Mismatch in subspaces using FunctionAssigner
I am trying to mirror what MiroK proposes in this reply in order to assign values to a function.
Specifically, I only want to set two specific values to function u_n which is a subfunction of U_n.
Ve = FiniteElement("CG", mesh.ufl_cell(),1)
MS = FunctionSpace(mesh, MixedElement([Ve, Ve, Ve]))
U_n = Function(MS)
u_n, u_t1n, u_t2n = split(U_n)
#MiroK's code
u_v = U_n.vector()
dofs = MS.sub(0).dofmap().dofs()
u_i = u_v[dofs]
u_i[0] = a                 #first value to be set
u_i[len(u_i)-1] = b        #second value to be set
u_v[dofs] = u_i
#Code is wrong starting here
assigner = FunctionAssigner(MS, MS)
Functions_init = [Function(MS) for dofs_i in dofs]
for f, dofs_i in zip(Functions_init, dofs):
    f.vector()[:] = u_v[dofs_i]
Two issues here:
  • there is a mismatch in the FunctionAssigner. I only need to assign values to u_n but I’m working on U_n here, as I don’t know how to assign only to u_n.
  • I’m not doing things correctly in the last loop either. It’s the same issue, I’m trying to work on u_n only but I can’t find the appropriate syntax.
Here is the error I get
RuntimeError:
*** Error: Unable to create function assigner.
*** Reason: Expected the same number of sub spaces in the receiving FunctionSpace as the number of assigning FunctionSpaces.
*** Where: This error was encountered inside FunctionAssigner.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:
Thanks for your help
Here is a test using FunctionAssigner. This will help you.
