MeshConnectivity in python
I would like to ask about the syntax of MeshConnectivity class in python. I have a 3D box (submesh) inside another 3D box (mesh) and I need to have two lists with the nodes which belong to each surface. (insurface->inside box, outsurface->outside box). Thank you!!
import random
mesh = Mesh(“dolfinmesh.xml”)
mesh_file_volume = MeshFunction(‘size_t’, mesh ,“dolfinmesh_volume_meshvalue.xml”)
mesh_file_surface = MeshFunction(‘size_t’ , mesh , “dolfinmesh_surface_meshvalue.xml”)
mesh_file_boundary = MeshFunction(‘size_t’ , mesh , “dolfinmesh_bcfunc.xml”)
V = FunctionSpace(mesh, “Lagrange”, 1)
insurface = list()
outsurface = list()
#I’ve tried: connectivity32 = mesh.topology(mesh, 3, 2); or connectivity32 = MeshConnectivity(3, 2); but #it doesn’t seem to work.
for cell in cells(mesh):
You need to initialize the mesh connectivity, as it is not computed by default:
mesh = UnitCubeMesh(3,3,3)
mesh.init(3, 2)
c2f = mesh.topology()(3,2)
print(c2f(0))
Thank you very much!
I also try to extract the nodes of which the surfaces (triangles) consist of. I’ve tried dof to vertex map but it doesn’t seem to work because surfaces are not my cell index. Any idea about how I can approach these nodes?
Thank you
Consider the following:
mesh = UnitCubeMesh(1,1,1)
mesh.init(3, 2)
mesh.init(2,0)
f2v = mesh.topology()(2,0)
for cell in range(mesh.num_cells()):
    facets = c2f(cell)
    for facet in facets:
        vertices = f2v(facet)
        print("Cell ", cell, " Facet ", facet, " Vertices ", vertices)
Thank you again, so much!
