I don’t understand the meaning/order of the arguments in MeshFunction, for examples this code gives error when uncommenting one of the two lines:
Len = 10.0
W = 2.0
H = 2.0
mesh = BoxMesh(Point(0.0, 0.0, 0.0), Point(Len, W, H), 10, 2, 2)
class Omega0(SubDomain):
return True if x[0] <= Len / 2 else False
class Omega1(SubDomain):
return True if x[0] > Len / 2 else False
subdomains = MeshFunction("size_t", mesh, mesh.topology().dim(), 0) # GIVES ERROR
#subdomains = MeshFunction("size_t", mesh, 0) # THIS WORKS
subdomain0 = Omega0().mark(subdomains, 0)
subdomain1 = Omega1().mark(subdomains, 1)
V1 = FunctionSpace(mesh, "CG", 1)
u = Function(V1)
v2d = vertex_to_dof_map(V1)
u.vector()[v2d] = subdomains.array()
#from vtkplotter.dolfin import plot
#plot(subdomains)
File “test.py”, line 28, in
IndexError: Index mismatch
How do I set correctly the u.vector() in the first case when I get the error message? Thanks!
The third argument to the MeshFunction constructor is the dimension of the mesh entities for which values of type "size_t" are stored. The fourth, optional, argument is the value to which the MeshFunction is initialized. (By default, it is zero.) The reason the first version gives an error is because u has values at vertices, whereas the MeshFunction has values at entities of the topological dimension of the mesh, i.e., cells. There is no one-to-one correspondence between cells and vertices, which is why there is an index mismatch. The second version works because the MeshFunction associates values with entities of dimension zero, i.e., vertices.
Thanks for your answer, so what would be the way to map the values from the entities to the vertices?
You can read The FEniCS Book on chapter 16. Entities of dimension 0 have the same order with vertices. I think you got the correct result already if using the commented line.
I have two other ways to do the same job:
subdomains = MeshFunction("size_t", mesh, 0, 0)
# subdomain0 = Omega0().mark(subdomains, 0)
subdomains = MeshFunction("size_t", mesh, 0, 1)
# subdomain1 = Omega1().mark(subdomains, 1)
Is it interesting?
