I am pretty new to all this - FEM and dolfinx.
I am trying to get the frequency response of an acoustic cavity using modal superposition. Essentially, I am follwoing this tutorial: Modal Superposition in Acoustic Cavities – Unda Project
Although my knowledge is pretty limited, I was able to follow the tutorials on that site, with lots of trying around and referring to other resources.
But I really can’t figure out the last step that in this tutorial is described as “a couple of matrix multiplications” and computing the modal participation factors using a ksp linear solver.
I’ve searched a lot online and even gave chatgpt a shot. The fact that dolfinx and dolfin seem to have quite some differences doesnt make it easier for a beginner to try out code found online.
Any help is greatly appreciated.
Below is the code i have currently.
It seems to correctly extract the modes of a half-open tube. The open-ness is modeled with a dirichlet bc at the right.
I would be interested to apply an acoustic load (As far as I read it should be a velocity source, but i don’t quite know) to the left of the tube and see what the frequency response looks like via modal superposition.
Thank you!
# Dolfinx version: 0.6.0, complex number support.
# Python Version: 3.10.9
# IMPORTS
from dolfinx.mesh import create_box
import pyvista as pv
pv.set_jupyter_backend('static')
print("Pyvista Backend: ", pv.global_theme.jupyter_backend)
from dolfinx import plot
import sys, slepc4py
slepc4py.init(sys.argv)
from dolfinx import fem
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace, VectorFunctionSpace,
locate_dofs_topological)
from dolfinx.mesh import (create_box, meshtags, locate_entities, CellType,
locate_entities_boundary)
from slepc4py import SLEPc
from dolfinx.mesh import create_rectangle
from ufl import (inner, grad, dx)
from dolfinx.fem import Function, FunctionSpace, assemble_scalar, form, Constant
from tqdm import tqdm
deg = 1
c0 = 340 # [m/s]
freqMax = 20000 #Hz Maximum Frequency of interest
λ_min = c0/freqMax
meshSizeMin = λ_min/10. # [m] rule of thumb according to https://undaproject.com/sound-propagation-in-3d-cavities
print(f" - Speed of sound: {c0} m/s")
print(f' - Lambda min: {λ_min} m')
print(f" - minimum Mesh Size approx: {meshSizeMin*1e3:.2f} mm")
L_mm = 500 # [mm] Pipe Length
D_mm = 20 # [mm] Pipe Diameter
L = L_mm/1e3
D = D_mm/1e3
f_analytic = c0/(4*L)
print(f"Predicted Fundamental Frequency: {f_analytic} Hz")
print("Expected Harmonics:")
for i in range(5):
print(f"{i+1}. { f_analytic*((i+1)*2+1)} Hz")
print('....')
## Deinition of Geometry
ll = np.array([0,0]) #lower left corner [mm]
ur = np.array([L_mm,D_mm]) #upper right corner [mm]
ll = ll/1e3 #to meters
ur = ur/1e3 #to meters
dims = ur - ll
numCellsPerDim = np.ceil(dims / meshSizeMin).astype(np.int64)
print(f"N Cells: {numCellsPerDim}")
estCellsTotal = int(numCellsPerDim[0]*numCellsPerDim[1])
print(f'Estimated Cells Total: {estCellsTotal}')
## Mesh Creation
mesh = create_rectangle(MPI.COMM_WORLD, [list(ll), list(ur)], list(numCellsPerDim), cell_type=dolfinx.mesh.CellType.quadrilateral)
tdim = mesh.topology.dim
#pv.start_xvfb()
topology, cell_types, geom = plot.create_vtk_mesh(mesh, tdim)
grid = pv.UnstructuredGrid(topology, cell_types, geom)
plotter = pv.Plotter(window_size=[1500, 500])
plotter.view_xy()
plotter.show_grid(font_size = 15)
plotter.camera.zoom(2.5)
plotter.show()
# Test and trial function space
V = FunctionSpace(mesh, ("CG", deg))
u = ufl.TrialFunction(V)
# Define boundary conditions
def getRightBorder(x):
return np.isclose(x[0], ur[0])
fdim = mesh.topology.dim - 1
boundary_facetsR = locate_entities_boundary(mesh, fdim, getRightBorder)
print("Boundary facets right:", boundary_facetsR)
u_D = Function(V)
u_D.interpolate(lambda x: x[1]*0) #Doesnt make much sense to me but works
bcR = dirichletbc(u_D, locate_dofs_topological(V, fdim, boundary_facetsR))
# Stiffness and Mass Matrices
stiff_matrix = inner(grad(u), grad(v)) * dx
mass_matrix = inner(u, v) * dx
# Using the "diagonal" kwarg ensures that Dirichlet BC modes will not be among
# the lowest-frequency modes.
SM = dolfinx.fem.petsc.assemble_matrix(form(stiff_matrix), [bcR], diagonal=62831)
MM = dolfinx.fem.petsc.assemble_matrix(form(mass_matrix), [bcR], diagonal=1/62831)
SM.assemble()
MM.assemble()
# Setup the eigensolver
N = 50 #num modes to extract
problem = SLEPc.EPS().create()
A = [ ]
A.append(SM)
A.append(MM)
# Setup Spectral Transformation
st = SLEPc.ST().create()
st.setType(SLEPc.ST.Type.SINVERT)
st.setShift(0.1)
st.setFromOptions()
problem.setST(st)
problem.setDimensions(N)
problem.setProblemType(SLEPc.EPS.ProblemType.GHEP)
problem.setInterval(10,18)
problem.setOperators(SM,MM)
# Solve the eigenproblem
problem.solve()
# Getting the result vectors
xr, xi = SM.createVecs()
nconv = problem.getConverged()
if nconv > 0:
modes = []
eig_values = []
eig_vectors = []
eig_freq = []
vrs = []
for i in range(nconv):
# eigenvector = Function(V)
# modes.append(eigenvector)
k = problem.getEigenpair(i, xr, xi)
fn = np.sqrt(k.real)/(2*np.pi)*c0
eig_values.append(k)
eig_freq.append(fn)
vrs.append(xr.array.copy())
