I have installed fenics and doflin from source code using the instructions in the fenics documentation. I am successfully able to run my code on the head node but when I try to run the exact same code on the compute node of the cluster, I get the following error.
In file included from /export/apps/gcc-7.4.0/include/c++/7.4.0/ext/string_conversions.h:41:0,
from /export/apps/gcc-7.4.0/include/c++/7.4.0/bits/basic_string.h:6361,
from /export/apps/gcc-7.4.0/include/c++/7.4.0/string:52,
from /export/apps/gcc-7.4.0/include/c++/7.4.0/stdexcept:39,
from /home/kenjakt/anaconda3/envs/fenics2/lib/python3.7/site-packages/ffc/backends/ufc/ufc.h:20,
from /home/kenjakt/anaconda3/envs/fenics2/dolfin/include/dolfin/function/Expression.h:25,
from /tmp/tmp91xne4pt/dolfin_expression_91009fe811dc440183092772d4dda843.cpp:13:
/export/apps/gcc-7.4.0/include/c++/7.4.0/cstdlib:75:15: fatal error: stdlib.h: No such file or directory
#include_next <stdlib.h>
compilation terminated.
Looking up on what “include_next” does informed me that it removes the directories from the search path to avoid recursively including header files. I am not sure how to fix this issue so the code can run on the compute nodes of hpc too.
Can anyone please point me in the right direction?
Thank you for any help I can get!
Krishna
