Missing entries in matrix assembled from facet submesh custom kernel
I created a custom kernel using numba and ffcx for a facet submesh. The resulting matrix seems to be missing entries. The matrix should have blocks of the form
[[1.         0.5        0.         0.         0.         0.        ]
 [0.5        1.         0.         0.         0.         0.        ]
 [0.         0.         1.41421356 0.70710678 0.         0.        ]
 [0.         0.         0.70710678 1.41421356 0.         0.        ]
 [0.         0.         0.         0.         1.         0.5       ]
 [0.         0.         0.         0.         0.5        1.        ]]
but some entries are missing. Here’s the MWE which adapts the kernel from dolfinx_hdg/python/demo/hdg_poisson.py at main · jpdean/dolfinx_hdg · GitHub.
from dolfinx import mesh, fem, jit, io, default_scalar_type, default_real_type
from dolfinx.cpp.mesh import cell_num_entities
import dolfinx.fem.petsc as petsc
from ufl import inner, grad, dot, div
from dolfinx.fem import IntegralType
import cffi
import numba
from dolfinx.cpp.fem import Form_float64
import sys
import json
from ffcx.codegeneration.utils import empty_void_pointer
from ffcx.codegeneration.utils import numba_ufcx_kernel_signature as ufcx_signature
# import custom_assembly
dtype = default_scalar_type
rtype = default_real_type
Print = PETSc.Sys.Print
nptype = 'float64'
ffcxtype = 'double'
null64 = np.zeros(0, dtype=np.float64)
null32 = np.zeros(0, dtype=np.int32)
null8 = np.zeros(0, dtype=np.uint8)
ffi = cffi.FFI()
def compute_cell_boundary_facets(msh: dolfinx.mesh.Mesh) -> np.ndarray:
    """Integration entities for integrals around all cell boundaries.
    Returns flat array of (cell_index, local_facet_index) pairs, as
    required by ``ufl.Measure("ds", subdomain_data=...)``.
    (Copied verbatim from demo_hdg.py.)
    tdim = msh.topology.dim
    fdim = tdim - 1
    n_f = cell_num_entities(msh.topology.cell_type, fdim)
    n_c = msh.topology.index_map(tdim).size_local
    return np.vstack(
        (np.repeat(np.arange(n_c), n_f), np.tile(np.arange(n_f), n_c))
    ).T.flatten()
def get_kernel(ufl_form, comm):
    """JIT-compile ufl_form and return its cell-integral tabulate_tensor fn."""
    ufcx_form, _, _ = jit.ffcx_jit(
        comm, ufl_form, form_compiler_options={"scalar_type": ffcxtype}
    attr = f"tabulate_tensor_{nptype}"
    return getattr(ufcx_form.form_integrals[0], attr)
comm = MPI.COMM_WORLD
n = 2
msh = mesh.create_unit_square(comm, n, n, ghost_mode=mesh.GhostMode.none)
fdim = tdim - 1
num_cell_facets = cell_num_entities(msh.topology.cell_type, fdim)
msh.topology.create_entities(fdim)
facet_imap = msh.topology.index_map(fdim)
num_facets = facet_imap.size_local + facet_imap.num_ghosts
facets = np.arange(num_facets, dtype=np.int32)
facet_mesh, facet_mesh_emap = mesh.create_submesh(msh, fdim, facets)[0:2]
k = 1
V = fem.functionspace(msh, ("Discontinuous Lagrange", k))
Vbar = fem.functionspace(facet_mesh, ("Discontinuous Lagrange", k))
V_dim = V.element.space_dimension
Vbar_dim = Vbar.element.space_dimension
u = ufl.TrialFunction(V)
ubar = ufl.TrialFunction(Vbar)
vbar = ufl.TestFunction(Vbar)
h = ufl.CellDiameter(msh)
n = ufl.FacetNormal(msh)
gamma = 6
dx_c = ufl.Measure("dx", domain=msh)
cell_boundary_facets = compute_cell_boundary_facets(msh)
cell_boundaries = 1  # tag value
ds_c = ufl.Measure("ds", subdomain_data=[(cell_boundaries, cell_boundary_facets)],
                   domain=msh,)
a_11 = gamma * inner(ubar, vbar) * ds_c(cell_boundaries)
kernel11 = get_kernel(a_11, comm)
num_dofs_g = V.dofmap.index_map.size_global
@numba.njit(fastmath=True)
def compute_A11(coords):
    A11 = np.zeros((num_cell_facets * Vbar_dim,
                    num_cell_facets * Vbar_dim),
                   dtype=PETSc.ScalarType)
    A11_f = np.zeros((Vbar_dim, Vbar_dim),
    entity_local_index = np.zeros((1), dtype=np.int32)
    coeffs = np.zeros(0, dtype=dtype)
    consts = np.zeros(0, dtype=dtype)
    for local_f in range(num_cell_facets):
        A11_f.fill(0.0)
        entity_local_index[0] = local_f
        kernel11(ffi.from_buffer(A11_f),
                  ffi.from_buffer(coeffs),
                  ffi.from_buffer(consts),
                  ffi.from_buffer(coords),
                  ffi.from_buffer(entity_local_index),
                  ffi.from_buffer(null8),
                  empty_void_pointer(),
        # Insert in correct location
        start = local_f * Vbar_dim
        end = start + Vbar_dim
        A11[start:end, start:end] += A11_f[:, :]
    return A11
x_dofs = V.mesh.geometry.dofmap
x = Vbar.mesh.geometry.x
geometry = x[x_dofs][2]
A11_loc = compute_A11(geometry)
Print(A11_loc)
c_signature = numba.types.void(
        numba.types.CPointer(numba.typeof(PETSc.ScalarType())),
        numba.types.CPointer(numba.types.double),
        numba.types.CPointer(numba.types.int32),
        numba.types.CPointer(numba.types.uint8))
@numba.cfunc(c_signature, nopython=True, fastmath=True)
def tabulate_tensor_a(A_, w_, c_, coords_, entity_local_index, permutation=ffi.NULL):
    A_local = numba.carray(A_, (num_cell_facets * Vbar_dim,
    coords = numba.carray(coords_, (num_dofs_g, 3), dtype=PETSc.ScalarType)
    A_local += compute_A11(coords)
cells = np.arange(msh.topology.index_map(tdim).size_local)
facets = np.arange(facet_mesh.topology.index_map(fdim).size_local)
integrals_a = {fem.IntegralType.cell: [(0, tabulate_tensor_a.address, cells, np.array([], dtype=np.int8))]}
formtype = fem.form_cpp_class(dtype)
form_type_compiled = formtype([Vbar._cpp_object, Vbar._cpp_object], integrals_a, [], [], False, mesh=msh._cpp_object, entity_maps=[facet_mesh_emap._cpp_object])
a_cond = fem.Form(form_type_compiled)
A = petsc.assemble_matrix(a_cond, bcs=[])
A.view()
