x[1], y_max,tol))
bc4 =DirichletBC(V.sub(1), Constant(0.),north)
def south(x, on_boundary):
    return (on_boundary and near(x[1], 0,tol))
bc5 =DirichletBC(V.sub(1), Constant(0.),south)
bc=[bc1,bc2,bc3,bc4,bc5]
#problem = LinearVariationalProblem(a, l, u, bc)
#solver = LinearVariationalSolver(problem)
#solver.solve();
solve(a==l, u, bc, solver_parameters={'linear_solver' : 'mumps'})
#Vsig = TensorFunctionSpace(mesh, "DG",degree=1)
#sig = Function(Vsig, name="Cauchy_Stress")
#sig.assign(project(-sigma(u), Vsig));
file_results = XDMFFile("Verde_CA.xdmf")
file_results.write(u, 0.)
#file_results.write(sig, 0.)
When i remove the # in the lines to calculate the stress the model dont work. I hope you can help me.
This is the error
You can change the solver in project, as shown in: Out of memory error - #4 by dokken
Thanks Dokken, its work perfect!
Hi dokken, im working whit a bigger 3d mesh and i cant run my model. I am using this solver:
u = Function(V,name="Displacement")
solve(a==l, u, bc, solver_parameters={"linear_solver" : "gmres", "preconditioner" : "ilu"},form_compiler_parameters={"optimize":True})
And the error is:
Hope you can help me
In general I would not use ilu to solve linear elasticity problems.
I would use cg and gamg (and attaching the near nullspace).
Anyhow, without an example reproducing the error, I cant give any more concrete suggestions
Im sorry, my code for the error is:
from dolfin import*
from mshr import*
from fenics import*
mesh = Mesh("FASE2.xml")
# Strain function
# Stress function
def sigma(u):
#Load
g_z = 0.0
b_z = -rho
#Function Spaces
x_max = 1216.0
y_max = 929.0
tol=1e-8
solve(a==l, u, bc, solver_parameters={"linear_solver" : "mumps", "preconditioner" : "ilu"},form_compiler_parameters={"optimize":True})
The point is that this does not help, as you have not supplied the mesh.xml file, or any way of generating the mesh file.
As I said above, I don’t think you are using a good solver for elasticity problems.
How can i share the xml file??
i can give you the file in one drive link:
As stated now three times, this is most likely due to your solver setup.
See for instance Bitbucket for a sensible configuration of your solver.
Thanks Dokken it works perfect! And sorry for your lost time and my insistance.
